Question about Brother Sewing Machines
Threading the bobbin
Have a Brother LS 2125. How do thread the bobbin?
  • Brother Master
  • 12,730 Answers
Search for:
Make Model threading
Posted on Nov 25, 2017
    Top Expert:
  • Brother Master
  • 8,503 Answers
Hi Sharon.
not sure if this will help you out because its saying its for the, ls 2125i.. but try this step by step link.
How to Thread Brother Ls 2125i Sewing Machine
or this youtube video link.
How To Thread Bobbin on Brother LS 2125 Sewing Machine
this link might be the best one for you to watch.when you go to this one scroll down the page a bit and you will see where you can watch the video,
How to Thread bobbin on the Brother LS 2125 sewing machine
SOURCE:
SOURCE: brother ls-2125 how to thread
all manuals for a brother sewing machine are downloadable at www.brother-usa.com
Posted on Jun 12, 2008
bilabon
  • 46 Answers
SOURCE: Threading the Bobbin
Place the bobbin in the bobbin case making sure the thread feeds clockwise. Draw the thread through the slot on the case. Continue to draw under the tension spring and through the opening pulling out about 6" of thread. Hold the latch open, position the bobbin case into the suttle and release the latch. THe case should lock into place when the latch is relaeased.
With the top thread, hold out about 5" to the left. While holding on tot he top thread, turn the hand wheel toward you and you should see a loop at the feed dogs. grab the two thread and bring them behind the presser foot.
Bonnie
Posted on Sep 02, 2008
SOURCE: Need help threading machine
I have the same problem
Posted on Sep 21, 2008
  • 323 Answers
SOURCE: threading lower bobbin
There are some different bobbin cases for different machines but the one you have is a pretty common one with a finger sticking out on top. If you examine the bobbin case you will see a slot on the side of it and there is another piece of metal screwed onto it. This is the tension they are describing.
To thread it properly, turn the bobbincase upside down and insert the bobbin in the case so you can see it. Place your thumb on top of the bobbin and pull the thread through the slot on the side of the case and under the piece of metal(the lower tension) which I described to you earlier.. When you have done that, remove your thumb from the bobbin and pull on the thread. It should have some tension on it.
Next,placing a thumb or finger on the bobbin to keep it from falling out, turn the bobbin case over.
Keeping the finger sticking up lift the lever on the
front of the case and insert the bobbin and bobbin case onto the spindle inside the hook assembly(The part that is in the bottom of the machine that turns when the hand wheel is turned.) Don't worry about the thread that is sticking out.
Holding the upper thread under the presser foot ,turn the handwheel towards you until the top thread pulls the lower thread to the top. Pull the thread to the left of the machine, insert your fabric, lower the presser foot and begin sewing
One more thing , The finger sticking up on the bobbin case will go into a slot on the ring holding the hook inside the machine.
Hope this solves your problem.
Be sure you thread the upper part properly. It should go through the tension, then the take up lever and then the needle. Tension should be set at around 5
sewman7
Posted on Jan 17, 2009
Mimito7
  • 130 Answers
SOURCE: bobbin case on brother sewing machine
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
Posted on May 29, 2009
After setting the bobbin directions correctly, the bobbin will not thread. I get no movement from the bobbin or thread at all ???
You must redo your threading, something is not right. Are you going by what the book says? If so, then call Brother at 1-877-276-8437 and they will tell you if there is something mechanically wrong with your machine. They will walk you through all of the steps. Good luck
Oct 04, 2010 | Brother LS-2125 Mechanical Sewing Machine
HI, I haven't used the brother 2125 sewing machine for months. There was no stiches coming out after I started it this morning. I tried many times. The motor is fine, threads from up and the bottom are...
Totally rethread your machine and insert a new needle, you may have a bent needle. Your thread may be tangled, and your bobbin may not be inserted right. If, you don't have your manual go to brother-usa.com and download a manual for free. It should answer all of your questions
Sep 12, 2010 | Brother LS-2125 Mechanical Sewing Machine
Drawing up the lower thread
Check the needle to be sure it is installed with the flat side to the back of the sewing machine.
Mar 03, 2010 | Brother LS-2125 Mechanical Sewing Machine
Thread loopy on top
General rule of thumb::
loops on the bottom, problem on the top.
loops on the top, problem on the bottom.
It sounds like your bobbin thread is not thru the little tensioner in the bobbin compartment.
May 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
May 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bobbin holder keeps catchin thread
Try re-threading, make sure the presser lifer is up so the tension discs are open and the thread will go into them. It sounds like you may have missed either the upper tension discs or the take up lever.
A drop of oil on the hook wouldn't hurt if you haven't oiled in awhile.
good luck!
Jan 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
Need help catching the bobbin...not able to stitch
go back and check to see if the needle is inserted properly. I have had this problem on other machines and have found that this is a cure for some. i just got in a hurry and put it in wrong(most times the flat side of the needle goes towards the back).
May 06, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
107 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
