Question about Vacuums
Cleaned out hoses and now it has no suction and the dirt comes back out at the bottom
  • 44 Answers
Check out filter in vacuum ,if full of scruff, the vacuum will have no suction.regards
Posted on Jul 29, 2009
My dirt devil cyclonic upright has suction on bottom but not in cleaning wand
Take the hose off where it goes in to the vacuum and see if there is something lodged in the opening where the hose fits in to.
Mar 18, 2018 | Dirt Devil Vacuums
It's blowing dirt out the bottom/back
this is caused by a plugged up suction hose AND / OR a dirty filter.
clean the filter - and remove the bottom floor plate and clean out the hose where it bends down to the floor unit ( this is always where the dirt collects when the filter gets dirty and suction is low ).
c...
Feb 22, 2011 | Bissell 6594 PowerForce Bagless Upright...
No suction coming from the bottom of the vacuum
9 times out of 10 there is a hose blockage at the point where the hose bends down to the floor. remove the suction hose and clean and clear any dirt build up inside the hose. also at this point it is a good idea to clean the filter. ( remove and brush out or use a air compressor to blow filter clean ).
c...
Dec 31, 2010 | Vacuums
I have Bissell Powerforce Bagless Upright Vacuum. it doesn't suction well. I checked the belt. It is ok. may be clog in the hose.I don't no how to clean. can you help me please?
- Check the dirt cup to make sure it is empty.
- Your vacuum has 3 filters. Dirty filters will restrict air flow. The filters may be hand washed in cold water with mild detergent. Allow them to completely dry prior to reinstalling them. The white HEPA media post-motor filter is not washable.
- Lift the upholstery hose from the bottom holder. Check for suction at the end of the hose.
If there IS good suction at the end of the hose, please unplug your machine from the outlet and try the following:
- Ensure the hose is firmly pressed into the lower hose outlet on the back of the vacuum.
- Check to ensure the brush is rotating. If it is not, remove the plate on the bottom of the vacuum. Check the belt and clean the roller of dirt and debris.
- Check the lower hose for clogs by removing the screw which attaches it and lifting the hose up to clean it out. Also, remove the larger hose by twisting it off and using a broomstick handle, push any dirt and debris through the hose.
Aug 05, 2010 | Bissell Vacuums
No suction
Check the main filter cone - if it has a rip in it, then there won't be any suction in it, also clean it gently with a paint brush to get all of the dust out and check the back of the upright after the bin is taken out as sometimes there is dirt clogged at the back. Check the front of the sole plate i.e. where the roller brush is and check the dust channel behind this as it can get clogged. Due to the nature of this vacuum with the hose being located at the front of the floor head dirt can be trapped but most of all its the paper pleated cone filter that needs a good brushing. Hope that helps.
Feb 25, 2009 | Dirt Devil Featherlight Bagless Upright...
Vacuum hose has little suction.
There is most likely a clog in the hose. If the hose has poor suction the foot probably has poor suction as well seeing that the hose is what gives the foot assy suction.
Jan 05, 2009 | Bissell 6594 PowerForce Bagless Upright...
I have a Dirt Devil Vision and when I put a clean canister back in place the suction at the bottom of the filter clogs up and very rarely go into the canister. Also where the air blows out of the motor, I...
yes your intake hose is clogged thats the clear hose you can see it on the bottom from the back.disconnect the upper hose from your intake hose and try to push a coat hanger through with the end of the coat hangers end bent till its rounded so you don't puncture the intake hose
Jan 05, 2009 | Dirt Devil M086700 Vision Bagless Upright...
No suction
check the belt or the inside tube between the bag and the brush
Aug 11, 2008 | Dirt Devil M086700 Vision Bagless Upright...
Suction problem
sounds like you have a leak in the suction path
look for a broken hose or seal
May 21, 2007 | Dirt Devil M086700 Vision Bagless Upright...
Vacuums Logo
82 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
