Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Panasonic i have a panasonic rear project 43 inch an it displays a message air filter need cleaning will turn off after 1 minute any sugestions the tv shows fine on this problem
  • kikischaffer Dec 30, 2007
    we have the same problem but cannot locate the filter - dont' want to force anything....any thoughts or luck?
Here is your $75 service fee for free:
My Panasonic PT-52LCX16 from Costco (July 2006) showed the On Screen Display: Air Filter needs cleaning and the TV will shut down in 1 minute.
After searching the web for hours and amazed that I could not find the solution, I call the local Panasonic repair shop and Matt came out on the service call.
Matt has been doing this for twenty years and I was getting some on-the-job training because I was ticked that I could not fix this myself.
Here is your information you wanted:
Turn your TV OFF
1. Remove the grill cover in front. Gently pull on the sides and then the middle and the grill should come out.
2. You will see a door with a round door knob (this door is for the lamp), turn the knob and the door will remove.
Put the door back on and turn the knob
This will clear your On Screen Display message when you turn your TV back on.
Note 1: There is NO Air Filter on this model!
Note 2: If you do NOT put the door back on and yurn the knob you can not turn yout TV back on. Good safety feature!
Note 3: There is a firmware revision that you can download on an SD disk and place this into the TV and it should update the TV to show ??????
Matt told me it should give you a warning that you need to replace your LAMP.
Note 4: This model does NOT have a menu to see how many hours are on the lamp and how many times the TV has been turned on/off.
I have not replaced the lamp yet and I have not updated the firmware. My plans are to order a new lamp (this lamp is # TY-LA1001, $233 - $275), replace the lamp and then update the firmware.
Matt told me what usually goes out is the Light Engine and that's about $1000 with the service call. Buy a new TV at that price.
I did not by the extended warrenty on this TV and Matt said if your TV costs more than $2500 or more he would recommed it because some parts are just cost so much and your are out of luck when some thing goes out.
Shane in Keizer, Oregon
Posted on Dec 26, 2007
  • shanewyer Dec 26, 2007
    Sorry, I missed the spell check button! Doh!
Replace with a new aire filter or clean the air filter
Posted on Dec 16, 2007
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000 > ... > Projector Accessories > Lamps, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
Clean filter message reset
the filter will need to be cleaned and if the set still shuts down then I would suspect the fan may need to be cleaned and possibly replaced.
Aug 07, 2012 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic rear projection tv air filter
heres what you do remove front panel "little black door below the screen" get some software cleaner "air" clean all in that box that you just removed the cover from also you might try cue tips and alcohol let dry thoroughly put cover back on and turn on tv it should work if the message comes on again turn the power on and off about 6-10 times and turn back on it should turn on and be fine .if that happens again just open the cover and blow with sopftware clean.sound wierd but after alot of experimenting i fixed my tv that i bought as a salvage because of that error message bhope it works
Feb 19, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Temp light flashing and air filter message
there are 2 cooling fans one or both of them may need replaced,
Jan 20, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Air filter dirty
It means the Fan is dirty clean off dirt so fan can run,or fan might be bad. More then likely fan has alot of Dust Bunnys.
Dec 01, 2008 | Panasonic PT-43LC14 43" Rear Projection...
OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Sep 28, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Reset lamp meter on Panasonic PT-43LC14 television
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
Jun 03, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
302 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
