Question about CMS Products - 160GB 5400RPM HD DELL LATITUDE D610 SERIES 160 GB Hard Drive
Touchpad pointer moves by itself. Moves slowly to either the top right hand corner or the bottom left hand corner.
  • 3 Answers
I tried updating drivers, no help. I decided my particular wild mouse was a stick pointer hardware problem. Since I do not use the stick I decided to disconnect it electrically.
Here is what I did to tame the wild mouse cursor. Observe static protection practices. Basically touch table, tools and laptop at the same time and do not rub feet or anything. This procedure electrically isolates the stick pointer making it inoperative and renders it unable to interfere with the touchpad/mouse function. Read instructions completely prior to performing service.
1. Power down laptop.
2. Remove battery and wait five minutes.
3. Open laptop and lay screen all the way flat.
4. Find the 1/4 inch depression at top right of the base (the part that has the keyboard). With a small pry tool lift the plastic strip that houses the power, hard drive and battery status indicator and covers the top part of the case that has the power and sound buttons. Once loose on the right side, lift from right to lift to remove.
5. Remove two small screws that secure the keyboard.
6. Lift top of keyboard and gently flex the keyboard up in the center to dislodge from under the sides of the case.
7. Lift keyboard forward to dislodge from under the palm rest.
8. Lift connector straight up.
9. Insert an approximately 3/8 inch by 3/8 inch piece of plastic grocery bag over the contacts in the center of the right side of the connector on the main board. Position plastic such that it overhangs the side of the connector such that when the connector is reconnected it will remain in place and prevent electrical contact with the narrow stick pointer flex ribbon part of the connector.
10. Insert connector.
11. Reverse process to reassemble, taking care to insert keyboard under palm rest and flexing up in the center to insert under sides of case.
Posted on Sep 02, 2012
  • 21 Answers
This can be caused by fault in the touchpad or motherboard connector. Easiest fix is to disable the mouse in the touchpad software and use a USB mouse.
Posted on Jul 31, 2009
    Problem Solver:
  • 12 Answers
Sounds like their might be some dirt underneath the surface of the trackpad exerting pressure causing it to move. Try turning down the sensitivity, do this under mouse in Control Panel.
Posted on Jul 30, 2009
How do you disable or lock the touchpad on HP ProBook 6570b?
Hi there! The simplest way to turn On/Off your touchpad is by tapping the top left hand corner of your touchpad surface.
Mar 21, 2013 | HP ProBook 6570b laptop
Samsung laptop cursor tweeking
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 10, 2012 | Samsung SENS R460 LAPTOP LCD SCREEN 14.1"...
The cursor jumps around on my ASUS K501J notebook.
Step 1
Step 2
2. Select the "
Apply."
4. Pick the "
Step 3
Oct 08, 2012 | ASUS K50IJ Notebook
Tapping on gateway nv 53 trackpad not working
This just happened on my HP2730P. I always used the click on the touchpad, plus used the right click button at the bottom. Yesterday it just decided to stop working and went haywier...it started doing the selecting and dragging while I was moving the mouse around and my left click stopped working. Obviously my enable tap click was already on cuz I used it all the time.
My solution was disabling the buttons under the "buttons" tab. Then my mousepad tap started working again, I regained function in the scrollbar on the mousepad again, and if I need to right click I can use the point stick buttons right above the pad.
OR
Does it start working when you reboot? If so, try changing the "Touchpad Sensitivity" option :)
Jan 24, 2012 | Computers & Internet
My touchpad moves my pointer very slowly
Hi, try to find the mouse properties in the control panal under hardware then find the pointer options tab which should have a slider to control the pointer movement speed, select to desired speed and apply then give it a try... Best of Luck
Feb 04, 2011 | Computers & Internet
My cursor moves as i type what can i do
You seem to be brushing against the touch pad while you're typing. You need to adjust the sensitivity of that touch pad:
Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers." Select the "Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "Apply." Pick the "Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings." Read the information provided in the next dialog box. It gives you options for tapping your touchpad, using the buttons, scrolling, pointer motion and sensitivity. Make any changes you want from the various topics. When you make a change, click "Apply." Click "OK" when you finish making all your changes. Do some work on your computer for a while. If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Jan 01, 2011 | Computers & Internet
The cursor moves randomly while I use the trackball
this problem is caused by a defective mouse, replace it.
Sep 09, 2009 | Logitech Marble Mouse Trackball
Dell d600 mouse pointer jumps into corners if working on documents etc.; maybe if the system stores data in the cache or ram, the cursor wether jumps into the left down corner or moves slowly in directon...
What the issue is, is the eraser head mouse in the enter of the keyboard. When you type, it's putting uneccessary pressure on it, and it makes the pointer move. The only solution I know for this is to get the updated ALPS driver for the mouse, and disable the eraserhead (The updated driver gives you an option to do this), thereby using only the touchpad mouse.
Mar 15, 2009 | Dell Latitude D600 Notebook
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
CMS Products - 160GB 5400RPM HD DELL LATITUDE D610 SERIES 160 GB Hard Drive Logo
482 people viewed this question
Top CMS Computers & Internet Experts
Cosma Papouis
Cosma Papouis
xkikbxr
Dan Dunham
Are you a CMS Computer and Internet Expert? Answer questions, earn points and help others
