Question about Quantum DLT 4000 DLT Tape Drive
What is a leader tape look like and how do I finf
What does a leader tape look like and how do I find it when looking into my DLT 4000?
    Scholar:
  • 74 Answers
The tape leader is a band of flexible plastic with a hook on the end that is attached to the reel inside the drive.
When a damaged tape is used in the drive or when the drive is faulty, the tape leader can miss hook the leader and it pulls through and just flaps around on the internal spool leaving the drive unable to accept any tapes and failing self test.
Re-thread the lape leader round the guides and past the head and hook the square hole in the leader back onto the plastic hook just in front of where the tape usually sits and power on the drive and see if it passes self test.
Although this is often just a damaged tape that causes this it can also suggest a faulty drive so dont use any important tapes in the unit till you are sure the drive isnt totally 100%
I have used www.tape-drive-repair.com who are pretty good for this kind of thing and not too expensive - if you need to send the drive away for repair / exchange
Posted on Aug 24, 2009
How do I get my Dell Powervault 120T DLT7000 tape drive out of 'service mode' ?
If the drive automatically ejects tapes every time they are loaded then the problem is probably a lost leader and in which case it will have to be opened up to fix.
Dec 27, 2010 | Dell PowerVault 120T DLT7000 DLT Tape...
How do you manualy eject a stuck tape from a Quantum DLT VS80 external tape drive
Hello, if it has an eject button, press it quickly several times (can't remember the exact number; try 3 first, then 5, then 7)the reason being that on earlier DLT's the firmware would cause a drive reset which would, if there wasn't a detached leader or other physical problem, result in a tape unload.
p.s. do let me know how you get on!
Regards,
nicam49
Dec 08, 2010 | Quantum DLT VS80 DLT Tape Drive
Dlt-v4, the drive accepts the tape only to spit it out
You have to try the other tape if the same problem you have to replace the head.
Feb 05, 2010 | Quantum DLT-V4 DLT Tape Drive
INSTRUCTIONS ANT 104
This is a very outdated post but, I have posted the installation guide here:
http://www.eserviceinfo.com/downloadsm/67093/Quantum_ANT-104.html
Jan 24, 2010 | Quantum DLT 4000 DLT Tape Drive
Fault and clean light come on together
Possible bad or wrong media type. You must be using DLTtape VS1 cartridges for write capability.
You also need to visually inspect the drive to make sure the leader is attached to the buckling arm. The "leader" is the ~10 piece of reinforced tape that is permanently attached to the take-up reel in the drive. It threads around the rollers, past the head, and is held in place by the buckling arm and is visable by using a flashlight and looking into the drive from the front. The leader tip is in the shape of a rounded arrowhead and is what physically hooks to the media in your VS1 cartridge. If the leader isn't there you'll need to send the drive into Quantum for repair.
If this is the case, you likely have a damaged piece of media in your pool that you must find, as this tape will cause the same "damage" on your next drive, causing the drive to "swallow the leader". Quantum has a Media Inspection PDF file on their site...use it, as it will save you time and $$$ the moment you find a single piece of "bad media".
As a side note, most media makers offer a Limited Lifetime Warranty and will replace bad media at no cost (other than shipping) to you.
Sep 07, 2009 | Quantum DLT-V4 DLT Tape Drive
On power up we get an 'E' during drive initialization
E stands for error (Although i am sure you could have guessed this)
Try to see if the drive at the back is passing self test or not so we know if it is a drive or loader issue
If it looks as if the drive is OK try cleaning the tape slots as there are sensors to sense tape loaded etc
Is the arm (and the main chassis) bent? this will also cause issues.
If it is a drive issue (Drive fails POST) then it is most likely a tape leader issue where the drives needs to be removed and the leader refitted (see other posts on here about DLT tape leader issues)
Aug 10, 2009 | ADIC FastStor DLT7000 DLT Tape Drive
Dlt tape drive left lights blinking, internal fault
This is a hardware fault with the drive (Quite common) The drive needs to be properly repaired (Main PCB Fault)
Send it to www.tape-drive-repair.com as they are quite good at this sort of thing and are not expensive
Mar 02, 2009 | Quantum DLT 4000 DLT Tape Drive
Tape eject from drive
Hi. This is from Dells site regarding automatic ejection of tape once inserted:
The PowerVault 110T DLT VS160 Tape drive reads and writes DLTtape VS1 cartridges. The PowerVault 110T DLT VS160 Tape drive can read - but not write - DLTtape™ IV cartridges written using the DLT1/VS80 format. NOTE: The PowerVault 110T DLT VS160 Tape drive automatically ejects any other cartridge types and any cartridges whose format it cannot read. Make sure all cartridges that you want to use for writing are DLTtape VS1 cartridges.
Perhaps your cartridge is improperly formatted or is of the incorrect type?
May 23, 2008 | Dell PowerVault 110T DLT VS160 DLT Tape...
Quantum DLT 4000 DLT Tape Drive Logo
353 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
