Question about Crafts & Hobbies
I have lionel 6-81269 Pennsylvania allegheny hauler Berkshire, the chuffing sound goes in and out. the chuffing sound cuts in and out when train is traveling down the track .
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
SOURCE: Need help setting up Lionel North Pole Central
I had the same dilema and trains are not new to me. Look under the piece of straight track that has a notch in it for the wiring. There will be a clip to hold the wire and a piece of plactic that looks like a block. One either side of that is a metal tab that one end of the wiring slides over. Actually each piece of the Fastrack has one of these. Only one has a notch but you can notch any one.
MHC
Posted on Dec 04, 2009
  • 4 Answers
SOURCE: Lionel Polar Express Berkshire Locomotive will only go in reverse
No doubt the transistor in the motor controller inside the engine is shorted TIP31C Q6 If you have the skills you can repair the unit. Parts are cheap, like 50 cents. Expense is shipping. Have repaired at least one that had the probblem you describe
good luck
Posted on Dec 23, 2009
SOURCE: WE are trying to get our lionel holiday train
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
Posted on Dec 27, 2009
  • 10 Answers
SOURCE: No longer have manual for
See link below to PDF file with instructions to your transformer. It looks like you are correct with regards to the wiring with what I can see in the manual.
Hope this helps and good luck
www.lionellines.com/files/manuals/KW_Manual.pdf
Posted on Aug 04, 2011
The value of a train set 1953 Locomotive 1130
A Lionel 1130 is a "Scout" type locomotive....they are not particularly valuable even to collectors. They were a part of the low end starter sets Lionel made. Now if you had a similar vintage 736 Berkshire or a 681 or 682 Turbine they are worth considerably more.
Aug 10, 2016 | Crafts & Hobbies
How to add water
Here's a link to Lionel Service Documents,,Owners Manual for you train.
http://www.lionel.com/media/servicedocuments/71-0018-250.pdf
Dec 02, 2012 | Lionel 6-30018 Pennsylvania Flyer Steam...
Chuffing sound when accelerating, not at idle
injector copper washer seal ,best ask a garage its not a easy job ,
Jun 27, 2017 | 1992 Mitsubishi Pajero
Instruction manual
Search the Internet, you may find a PDF file containing the manual. If all else fails, contact Lionel and request a manual.
Dec 08, 2011 | Lionel 'o/o27' 1645 4-4-2 Pennsylvania...
My train wont go in reverse
Try flipping the "Reverse" switch on the bottom rear of the locomotive.
Jan 03, 2011 | Lionel Pennsylvania Flyer Train Set
I bought the 6-30089 Pennsylvania Flyer Train Set last year. It's been in storage in the original box in a cool, dry place since last Christmas. I put it together, but it will not run. There is power to...
Hope you got the set working. If not, look underneath the locomotive near the rear (under the "cabin"). There are two switches, one on either side. One says "Smoke", the other says "Reverse". If the "Reverse" switch was set to "Off" when the locomotive was in Neutral, it will stay in neutral even when the power is cycled or the "Direction" button is pressed on the power supply. Even in Neutral, all the lights will work and I believe the smoke element will heat up but won't puff. Whatever setting the "Reverse" switch is on, try changing it to se if that works. Hope this helps...
Dec 04, 2010 | Lionel Pennsylvania Flyer Train Set
good luck
Dec 08, 2009 | Lionel The Polar Express Train Set
Crafts & Hobbies Logo
128 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
