Question about Panasonic PT-43LC14 43" Rear Projection HDTV
Air filter How do you reset the air filter warning. I heard there is a code using you remote control to do this. A warining for air filter cleaning comes up and then turns off my TV. I have called Panasonic and they say there is no filter. Please help
  • momnky Dec 30, 2007
    i am having the same problem can someone help
  • 579 Answers
Is your set under warranty? If not, bite the bullet now and get the service manual - you will need it sooner or later.
Whether there is a way to reset the warning or not, a solution is needed for the problem of restricted airflow and you will need to take off teh back panel and blow out the dust using compressed air and while your in there, look for any filters in front of the fans.
Posted on Dec 31, 2007
Where is reset button located on whirlpool split ac front panel? (Mastermind series chrome). Though I cleaned my filter the "filter" light is still glowing and hence i need to reset it but I am not finding...
Look real hard on the remote. There is a mini "use a ballpoint pen" push to reset filter button on the remote.
Electronic control panel: (not all models)
Hold the mode button and the Temp Up arrow depressed for about 5 seconds. It should display the temp and the FL should disappear.
Thanks for choosing FixYa.
Sep 05, 2010 | Whirlpool ACC108PS Air Conditioner
The error code E1 is lit on the front panel of room air conditioner. The instuction book is lost and I can't locate the model number. It says energy star and comfort touch and come with an remote...
E1 is refering to the air filter. If turning the unit off and unplugging doesn't reset it then you probably have a PC board or sensor failure. None of these units can actually detect a dirty air filter. All it does is set a timer that turns the E1 on after what the manufacture determines is average.
Hope that helps.........
Jul 28, 2008 | Sharp Heating & Cooling
At exactly 120,000 miles the service 4w drive warining shows up on my panel. Is that a actual warning or do they just want me to bring it in because im at 120, 000 miles?
It is an actual warning.The 4wd is not like an emission warning where it has to be checked to make sure it still passes emissions.You need to get the codes checked to see what could be causing the light to come on.Hope this helps.Good luck.
May 24, 2010 | 2004 Chevrolet Suburban
Camera having error WARNING FOCUS LOCK
Hello there! Focus ring lock means that some how the focus ring is not turning freely. If it turns easilly then inside the optocoupler unit which reads out the movement of ring must be dust or the flexicable. Therefore somehow the camera should be disassembled got cleaned by pressurized air in case of dust and reassembled and hopefully it should work without problem.
Aug 12, 2009 | Panasonic AG-DVX100 Mini DV Digital...
The clean your filter warning sign comes up and then shuts the projector down in 1 min. I have changed the lamp and filter. How do i reset the timer for the Lamp Hours and get rid of the warning?
Once the filter is replaced, plug the projector back in and make sure the projector is in standby mode.  Point the remote control at the projector and press the following buttons in order in less than 3 seconds: reset, ←, →, enter.  This worked for me.  Good luck.
Feb 21, 2009 | Sony VPL-VW100 (Ruby) Multimedia Projector
It says reset filter
Reset the filter timer. (1) Turn on the projector. While the projector running, press the MENU button to open the menu. (2) Choose the “OPTION” on the menu using the up/down button, then press the right button or ENTER button. (3) Choose the “FILTER TIME” using the up/down button, then press and hold the right button of projector or the RESET button of remote control for 3 seconds. (4) Choose the “RESET” using the up button.
Dec 04, 2008 | Office Equipment & Supplies
Panasonic PT-60LCX64 Air Filter Cleaning
Cleaning filter for the Panansonic PT-501LCX64.
I just had a T.V. tech do this. The filters are located on the two removable filters on the back side of the T.V. They look like the speaker units. He removed those two units, unplugged them & set them on the floor. He took some type of electronic cleaner with a cloth & wiped them down. The filters themselves are plastic. He explained that air flows through some tube connected to these plastic filters for cooling down below. He admitted they didn't look dirty--put everything back together & it is working fine now.
I imagine that dirty or not the timer is automatically set for every 400 hrs. of use to give you the prompt that the filter needs cleaning & will shut off in one minute so you can call a T.V. tech?
So to reset the timer--follow the other detailed prompts listed on this board & or use your owners manual & follow the prompts for replacing the bulb. That should take you somewhere to reset the timer--so you have another 400 hours of operation.
I believe it's with the T.V. turned off--hold down the down volume on your tv itself while holding the swap button on the remote control for 5-7 seconds---then follow the prompts. You should see a prompt for replacing a bulb & then one for filter cleaning. Then just reset the timer.
Hopefully this will help?
Nov 04, 2008 | Panasonic PT-60LCX64 Television
Air Filter Waring for Panasonic PT-43LC14
This may be a temperature issue there is a thermal sensor that tell the tv its to hot and need air so it think its filte is cloged. make sure there is plenty of clearance for air flow.. however there may be more involved problem with the set ... the sensor could be failing
Nov 22, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Reset filter
The solution is simple. Just press on the little red light that says to reset filter. Its a button that will reset the warning and the light should go out
May 14, 2007 | Kaz Honeywell Tower Air Purifier with IFD...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
310 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
