-   I have the same problem, my Enter key came off. But my clip cameapart
in 2 parts when I tried to fix it. Does anyone know where Ican see
pictures so I know what I'm doing?
-   tracydawe
Apr 22, 2009
-   Thank you, pipster27!
-   Guest
Sep 17, 2008
-   i dun all tha but it still nt clicked bk on prop it rised abit 1 side-   Guest
you need to take the white/see through connections off of the bottom of the key, they will unhook and should just clip off, they should open and close slightly to make a X shape from the side view to connect it correctly. On the computer place the smallest connection at the top first, it should hook under a metal clip on thecomputer and then the longer one connects at the bottom, just press it down and it will clip in. Put the black spacer in the middle of the connection on the circular pcb bit. You should then press the key onto it, it will just clip into place.
Yesterday my NEW acer d250 laptop was working fine today it only works if itsd plugged in ive tried...
(More)
Yesterday my NEW acer d250 laptop was working fine today it only works if itsd plugged in ive tried taking the battery out and seeing if it would charge but it doesnt and it stays on 0% even if it is charging a little bit about the batttery Battery Name:BCL3100LiON Unique ID:Compal BCL3100LiON Chemistry:Lion Power State:online Manufacturer:Compal
My acer d250 laptop is new it was great yesterday today it only works if the charger is plugged in...
(More)
My acer d250 laptop is new it was great yesterday today it only works if the charger is plugged in nd it doesnt even charge it stays on 0% ive tried taking the battery out but it still wont turn on
