Factory resetting it may still return you to Spanish as it's default language or even worse enough, Chinese. You can download language translator on another phone,PC or tablet as your guide to reset it to your language of choice. Do it this way, translate, menu,settings, language setup into Spanish and follow them on your phone to navigate to change the language.
If your tom tom is in a wrong language, to set it back or change it to the normal language, all you need to do is to reset it. To reset it, hold down the power on/off button for about 15 seconds, it will restart the tom tom, that way the language will be restored back to its normal language.
If you are not requesting to change the language back to its normal language, then to change the language to any other foreign language, what you have to do is to go to the gps settings, then you select from the options where you find language, then you select your choice language, that way your language will be changed.
hope this helps.
For resetting Sansa e250 to factory settings:
Start from Main Menu.
Next select:
Settings (image of an equalizer)
Reset All
Yes
Having problems reading the language first choose yours, select:
Settings (image of an equalizer) Language is the 5th option after Settings Change the language to the language you prefer
Press Menu,
to highlight Setup, then
to access settings Select Language then choose your Language.
The option before Language is Reset, this will reset all options to their default. In Danish: Settings = indstillinger. Language = Sprog. Setup and reset are the same. Hope this helps.
