Question about Nikon Lite-Touch 130 ED Film Camera
I can't turn off my Nikon 130ED film camera.
I just bought a Nikon 130ED film camera. I've now put a battery in it and don't seem to be able to turn it off even when I have closed the lens cover. Is there a light sensor behind the cover that turns the camera off when closed. Could this be broken?
Pull the plug
Posted on Jul 30, 2009
How do i remove film from nikon lite zoom ed 130
First rewind film in canster then when you hear the click you are finished rewinding the pull up on left winder knob this will open the door keep holing up and let fil drop out walla you're done.
Oct 01, 2013 | Nikon Lite Touch Zoom 130ed 35mm Film...
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
Nikon f80 is dead
Dead circuit - return to seller and get refund
Dec 11, 2012 | Nikon F80 35mm Film Camera
I've got Nikon F65. I cannot load film. The motor which load up the film doesn't move at all. Please help!
I don't know this model but you can try this.Drop the film canister in and pull the film strip out and place on the film advance sprocket.Rotate the sprocket by hand/thumb until film is seated (1 turn). If the auto feed is working you will be OK. 2 other things ,1 of course load film in dark area, 2 check the batteries on the camera first, if they are week your film advance wont work ,Good Luck.
Jul 29, 2011 | Nikon Photography
Nikon Coolpix L110 camera was bought for me for Christmas 2010. Worked fine at first, but now seems to be having problems. Batteries don't last. I just bought new batteries in Feb/March this year...
You have to charge the batteries for nearly 8-10 hours. Brand new batteries also require a full recharge of 8-10 hours.Not only making sure the batteries are charged, have you changed the battery in the menu under type of batteries.
Download this manual :
http://www.nikonusa.com/pdf/manuals/noprint/L110_ENnoprint.pdf and go to page #114
Buy EN-MH2-B4/MH-73 Kit (4 Rechargeable Batteries + Charger)
Jun 14, 2011 | Nikon Coolpix L110 Digital Camera
Hi i recently bought a used F3/T. Just ran a 36 exp roll and everything seemed to work fine. However i realized on loading a new roll, that the film counter did not reset. It remains at frame 37. How can i...
This won\'t be easy for you if you don\'t the proper tools, You have to remove the wind lever assy, and the speed dial, Then wind side top cover, Then pull wind base plate assy, And check counter reset lever, to make sure spring didn\'t come loose, Putting the baseplate back on can be fun because of linkage to the wind assy
Sep 29, 2010 | Nikon F3HP 35mm SLR Camera
I have a half way through film in my Nikon F80 and I have changed the batteries. At first it wouldn't go on, there would be the error sign blinking after turning it on. I turned it on and off several times...
You can force your camera to rewind, but you will have a partially shot roll of film. If you continue to shoot your counter will be off but when the film cannot advance any more the camera will rewind.
Jul 27, 2010 | Nikon F80 35mm Film Camera
The camera won't turn on.
With these batteries not working in two cameras I would check the batteries with a battery tester. One could be low and it does not take much below two-thirds to cause a camera not to operate. Also, in the camera with the acid that acid can creep into the internals of the camera where you and I cannot get to. It would be best to send it to Nikon for a CLS. You may call Nikon Film 1-800-645-6687 as well.
Mar 27, 2010 | Nikon F100 35mm SLR Camera
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
Nikon Lite-Touch 130 ED Film Camera Logo
76 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
