Question about HTC G1 Smartphone
My g1 wont go past the andoid screen
I just got a new g1 shipped to me becasue my other keyboard of my g1 wasnt working well, and this new one turned on once, but now it doesnt turn on past the andoid screen i really need help im getting frustrated thanks,
Hi, my htc g1 is stuck in "Clockworkmod recovery v2.5.0.1" i cant do anything if i try to reboot my phone it stays at the g1 screen for hours... do you know what is wrong?
late response im sure, but it sounds like you tried to install either a bad rom (ie wasnt made for the g1/improperly packaged) or it was rom that was corrupted in download. i would wipe data/cache, then try to install it again. if that doesnt work, just get yourself a sd card adapter pop it in your computer, download the firmware again, then reinstall with clockworkmod
Dec 18, 2010 | HTC G1
My g1 phone has locked and wont accept my username and password. I have changed the password on line and checked it works but cannot get my phone to unlock
Okay the thing here is you need to master reset it.
Here's how it works:
  1. Power off the G1
  2. Hold Home Key + End key for 20 seconds or until you see a "triangle with an exclamation point and a picture of the G1"
  3. Open the QWERTY keyboard and hit Alt+W
  4. Restored!
To do a soft reboot, simply hit the Home+Back buttons when you reach the "triangle with an exclamation point and a picture of the G1" screen.
This will reset your phone as if it were brand new and your correct user name and password combination will work.
(This is coming from a direct T-Mobile employee)
-Joe
Oct 22, 2009 | HTC G1 Smartphone
G1 phone was turned off and then when i turned it on. it stays on the "ANdrioD opening "and wont go past that point.
hey the same thing has happened to me as well for both my g1 and g2 it is really ridiculous. Have you figured out how to fix it or get somone to fix it?
Jul 13, 2009 | HTC G1
G1 boot up error
when i turn my phone on it wont go to the android area. instead it shows a picture of my phone with a exclamation inside a triangle... ive tried to reset it and it wont go past this.
Jun 16, 2009 | HTC G1 Smartphone
My G1 phone wont factory reset itself and i dont know what to do, im not sure if i can still return my phone and get a new one because i had it since March 13,2009
Have you tried a reset using the hardware buttons? To perform this, you need to turn off the phone first. While it is off, press and hold the home key and the power key at the same time. Keep holding the buttons until you see a screen with a triangle and an exclamation point in the middle. Once you see the triangle, let go of the buttons and open the keyboard. Press ALT+W at the same time, and the phone should reset.
Jun 06, 2009 | HTC G1
My G1 cut off and now it wont come back on... when i take out and put my battery back in the phone it stops at the screen that says android and will not pass....plz help!
To hard reset...turn the phone on while holding home and back. Follow on screen prompt. this will reset the phone to factory settings,
out of the box settings
hold home + power
once phone is on, open keyboard and hold alt first + w
you should call T-moble support. its probably the ahome app.
May 13, 2009 | HTC G1 Smartphone
Screen wont turn on
You are going to have to ty a hard reset. Don't worry about things being deleted from the phone, as your phone auto syncs with Gmail when you enter your account info again.
If that doesn't work try..
Hold home and power buttons
Feb 27, 2009 | HTC G1
Microsoft Keyboard & Mouse not working
Hi there
Remember to check the batteries and press the connect buttons underneath the keyboard and on the mouse or mouse docking station
post back if no results
Kind regads
Feb 18, 2009 | Microsoft EF1330255 Keyboard/Mouse
G1 Keyboard problem
i was in my local T-Mobile shop (UK) yesterday checking out the G1 before release date, Whoever said it isnt a high quality keyboarad has some serious personal issues. the keyboard on the phone is Really high quality, with backlit keys which are slightly raised to assist in typing, dedicated shortcut and programmable Keys and a really sturdy Sliding mechanism on the main screen ! as with most of HTC's QWERTY phones, the Keyboard is Top notch !
Hope this Helps
Greenie UK
Sep 25, 2008 | HTC G1
HTC G1 Smartphone Logo
262 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
