KDS Valiant 6380iPTD-01 Notebook Logo
Posted on Jul 29, 2009
NO hot water
Time switch 120 boiler , we have no hot water . it reads F33
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Aug 01, 2009
Anonymous
Contributor
Level 1:
Answers
32
Questions
0
Helped
6439
Points
65
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
33
K2-120 boiler shuts down on waer flow sensor. what should i look for
Unless you are licensed to work on or repair boilers call a professional. You will spend more in time and money trying to fix it, and finding a supply house that will sell you boiler parts. You could seriously injure yourself or someone else, boilers run very hot and are rated a pounds steam which is dependent upon boiler pressure.
tip
Combi Boilers Waste Energy
Combination boilers are called just that because they combine your hot water production and your space heating together with one boiler. The problem lies in the way that they produce hot water. To make the water hot, these boilers have a coil inside the chamber that the water for the space heating is held. The heat is transferred through the copper coil wall from the one water to the other.
The heat transfer of the efficiency of the transfer is not the problem. The problem is that you have to keep the boiler hot all of the time to make sure that you will have heat to make the water hot when you need it. To compound the problem you will find that boilers are typically very poorly insulated. The amount of heat that you will lose because of this poor insulation is unbelievable.
You have or are thinking about buying a Combi Boiler. Read this first because I will explain to you why you either have or are going to make a very big mistake.
Rather than go with this method of water heating, set up your boiler with a separate zone for an indirect water heater. Indirect hot water heaters transfer heat just as effectively, and they are usually very well insulated. The temperature drop in these indirect tanks is typically less than 1 degree F per hour. That’s not very much!
Keep in mind that even though this setup may cost you a bit more up front, that in the long run you will be saving more everyday. With the price of heating fuels going up daily you can bet that the indirect tank will pay for its self in a very short period of time.
on Dec 24, 2009 • Heating & Cooling
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
My boiler heating is working but hot water is not coming. i want to know how to set hot water 24 hours 7 days
As I understand your question, you have a boiler with a 'summer/winter' hookup for domestic hot water.
Your boiler should run all the time, i.e. not be shut off by you. Your boiler provides hot water for baseboard heat in your home ... possibly through several 'zones' each controlled by an individual thermostat and circulator. Yours may be a steam system. If this is the case, you have radiators not radiant baseboard heaters and no circulators.
Your summer/winter hookup provides a constant supply of domestic hot water. It does this by taking cold water from your water main and passing it through a copper coil which sits inside your boiler and then to your hot water main in your home. Since the coil sits in the hot water at the top of the boiler, it is constantly being heated. This coil may be in a deteriorated condition in your case or it may be too small for your needs.
Several years ago, I did a small upgrade to my mid 1950's era American Standard boiler. The summer winter hookup in my case was mounted on a 4 inch cast iron boiler plug. The coil was 12 feet long (folded up to a package about 1 foot long). I was very afraid when the plumber came in with what amounted to a 10 foot long pipe wrench. My fear was I would have a pile of broken cast iron at the end of the day. All is well that ends well. He got the old one out and replaced it with a coil that consisted of 20 feet of copper tubing 3/4 inch in size (the folded tubing was about 20 inches long and fit nicely into the boiler). We now have all the hot water a household consisting of one guy and three gals would need in all but the extremest of times..
I think you r answer is here ... replace your summer/winter coil with a new, bigger coil.
Something else I did. My kitchen is 60 feet (pipe wise) from the boiler. It takes a long time to get hot water there. I put in a small electric hot water heater just under the kitchen. I put a timer on it so it runs for a couple hours in the morning and a few hours in the afternoon. The hot water line from the boiler serves as the cold water input to the heater. I now enjoy the convenience of quick hot water in the kitchen with the relatively low cost of oil heated water from the boiler as a relatively small cost of electricity.
My winter settings are 160 - 200 and my summer settings are 120 - 150 which seems adequate for our needs.
Thanks for your question at FixYa.com. I hope I have been of assistance to you today.
HI IAM A ELECTRICIAN WORKING ON A LAAR HOT WATER BOILER WITH A STORAGE TANK THE TEMP IS SET TO 160 THE HIGH TEMP LIMIT SWITCH IS SET 200 AND THE AQUASTAT ON THE STORAGE TANK IS SET ON 120 THE BOILER COMES...
I would suspect a water circulation problem, most likely air in the system, if the water can't flow it will overheat.
If the problem persists after bleeding check to make sure the pump is running
Beeping noise
E2 means hot water over shot, make sure to check boiler hot water system to make sure zone valve or control is staying closed when the call for boiler hot water to the water heater is isolated. Sometimes a zone valve will fail open or not close properly causing hot boiler water to constantly feed the water heater.
Combi boiler hot water far to hot.
Yes the temp can be adjusted, the dial is behind the cover. Turn off power before removing cover.
Water heater is beeping with er- 120 flashing
if water heater is beeping E-2 it means that the water heater has gotten to high above water heater set point. Things to check
- there hot water being feed from boiler still
- is zone valve or pump isolated stopping flow of water to water heater
-check sensor readings
2helpful
2answers
Kenmore elite he4t
really need the whole model # ?
1 pressure switch
2 flowmeter
3 CCU
4 hose
he F33 means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch, the flowmeter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Top KDS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Eric
ADMIN Eric
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
