Question about Dell Inspiron 6400 Notebook
Excellent signal but not able get access online
Ive just brought dell inspiron 6400 w wireless 1390 wlan mini-card, ive entered the network key in correctly, disabled the firewall (heard it can cause probs to start with) and still l cant access the internet, says cant display page...any help would be appreciated....and if you can put it in layman's terms,not really comp literate...thanks in advance
I always see if the wireless works withOUT the burden of the encryption. Half the time the key was wrong just to spite me. Then add in encryption after you've proved everything else works. Another not-so-funny thing is the function key RadioOff (blue function key + F2 I think) gets hit by accident sometimes and turns the radio off without telling you. You can see a msg in the Dell Wireless software on the..second tab I think, when this toggles off...--Jeb
Posted on Nov 26, 2007
Dell NetworkDell Wireless 1350 WLAN MiniPC
The Dell Wireless WLAN Card Utility locates, manages and provides information about wireless networks in your area.
The Dell Wireless WLAN Card Utility allows you to create network profiles, connect to an available network, and diagnose connection problems.
Enable the utility through an icon in the notification area of your desktop, or locate it in the programs list depending on which Dell computer you have.
Turn on the Dell laptop and make sure the wireless switch is in the "On" position.
Right-click the utility icon in the notification area of your desktop.
The icon appears as a set of four green, yellow, red or white bars, depending on the signal strength in your area.
Click "Enable Radio."
Right-click the icon and click "Open Utility" to open the Dell Wireless WLAN Card Utility.
Control Panel
Click "Start" and select "Dell Wireless WLAN Card Utility."
Click the box next to "Enable Radio" and click "Apply."
Click "OK."
Jul 05, 2013 | Dell NetworkDell Wireless 1350 WLAN...
Dell Wireless 1390 WLAN Mini-Card driver
Hi. You can download the driver from Dell website. I strongly recommend that even there will be more recent versions out there, stay with the versions released by Dell, Dell before releasing a driver tests it with the systems to ensure full compatibility and zero-problems with other devices:
Dell Wireless 1390 WLAN mini-card driver
Also for future needs, it's advisable that you go to the following web page:
Dell Drivers & Downloads
And enter the service tag of your Dell computer, so that you could get drivers specific to your system.
hope it helps
Oct 22, 2012 | Microsoft Windows XP Home Edition
I cannot get my wireless Lan mini card to connect to a wireless network, the network is detected but will not connect
Go to the Device Manager. Double click on the Dell Wireless (1390/1490/1500) Dual Band WLAN Mini-Card device. The properties dialog should appear. Click on the Advanced tab. Look for Antenna Diversity under the Property. Change the value to Aux. Hit ok. Then try and reconnect to your WIFI connection. By changing this you should see your access point and be able to connect to it.
May 08, 2011 | Toshiba Computers & Internet
I have limited connectivity. Both my Broadcom 440x 10/100 Integrated Controller and Dell Wireless 1390 WLAN Mini-Card drivers are up to date.
make sure the access point or router is on DHCP then connect the computer, but if its on dynamic IP... them enter an IP in range of what you have on your AP/Router
Sep 06, 2009 | Dell 430-0008 Network Adapter
Wireless Connection Problems between an Dell Laptop and Actiontec
Have you got permission to connect into her Internet using her wireless router?
If so you need to get the WPA encryption key from her to configure your wireless card's encryption to get access.
Jun 28, 2009 | Dell Inspiron E1505 Notebook
Browsers on Dell Inspiron E1505 won't bring up pages
Open a command prompt and type the following command:
netsh winsock reset
This works wonders on mysterious networking problems like the one you describe here.
Hope this helps.
Feb 28, 2009 | Dell Inspiron E1505 Notebook
Wireless card in E1505 Dell not finding networks in range
The 1390 WLAN Minicard may not be configured to communicate with your wireless router.
Check the wireless router settings, (check the wireless settings on your other computer) and configure the 1390 WLAN with the same settings eg. SSID, WEP/WAP encryption, etc.
Is MAC address filtering enabled on your wireless router, if so add the MAC address of the 1390 WLAN to the MAC address list in the wireless router.
Check the TCP/IP properties of the 1390 WLAN card the Internet protocol should not have a fixed IP address, set it to Obtain an IP address automatically including the DNS.
Use the Ipconfig command to see the IP configuration of the network cards.
Use the Ping command to see if you can communicate with wireless router.
Feb 03, 2009 | Dell Inspiron 1501 Notebook
Changing OS from XP home edition to Xp professional
Get free program called driver max its easy to use you just need to registar with email and stuff will find drivers for you ;-) hope this helps also is your wireless lan built into the computer or is it a plug in card look on keyboard for key with FN on press and hold this and look for key that looks like radio mast and press this at same time that is if you have the keys will look now for you on dell webby
Jan 14, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 1520
it'll not fit since your laptop needs an expresscard.
here are the list of the wireless cards that you can get:
Dell Wireless 1390 802.11g Mini Card Wireless Dell Wireless 1490 802.11a/g Mini Card Wireless Dell Wireless 1505 Wireless-N Mini Card Intel Pro/Wireless 3945 802.11 a/b/g Mini Card Wireless Intel 4965AGN Wireless-N Mini Card Dell Wireless 5510 HSDPA ExpressCard34 Dell Wireless 5520 HSDPA Dell Wireless 5720 EVDO or a Linksys Wec600n Wireless-N Expresscard Adapter
Jun 04, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Dell Inspiron 6400 Notebook Logo
180 people viewed this question
Alun Cox
