Question about Crafts & Hobbies
I have an old lionel santa fe special train. It won't go in reverse and it goes forward way too fast, even when I barely turn the toggle. Any suggestions?
  • 35 Answers
SOURCE: Lionel Train transformer goes full throttle only
Sounds like the "variable resistor" that allows for a variable speed is either defective, or has become corroded on it's switch contacts. You might get lucky with some electrical contact cleaner spray and spraying it in or around the variable speed switch. Otherwise, I'd just invest in a new transformer.
Posted on Dec 16, 2011
cansmo
  • 2431 Answers
SOURCE: 2001 hyundai santa fe starts with one crank but won't go into drive or reverse, only goes into park and neutural what could be the problem? i have a 2001 hyundai santa fe 2.7 l v6 all wheel drive
You do have drive and reverse,if you have park and neutral.It just the transmission cant transfer that power a new or rebuilt is the solution
Posted on Mar 20, 2012
adamfjeld
  • 1508 Answers
SOURCE: peg perego train only goes backwards, but doesnt have a reverse and forward button. please help
funny, you can fix this real easily, you just need to flip flop the cables on the motor, currently the polarity is reversed, theres only two wires connected to the motor just switch them around
Posted on Apr 30, 2012
adamfjeld
  • 1508 Answers
SOURCE: batter for Santa fe peg perego train needed
i can get you original one from manufacture if you still need one
Posted on May 22, 2012
residentoccu
  • 161 Answers
SOURCE: lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Posted on Feb 15, 2013
How to replace the front light on a lione santa fe train engine
From the Lionel User Guide for this engine.
it forward to release the two rear clips from the frame slots.
2. To remove the lamp, gently push the lamp down and turn counter clockwise to disengage
the lamp from the socket. Refer to Figure 6.
3. Replace the expired lamp with Lionel part no. 600-0363-300, available from your local
Lionel Authorized Service Center or Lionel Service. (For more information, see Lionel
Service on page 12.)
4. To reinstall the shell, first insert the rear tabs on the body into the slots on the frame. Line
up the screw holes on the frame and body shell, and reinsert the screw. Make sure all of the wires are inside the body before you tighten the screw.
This is a 14V bulb
This
Mar 14, 2014 | Lionel Santa Fe Diesel Locomotive Engine...
Lionel f7 only runs in reverse
Have you checked to see if the direction switch is on? Most Lionel locomotives can be set to run in one direction by turning the direction sequencing off. This is true for the newer electronic direction circuits and the older electromechanical E-units. Sometimes the direction units fail and the locomotive will only go in one direction or sits in neutral. If that is the case, the direction unit will need to be serviced (mechanical type) or replaced (electronic type). Go to Lionel.com for additional information and help.
Mar 03, 2014 | Lionel Trains Santa Fe Flyer Freight Train...
Peg perego train only goes backwards. no switch. only button.
does this have a special battery that is wired to plug into the train-if it is,are the wires the same colors as in the battery you just replaced-they should be color coded- to switch the wires, cut them on the battery side of the plug switch them-you can get an automotive wire splicing kit at a parts store like autozone,that you can make the connections with -cheers Denny
Nov 15, 2013 | Peg Perego Santa Fe Express Ride On Train
Lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
Hope this helps.
Jan 05, 2013 | Lionel New Haven Freight Train Set
My f3 santa fe only runs in reverse with my 1033 tranformer
try reversing your wires from the transformer to the track.
Dec 29, 2012 | Lionel New Haven Freight Train Set
Peg perego train only goes backwards, but doesnt have a reverse and forward button. please help
Apr 19, 2012 | Peg Perego Santa Fe Express Ride On Train
Mar 20, 2012 | 2001 Hyundai Santa Fe
My brand new Sante Fe "O" guage quit running in the forward direction after about 15 minutes on Christmas Eve. I took it to the dealer and was treated rudely by the repair person. I was accused...
If sounds like something is wrong with circuit board that controls direction. If it is new it should still under warranty. Find a decent repair shop from Lionel and bring it in.
Feb 01, 2011 | Lionel Santa Fe Diesel Locomotive Engine...
Train runs in reverse and not forward...Jumped motor, runs o.k both ways..Switched the switches and still nothing in forward...?
this train is only supposed to go one direction, if its currently going in reverse just switch the wires on the motor
Oct 03, 2010 | Peg Perego Santa Fe Express Ride On Train
Crafts & Hobbies Logo
104 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
