Behind the plastic power button is a tiny metal switch. If just the button is broken, use a tiny plastic tool to push the switch. But if the switch is also broken, I recommend returning the tablet for a refund or replacement if it is still covered by the factory warranty.
Fixing a broken power switch is delicate work and may cost more than the value of the tablet.
SOURCE: While playing a game, my
If holding down the power button for 10 seconds (theoretically, try holding it down for ages and be patient) doesn't reset your device, you may have to wait for the battery to run flat, then try the reset procedure again.
Hope this helps,
Alistair
SOURCE: My Samsung Galaxy Tab won't turn on, even though battery is full. What's the problem?
hi did you fix your problem?
SOURCE: Samsung galaxy tablet is frozen
Couldn't even turn mine off ... read up on this.
SIMPLE SOLUTION: Hold the power button down for more than ten (10) seconds. WORKED!!!!
SOURCE: I want to hard reset
how to hard rest Samsung Galaxy Tab Tablet PC
press and hold -sound and power for 5 second you well open recovre mod press hard reset and press the long words and write yes the phone well restart and well pe in factore mod
contact vendor mfg - shoulds be under warranty
