Question about T-Mobile Sidekick ID Cellular Phone
The colors on the screen are all inverted and i dont know why.
    President:
  • 625 Answers
The lcd cable on your phone may be coming loose. You can try the procedure at the link below and reseat it.
Failing that, a new screen will do the trick.
Reseat LCD Cable on Sidekick
Search ebay for sidekick id lcd. There seems to be some in the store.
Posted on Jul 29, 2009
Vizio p50hdtv10a Has inverted colors wen you turn the TV on, the image shows like the colors have been inverted, the picture looks like a negative. Havent cracked the case yet, would like to know where to...
may be a faulty lead to the screen driver or the screen drive has a fault. would need to check the cables to the screen driver board on the back of the screen
Oct 01, 2013 | Vizio P50HDTV10A 50 in. Plasma HDTV
I changed my fonts and colors and I don't know how I did it? Now I would like my original screen back Help please?
You may have inverted the colors from the accessibilty menu. Try and turning it off by doing the following:
  1. Launch the Settings app from the Home screen of your iPhone or iPad.
  2. Tap on General.
  3. Now scroll down and tap on Accessibility.
  4. You'll see an option for Invert Colors in the first set of options. Toggle the switch to the OFF position.
Hope that helps!
Sep 04, 2013 | Apple iPhone 3G
VERTICAL HOLD CONDENSED TO SINGLE LINE IN MIDDLE OF SCREEN.USED TO ROCK IT TO GET FULL SCREEN,BUT THAT NO LONGER WORKS. I KNOW THE CHIP IS LOOSE BUT I DONT KNOW WHERE IT IS SO I CAN REPLACE IT.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP IN SOLVING THE PROBLEM...
Nov 02, 2010 | Televison & Video
I have a HP pavillion dv6 that I've had for about a year and just today while working online the screen suddenly changed colors. It's not inverted but some black colors are a solid red, some whites have...
ASAP (and the caps are intentional) get your laptop connected to an external monitor. If the display is fine on the "big screen", it's most likely you only have a screen inverter/lcd failure. Failing Inverters can cause the effect you're seeing as well as an LCD burn out on the way.
If the displays are identical, then your video card is about to fail.
At least you'll know, and know right away.
Best Regards,
Marcus (laptop specialist)
Sep 27, 2010 | HP 510 Notebook
Thinkpad screen colors Inverted/Distorted in 256 color mode
not a epert just trying to help,, i dont know what windows you are using xp or higher will not work good with that low of color,, hope this help you
Feb 25, 2010 | IBM ThinkPad T43 Notebook
Inverted Colors When Laptop Screen is Moved
hi
you are absolutely right.
there are basically two connections.
  1. at the motherboard end.
  2. at the display end.
any of the connector may be malfunctioning.
i ll suggest you not to open it yourself if you dont have prior experience in it.
while it wont take much to repair its not a costly affair.
if your system is under warranty it can be repaired for free.
if you find the solution helpful plz rate me carefully.
thnx
Jul 02, 2009 | HP 510 Notebook
Red lines on black color area
Its probably the inverter. its a device that powers lcd screen's. ebay the model # and include inverter. it will give you a ballpark number to work with
Feb 03, 2009 | Dell Inspiron 1100 Notebook
Inspiron 1521 green screen problem
Either the lcd cable is loose on the inverter board, the lcd cable is going bad, or the inverter is going bad. Usually this can be fixed by removing the power button bezel and making sure all the cables are seated properly on their connection. Removing the power button bezel varies from laptop to laptop, sometimes there are screws on the bottom of the laptop that you need to remove and sometimes there are not, it just snaps into place.
Thanks and please take a moment to rate as fixya.
Nov 25, 2008 | Toshiba Tecra 8000 Notebook
The LCD cable or the cable to the Inverter board may have come loose.
Here is a site that will show you in pictures what the LCD cable connections look like. The site also has Laptop repair hints:
http://www.laptoprepair101.com/laptop/category/lcd-screen-repair/
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 22, 2008 | Computers & Internet
Acer LCD fault
Definetly not an inverter issue. you would do well to replace the screen.
Mar 28, 2007 | Acer Aspire 1800 Notebook
T-Mobile Sidekick ID Cellular Phone Logo
128 people viewed this question
Top T-Mobile Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
