Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Pressure builds to 20 lbs- and wont go any higher and motor runs
The pressure builds to 20 lbs and wont go any higher. THe motor continues to run after this and wont stop.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 32 Answers
Major leak or bad valves. Inlet valve is not sealing back off and pushing the air on the up stroke back out the breather.
Posted on Mar 03, 2016
    Champion:
  • 225 Answers
Sounds like the regulator is fualty.
Posted on Jul 30, 2009
Why does my pump loose pressure
Sounds like your not using enough water, and or your pipes to sprinkler is to to small, causing pump to build up to cut off head. I cant lay my hands on a performance chart for your pump, but 60 psi cut off and 20 on sounds about right. Try running another tap when your sprinkler is running, and see if this keeps your pump running
Mar 25, 2015 | Utilitech 1-HP Cast Iron Convertible Jet...
DeVilbiss air compressor will not build pressure
Does it have an intake air filter? Has the compressor been properly maintained? Oil less? It may have worn out rings and or valves
Aug 24, 2017 | Air Tools & Compressors
Compressor runs and sounds ok, but it only manages to show 20 lbs. It will not build air pressure and continues to run.
check air tank drain valve located on bottom of tank, if it is not leaking try adjusting air pres regulator (large black knob close to air hose connection.) the knob when turned in will increase the tank air pressure, if knob wont turn check that lock ring on bottom of knob to make sure it is disengaged. also check for air leaks in all lines and connections
Apr 16, 2012 | Craftsman 1 hp Air Compressor, 4 gal. -...
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a bostitch 6 gal pancake compressor that won't build pressure past about 20 lbs. when I turn it off I don't hear air leaking out anywhere and when it's running it runs at a higher pitch ( similar to...
I'd pull the cover off to expose top of cylinder head and have a look at any intake air filter. In parts diagram, It appears there is a small one that would likely clog during the texturing process.
Jan 26, 2011 | Stanley Bostitch CAP2060P 105 Amp...
Air pressure only builds up to 45 lbs. compressor continues to run. I drained all the air and it still only builds up to 45 lbs.
The check valve is not holding the pressure back off the head,therefore allowing the pressure to build up fully.
Jan 04, 2011 | Air Tools & Compressors
WILL NOT BUILD UP AIR PRESSURE PAST 20 LBS.
Check to see if air is leaking past 'pressure relief' valve. It's probably leaking and that's where all the air is going.
Sep 11, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My shallow well pump will not pump to 40 lbs pressure which is the shutoff setting. tHE MAXIMUM PRESSURE IS 30 lbs so the pump runs continuously. What is the problem ? Pump is Red Lion 1/2 hp series RJS,...
Installed new shallow well pump still only can get to 30 lbs pressure. when i turn pump off pressure drops to 20 lbs right away and stays there
Jun 17, 2009 | Plumbing
Wont build pressure over 25 psi after rebuild
sounds like the belt is slipping have you checked the inlet and discharge valves also could be bad and leaking or stuck or installed wrong
Feb 19, 2009 | Air Tools & Compressors
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
1,082 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
