Question about Crafts & Hobbies
I have a New Bright 1997 holiday train set and it just quit working a few years ago. No power. I even replaced the transformer with no luck. In both transformers I only measure about 2 volts coming out the two prongs. What am I missing? The on/off power button doesn’t do anything. I took the parts apart and all wires appear to be in tact. I measure the 2 volts across the tracks too. Thanks for any help!!
    New Friend:
    Problem Solver:
  • 7 Answers
Is the transformer getting hot? Sounds like there might be a short circuit in the system. You'd need to put an ohm meter across the tracks (or a Digital Multimeter (DMM) set to ohms) to verify the short and then look around for some electrical path between the tracks.
Posted on Jan 09, 2018
SOURCE: My new Lionel CW-80 trans former stopped working
I have had the same problem with my polar express, which i just bought recently. Having to send it to the USA from the UK would be very expensive so i decided to open it up myself. The tamper proof screws were a bit of a problem getting into it. I ground down an old screw driver into the triangle shape to undo them. I then replaced them with self taping srews the same size.
The Problem I found was simple, there is an internal (250V, 8Amp) fuse soldered onto the red wire on the secondary winding of the transformer. The red wire going from the transformer to the PCB, the fuse has black heatshrink over it.
There is no room inside the housing of the controller to fit a fuse holder. I fitted a box on the side of it with a panel mount fuse holder. drilled a hole through the housing, fitted longer red wires, so they could go through to the terminations on the back of the fuse holder.
At least now I can change it simply if it blows again.
hope this is of help to you.
Posted on Dec 08, 2008
SOURCE: lionel train won't reverse
there should be a switch under or in the cab section that turns off/on the reverse function.
Posted on Dec 25, 2008
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
  • 14 Answers
SOURCE: Where can I buy a track clip for my New Bright
http://www.newbright.com/
New Bright does not offer any replacement or repair parts for thier products.
They have a 60 day replacement warranty, but after that, you are on your own.
Posted on Dec 16, 2009
  • 3 Answers
SOURCE: hi having trouble with
Yes, additional track is available from several places, such as Hobbylinc.com, and TowerHobbies.com. At this time, just after Christmas, they are out of stock, however. Walthers.com has them in stock (1-4-2011). You can find extra track on sale on eBay, as well. Be sure to get the track with the brass covers, as New Bright sells battery powered trains that use bare plastic track, which will not work with the 384. A Google search will turn up more sources.
Posted on Jan 04, 2011
New Bright Holiday Express train No. 380 won't run or even light up
You need to fault find with a multimeter before guessing what to change.
Dec 22, 2017 | Televison & Video
New bright greatland holiday express train
Check the connection from the transformer to the track, and that all the track is well connected. Make sure nothing is touching both tracks, shorting them out.
Nov 25, 2013 | New Bright 384 Holiday Express Animated...
Hi having trouble with our new bright musical holiday station electric animated train set...very frustrating as one of the train tracks broke off a little part so no matter what my husband tries to do the...
Dec 12, 2010 | New Bright 384 Holiday Express Animated...
We are having difficulty turning on our New Bright Holiday Express Animated Train set. Husband and I have been trying to figure this out for our eager 2 little boys. The remote seems to turn (red light)...
Here are a couple of resources from New Bright:
http://www.newbright.com/public/electric-train-faq
http://www.newbright.com/images/Manuals/384%20ws%20manual.pdf
There is no On/Off switch on the train. Power goes from wall plug to transformer, then from transformer to track clip, which must be attached to the track. A control line goes from the track clip to the controller. Mine has a green light just above the red On/Off button that will come on even if the engine and tender are not on the track. The tender does all the work, and must be connected to the engine and on the track. There are four sliding contacts between the tender wheels that provide contact with the track.
Dec 09, 2010 | New Bright Small Holiday Express Train
Each yr my New Bright Holiday Express train gets slower and slower the longer it runs. Finally it just stops. Every thing else seems to work: lights, etc.Train shop specialist say its the engine, not the...
check the electrical current to the trans former , then check the out put from transformer, may not be getting adequate electricity flow to operate , and if you continue to operate under required current , it may damage engine and or transformer , gd luck
Nov 23, 2017 | New Bright Small Holiday Express Train
Need train transformer model #APX663004
mcdevito75 here, Contact New Bright online at www.newbright.com for the transformer. Hope this helps. I didn"t see a telephone number at the site. Sorry.
Jul 13, 2010 | New Bright 384 Holiday Express Animated...
Holiday Express Train Set
We struggled with this just today...finally figured out that you have to twist the small piece right behind the bell on the top of the locomotive.
Dec 18, 2009 | New Bright Small Holiday Express Train
I have a Newbright Musical Holiday Station Electric Animated set No. 385. Everyt car on the train lights up but we can't get the train to move or take any of the commands from the control panel. What could...
Check to make sure you have the large plug from the tender car to the loco plugged in correctly and secure. The tender car supplies power to the loco and if that cable is not connected the train will not run.
Dec 15, 2009 | New Bright 384 Holiday Express Animated...
I have a new bright animated holiday train from a garage sale and I think I am missing a power cord
You should have a 3 pieces to provide power....
1. A track connector box. Looks like a "T". It slips under the track to make the track power connection. The transformer plugs into it (2 pin Molex type connector) and the command console (has an RJ11 telephone jack type connector on it)
2. A large square transformer. One end plugs into the wall and the other into the track connetor box.
3. The Command Console. Has the on/off button, forward, reverse, mute, sounds and speed contol on it .. has a connector that looks like a telephone plug.
Unfortunately... DO NOT look to New Bright for missing or non working parts. New Bright does not offer repair or replacement parts for thier products. :-( ....
Dec 10, 2009 | New Bright 384 Holiday Express Animated...
Nov 28, 2009 | New Bright 384 Holiday Express Animated...
Crafts & Hobbies Logo
163 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
