Question about Minuteman MN525 UPS System
MinuteMan MN525 During a storm 3 of the six ports of the device don't work. When I plug in VPN modem or routers they don't receive electricity. is there a way to fix it or should I just buy a new one? Thanks, Christian
    Novelist:
  • 154 Answers
The best thing to do is to replace it.
It preformed it's job which was to keep your pc's protected during a storm. As a result, three of your ports no longer work.
It can be fixed but you're better off getting a new one. You'll be certain your equipment will be protected.
Posted on Jul 29, 2009
    President:
  • 1,188 Answers
Hopefully only internal fuse(s) are blown. Refer to device owner manual to see how you can change fuses.
How connect cisco 5015 vpn with barracuda linkbalancer 330
Your Internet gateway <--- primary router
Port #1 on primary router <---> VPN server
Port #2 on primary router <--> Load Balancer
Load Balancer <--> web-server #1
Load Balancer <--> web-server #2
Load Balancer <--> web-server #3
VPN traffic enters your network, through the router to the VPN server, and then VPN-server back through the router to your internal servers. Web-traffic goes through the Load Balancer, for distribution to the collection of servers.
Jun 12, 2014 | WatchGuard Technologies WATCHGUARD TECH...
No card installed, it was called a modem (it looks like router.
Is it wired or wireless connection? What IP your PC gets connecting it? Bypass your router - connect directly to the device(modem). Add more details and I will be of help...
Nov 03, 2017 | Computers & Internet
I am trying to install my FVS318G
If you just plug it in - it should work. Are you using DSL or Cable - in either case just plug router WAN PORT into modem and then plug computer into and LAN PORTs on the router. Now configuring the unit is a different question
Aug 08, 2012 | NetGear FVS318 ProSafe VPN Firewall -...
Hello. It appears my router is blocking VPN access to the office server. I can connect using the ethernet cable so have isolated the problem to the router firewall. How do I get around this? Thanks
Hi
I will make a couple of assumptions on you setup. First, you have some type of highspeed internet. You have a retail type router/firewall plugged into your internet modem. You are using a VPN Client software installed on a PC or Laptop. By stating that when you connected using your Ethernet cable, you were plugged directly into the Internet modem.
Basically, what you have here is a configuration issue with your Router/Firewall. I use the Cisco VPN Client Software from home. This software uses UDP over TCP port 10000. Your VPN Client will use something along this line as well. So, you need to do one of two things here. Determine what Protocol and Port your VPN software uses. Login into you Router/Firewall and add that to your outbound allowed traffic. Or login into your Router/Firewall and configure it to allow all outbound traffic.
If you are not sure how to do this, the documentation that came with your Router should contain a Tech Support number to call. They can walk you through this in short order. Otherwise, post your EXACT make and model of your Router/Firewall and I will try to get the information for you.
Hope this helps.
Brian
Jun 30, 2010 | Linksys Computers & Internet
WRT120N doesn;t permit VPN accesses
Most times when VPN is not working is because one of the ports is not forwarding right. Easy fix is to go to router settings and enable DMZ for your computers IP address. Also you can actually find out what are the ports this VPN uses and go to Port Forwarding part of router and open the ports manually. My favorite is DMZ. All this does is open up ports for your computer IP address so there is no blocked pockets. Good luck.
Jan 12, 2010 | Linksys WRT120N Router
Unable to connect VPN using Arris Modem & Comcast Router
hi, mate check firewall settings of your modem/router. Then contact your IT administrator and he should be able to make changes to configurations for you. In most cases if server classify's your connection as unsafe it rejects it.
Jul 17, 2009 | Computers & Internet
Problem with VPNand Linksys router WRT150N
If that is the case you may forward ports on the router for VPN connection, try to open 47, 500 and 1723 all TCP and UDP protocol.
Here's what you need to do, check the IP address of the computer where you have the VPN software,
here's how:
click start> run> type cmd> hit okay
on the black screen put in ipconfig and check the IP address there,
> when you get the IP address then we can enable port forwarding on the router
> open IE on the working computer on the address bar, type 192.168.1.1
> nothing for username and password is admin in lower case
> then click on the applications and gaming tab on the router,
> and from there, example of how to field that in is like this,
> for aaplication name - VPN1
> for port it is 47 to 47
> for protocol it is BOTH
> for IP address ex. 192.168.1.XX - 192.168.1.100
> then check enable, do the same thing for the rest of the port.
> save the settings and try it again after.
> if it is still nothing, you may connect the computer that has the VPN connection directly to the modem and check if you will be able to connect via VPN
i'll wait for your response, thank you and have a nice day!
Jul 14, 2009 | Linksys Wireless-N WRT150N Router
Printing with Dlink DI-624S and VPN connection
I am guessing this VPN is something work related and not a VPN you setup yourself?? If that is the case your company's VPN access will not allow you to pass from there network back to yours which is why you are unable to print to your local home printer when connected to VPN. You might could run it by your IT staff and see if they will allow connection and help you set it up. If not then simply email the docs to yourself and then print them out after you are finished using VPN connection.
Hope this Helps
TankMurdock
Jan 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have netgear wpn824 wireless router and it works fine until I try to connect to my work server through their Sonicwall VPN. If I unplug the netgear and go straight into my computer through the DSL modem...
Two routers on two different sets of internal IP addresses will cause all kinds of conflicts. A VPN router is even worse. VPNs (virtual private networks) are designed to create encrypted tunnels between two computers. The computer its set to connect to must be authorized either as a user or a device with proper credentials. If your VPN authorizes devices based on MAC addresses, then unless your router's MAC address was previously authorized, youre not going to connect. Lets take the router out of the equation for a second. Do you have a working broadband connection from the sonicwall that the router can be plugged into? If you do, then you can treat this connection to your router like its a cable modem or DSL. If this connection has manual settings (such as IP address, default gateway, and primary and secondary DNS addresses) you will need these settings too. Post back and keep us updated...
Jan 17, 2009 | Computers & Internet
Trying to get VPN to work but not sure what fields to fill out to open ports on router. There is a previous post about opening some ports but I'm not sure what to fill out in all the fields or what it is...
you should at least provide with the router name and modem number , than i can provide you with the port number and how to open the port or more specifically "PORT FORWARDING" FOR YOUR vpn connections ... thank u
May 16, 2007 | SMC Barricade 7004 Router
Minuteman MN525 UPS System Logo
203 people viewed this question
Top Minuteman Computers & Internet Experts
Larry Chandler
Joseph Hoffmann
Are you a Minuteman Computer and Internet Expert? Answer questions, earn points and help others
