Question about Samsung SCH-u740 Cellular Phone
When i turn the phone on the vcast loading screen shows up and loads but never goes past that and it just trys again and again
My phone just blinks vcast now
I work for verizon-take your phone to a verizon store, have them swap it out for a new one. If your phone is under warranty you should be able to swap it out for a new one. If you are in contract the WARRANTY IS GOOD FOR THE LIFE OF THE CONTRACT. Call our Customer care line, don't go back to the store.
Mar 31, 2009 | Samsung SCH-u740 Cellular Phone
My phone got wet and now its just blinking!
water and electronics do not mix as it is now 2017 why will they not give you new phone at the right price
Apr 24, 2017 | Samsung SCH-u740 Cellular Phone
My Samsung SCH-u540 keeps turning on and then shutting off
Sounds like you have a defective battery. If you can use the phone normally with the charger plugged into it that is more than likely the problem. Step one is order a new battery. If that don't solve the problem take it into the store, but only if it's under warranty, otherwise shop for a new one.
Feb 09, 2009 | Samsung SCH-u540 Cellular Phone
Lg EnV VX9900 CLR Button Resets phone.
When you hit the clr button it will go back to the screen you where prior. When your booting up, it will show the Vcast screen. Maybe check your backlight setting.
Jan 17, 2009 | LG enV VX9900 Cellular Phone
My samsung SCH-i730 is stuck on the white loading screen
You may have to do a major reset on it. First remove and replace the battery and turn it on again. If that doesn't fix it, there is a tiny reset button on the bottom near the connector. You will need to push it in with a small point such as a paper clip wire.
Jan 03, 2009 | Samsung SCH-i730 Pocket PC
Phone had water damage now it won't work
If you can open the casing ,using a hair dryer on low heat ,fully dry the inside circuit board.Then try it.
PLEASE RATE THIS THANK YOU !
Jun 09, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Get pictures and video off phone to the computer
Preparation ? if an external Micro SD external memory card is to be used as the desired music/video/picture repository on the W755, install the card in the W755 behind the battery. Then go to SETTINGS & TOOLS ? MEMORY ? CARD MEMORY ? FORMAT and format the new card. Caution: reformatting the card will wipe out all contents on the SD card. Download/install free Motorolla Handset USB Driver Installer onto the PC (execute ?.msi? file). Download/install free VCast/Rhapsody software (no need to actually sign in or use the proprietary Rhapsody service). Start the VCast/Rhapsody software. Turn on cell phone (works with W755 and may work with other Verizon ?music phones? such as LG Chocolate, but the latter was not tested). Connect phone to PC ? connect USB cable to PC?s USB port first, then connect USB cable to phone . Be patient, it may take a minute to fully ?connect? in the phone?s display. Go to ?Sources? section of VCast/Rhapsody GUI screen ? the phone will register as a directory title using a name roughly like ?VCast xxx.? Windows Explorer will also show a ?VCast? drive/directory device. Files can be selected and dragged to and from source and target directories. At this point various options exist regarding music, picture, video management: 1.) The VCast/Rhapody software can be used to manage music, picture, and videos between the PC and phone. Again, no need to use the VCast service, just the software offline. 2.) Alternatively, other music management software such as Media Monkey (a personal favorite) can be used to move music, create playlists, etc. ? NOTE: Leave VCast/Rhapsody software running in the background as a means to ?connect.? It is best to start VCast, then plug in phone, then start other media management software so that the media management software will benefit from the connection (usually with a directory name using some variation of ?VCast.? Then use the alternative media management software as usual. Please note, this is a generalization based on success using basic software like Media Monkey, for example.
Apr 26, 2008 | Motorola Cell Phones
Need Help with Verizon LG VX8100 VCAST Memory
try eerasing some of the messages that are not needed aswell that may free up the mem.
Jun 18, 2007 | LG VX8100 Cellular Phone
Samsung SCH-u740 Cellular Phone Logo
314 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
