Question about Hoover U6434-900 Bagged Upright Vacuum
Roller doesn't turn...no forward or backward...
  • 144 Answers
Check the belt, if it's a belt driven brush roller. If not, check the bearings of the roller. You may need to replace the brush roller. Take it to a local shop and have it looked at.
Posted on Jul 29, 2009
Why the Dyson dc 41 roller brush will not turn?
Try these steps:
  • Check the button that turns off the roller brush to make sure you didn't press it by accident.
  • Unplug the vacuum and clear pet hair and other debris off the roller brush. It may stop as a safety feature if the roller brush is too restricted.
  • Make sure the belt to the roller brush is placed correctly and not broken.
  • Press the roller brush reset button. It may be located on the side of the vacuum's head, or inside the handle. The switch may need to be replaced if it's defective.
  • The roller brush is disabled while the handle is in the upright position, so tilt the handle backwards while testing the roller brush.
I hope that helps you!
Jun 21, 2014 | Dyson Dc 41 Ball
U6485-900 WindTunnel Self-Propelled I changed the belts but there is not enough tension on the brush drive belt to get it to rotate
I had the exact same problem with my Hoover U6485-900 Anniversary upright, self propelled, vacuum. It would move backwards and forwards, had good vacuum, but wouldn't pick up much because the brush/roller was not turning very well. I replaced the main drive belt (38528035) and it now works great. The old belt had stretched and was slipping under load. Thanks for the great suggestions.
Aug 02, 2013 | Hoover U6485900 Bagged Upright Vacuum
I placed the new belt on the brush roller like i was suppose to, but brush roller will not turn forward or backward. What am I doing wrong?
Most likely the roller is frozen due to dirt and debris. Follow the instructions to remove the belt and roller. Clean the roller as best you can and at each end where the hard rubber holders are located. Add some WD40 between the brush and these holders and turn by hand until the holders move freely around the brush. Reassemble making sure the belt is on in the correct manner so the brush rotates in the proper direction.
Oct 04, 2010 | Dirt Devil Featherlite Bagless Vacuum...
How to change belt on eureka whirlwind; what tool do I need
You will first need to remove the hood to gain access to the belt and brush roller. Turn the machine upside down, place the handle on the floor and the base on a counter. You will find several screws that hold on the hood, remove them. Turn the machine back to the upright position and remove the hood. On the right hand side,if your looking the front you will find where the belt goes. At the back you will find a silver shaft sticking out, put the new belt on there first. Then put the brush roller through the belt so it is in the carved out section of the brush roller. Then grab the brush roller by each end and stretch the belt till the brush roller fits back into the base. Turn the brush roller 3 compleat turns backwards and 3 forward to seat the belt in the proper position.
Then put back on the hood.
May 08, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
The power bar stopped working. The vaccume is
If its 2 months old I wouldnt stress looking at anything. Box it up and take it back. Something that flimsy doesnt make sense to keep does it?
Apr 29, 2010 | Hoover S3765-040 WindTunnel Bagless...
When machine is running the brush does not turn
You need a new belt. In order to change it, turn the machine compleatly upside down and place the head on a counter, handle on the floor.
There is a L shaped base plate to remove that has 5 screws in. Once the base plate is off, you see the brush roller and a silver shaft directly back from where the belt would ride. Remove the brush roller, place the new belt, Dirt Devil Style 5 ( see link below ) on to the shaft. Then insert the brush roller, so the belt is on the raised carved out section of the brush roller. Grab the brush roller at each end and stretch it till you are able to put the brush roller back into the base. Turn the brush roller backwards 3 compleat turns and the same forward to seat the belt.
Replace the base plate and you're done.
Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001 - Free Shipping Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001
Cost $ 8.00
Apr 28, 2010 | Dirt Devil Featherlite Bagless Vacuum...
How to put the belt on the deit devil breeze
Here is a detailed discription on how to change your belt. Turn the machine compleatly upside down and place head on a flat surface. There are 4 screws to take out, then remove the base plate. Near the back of the channel the belt rides in you will see a stright silver shaft. Place the new belt over that shaft. The put the brush roller through the belt, so the belt is in the notched out section of the brush roller. Grab both ends of the brush roller and pull till the brush roller is back in it's origial spot on the base of the vacuum. Turn the brush roller 3 compleat turns backwards, then do the same forward to seat the belt. Put back on the base plate and put back the 4 screws. You are now ready to vacuum.
Apr 09, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
Runs but doesn't vacuum/****. Sidebrush works fine. Cleaned the roller brushes, and that seemed to confuse the robot and now it keeps going backward a few inches, turning, and then starts going backward...
sounds like a sensor problem. pull and clean the front black/white caster assembly and the revealed movement sensor and the 4 cliff sensors along the bottom of the front. Make sure the front caster wheel turns freely. You may have to remove the roller from the caster assemply and push the axle out and clean it.
Oct 08, 2009 | iRobot Roomba 560 Robotic Vacuum
Self propel will go foward, but will not reverse. Seems like handle is all the way extended.
There is a cable that connects to the handle and goes down to the powerdrive transmission. It is visible at the actuator arm on the drive if you look at the bottom of the handle where it pivots on the main housing. It will be on the right hand side, front corner of the handle bottom. You should be able to see the cable connected to the arm of the drive and will move back and forth with the top handle. Sometimes, they break at this connection. The cable may be frayed and broken, or the acuator arm may be broken where the cable connects.
This could also be a simple worn belt problem. The roller is always rotating in a direction that pulls the machine forward and if the belt is worn, the roller will turn sluggishly but still enough to pull forward, but the belt also drives the transmission and a worn belt will not have the capacity to overcome the forces involved to propel the machine backwards. Always change the belt(s) yearly.(on average)
Dec 22, 2007 | Hoover U6630-900 WindTunnel Bagless...
DC07 Very difficult to push forward.
on the front of the base there are 3 very small rollers made out of rubber, these are either just dry and won't turn or worn and or damaged,
that is your problem / honest its that simple
Oct 13, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover U6434-900 Bagged Upright Vacuum Logo
160 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
