Help with washer problem
I have mold inside of my bosch washer on the rubber caset. i have tried a mold cleaner from walmart, baking soda mixed with vinger, lemon juice for a paste let set 1 hr. still . the mod still there. had the washer 1 yr. any helful hints
  • 13 Answers
You need to use a mug full of WASHING SODA in an empty wash at 60 deg temperature and let it run the cycle. You may need to complete this cycle 2 or 3 times but it will work.
Posted on Jul 29, 2009
There is like a black soot substance coming through into my wash, I'm having to wash the clothes again
When it comes to doing laundry, many people use front loaders because they are more efficient than top loaders. On average, they use 40 percent less water and almost 60 percent less energy. They also clean clothes better. They are not without their problems; and so, if you want to avoid problems, you need to know how to clean a front loading washing machine.
Dangers of a Dirty Washing Machine Mold is a common and dangerous problem with front loaders. Mold and mildew, at best, can cause bad odors in the machine and on your clothes. At worst, mold can make you sick. It grows because dirt, lint and water gathers between the seal of the machine's tub and door, thus creating the ideal atmosphere for the breeding of mold, mildew and other bacteria.
The mold creates inhalable spores, and the bacteria create nasty odors. Inhaled toxic mold spores can cause chronic fatigue; dizziness; eye, nose and throat irritation; fever and flu-like symptoms; headaches; learning disabilities; nausea; severe breathing problems and vomiting. Therefore, it is important that you keep your front-loading washing machine clean and that you keep the area between the door and the tub dry when not in use.
How to Clean a Moldy Washing Machine
If you are wondering if your machine is moldy, it probably is. If you smell a musty, sour or stinky odor coming from your washer or your clothing, you probably have an issue. There are a number of possible solutions, and none of them work for every situation.
Some people have had luck getting rid of mold by changing detergent. Some do well by using a mixture of baking soda and vinegar every few loads. Others have had mixed luck with oxygen-free bleach.
One product many people have had success with is the all-natural Smelly Washer Cleaner product. It works with high-efficiency front-loading washers, and because it is made from citrus, it is safe for the environment. It supposedly cleans by getting rid of the odor: not by masking it.
Another product that is supposed to get rid of the odor rather than mask it is Affresh Washer Cleaner for High-Efficiency (HE) Washers. The manufacturer also claims that the product is eco-friendly and safe for septic systems and appliances. It works by releasing oxygenated bubbles that remove residue buildup that causes odors.
To clean your washing machine without commercial products, use the Acidic Cleaner (click here for the recipe) with some sprinkles of baking soda to clean the rubber door gasket. Try using a soft toothbrush, or one of many small brushes you can find to clean in small crevices, and a soft clean cloth to gently but firmly wipe out the gooey mold. Frankly, If washing the gasket does not get rid of the odor and the mold, you may have to replace the gasket.
Also use the Acidic cleaner and baking soda to clean the soap and softener dispenser. If you can remove the soap dispenser tray, do so, then soak it in the vinegar solution with baking soda for ten minutes and wipe it clean. Also use the solution to clean the hole that houses the dispenser tray, if your appliance has one. Rinse all parts well after cleaning to remove the vinegar and baking soda residue. Spraying just the Acidic cleaner over the surfaces will remove the baking soda, and then water will remove the vinegar.
Again, be sure to rinse and dry everything well. In fact, you should dry all the parts of the machine, including the inside of the door, after each and every use to prevent the growth of smelly mold. Just like we advise after taking a shower to dry the tiles and grout right away, or after cleaning kitchen surfaces to let them dry completely, we advise the same treatment for your front loading washing machine. Mold, mildew and germs like moist surfaces. Eliminate the moisture, and there goes the gunk!
Another part of front loader maintenance is filter cleaning. Manufacturers and models vary, so you need to check your manual for your specific instructions. But typically, it involves opening a small door near the bottom at the front of the machine. Inside, you will find two items: a small hose and a debris filter.
The hose drains leftover water out of the washer, so you need something for the water to drain into. Be prepared, because it might be several gallons worth. After you drain the water from the machine, remove the housing for the debris filter by turning it counterclockwise. Once it is out, clear it of lint and other debris. Before reinserting it, reach behind where it was and check the drain pump impeller with your fingers to be sure it is also clear of debris.
After you have cleaned the above items, run a load of hot water with laundry detergent but no laundry. Adding oxygen-free bleach to the detergent will prevent mold. If your system has an integrated cleaning cycle, use that. If you were having odor issues, run another load afterward using hot water with one cup of baking soda and one of white vinegar.
How to Prevent Mold in a Front-loading Washer In addition to the rubber door gasket, you need to clean the soap dispenser and any other part to which you have access frequently. Because front loaders use very little water, not all substances are rinsed away when the tub empties. This can cause a residue buildup.
Let it Dry!
It is good to leave the washer door open after doing a load. This allows the inner parts to dry out. Dry the soap dispenser and the door gasket by hand with a towel. Also, do not leave wet clothes in the machine for very long - especially all night. Any moisture in the machine will eventually cause mold.
Rather than using powdered detergent, use liquid because it dissolves better and leaves less residue. Also, to reduce residue, use as little detergent as you can while still getting a clean wash. Rather than liquid softener, use softener sheets to reduce moisture.
If you always wash in cold water, do an occasional load in hot water. This will clean out some of the residue buildup. Use a low-sudsing detergent designed for a high-efficiency washer. These washers usually have self-cleaning cycles, and you should use the one on your machine periodically.
As with anything, prevention is better than cure. Becoming a little slack in caring for your front loading washing machine can cause many problems later. And if you are no more fortunate than many other people, you may not be able to get rid of your problems once you have them. So if you haven't done so in a while, go take a look at that washer and get ready for action.
Aug 02, 2015 | Washing Machines
Tip
How to Stop Mold or A Stagnant Smell from Washing Machine.
If your washing machine is producing a stagnant smell which is tainting your clothes then this Tip is for you!
Secret ingredient: Ordinary Baking Soda.
First check to make sure that the machine is draining properly and ensure that the pump filter is clear of any debris. Check that the drainage pipes at the back of the machine are not kinked or obstructed in any way.
If the machine is a frontloader a common place for mold to build up is the rubber seal gasket around the door such as this one. Immediately you can see the nooks and crannies where mold can build up.
Mold is one of the most common causes of a stagnant odour.
Clean this out as well as you can with ordinary kitchen cleaner (avoid using bleach) then place a heaped cup of baking soda directly into the drum and run an empty hot/boil wash on a full cycle.
Baking soda has a cleaning and neutralising effect and will help remove any build up of mold or gunge within the machine. You may need to run two of these washes before you see a solid result.
Thereafter I recommend you run a monthly 'maintenance wash' with the baking soda to prevent the problem arising again.
It is highly recommended that the door of the machine is always left partially open between washes as this encourages ventilation and discourages any more mold from forming inside the machine.
If you found this Tip helpful please take the time to register your vote using the buttons below.
Many thanks for using FixYa.
on Dec 19, 2009 | Washing Machines
What lime scale / detergent remover can be used for regular cleaning of my front loader.
Front-loading washing machines are energy efficient and use less detergent than top-loaders, but they sometimes have a tendency to harbor mold and unpleasant smells. By giving your washing machine a quick clean once a month, you'll keep your front-loader fresh, which means cleaner clothes, too. This eco-friendly method doesn't use bleach, costs only pennies to make, and comes together with ingredients you already have on hand.
What You'll Need:
  • 2 cups vinegar
  • 1/4 cup baking soda
  • 1/4 cup water
  • Scrub sponge
Directions:
  1. Start by mixing together the baking soda and water in a small bowl. This is going to be the "detergent" for cleaning the washing machine. Pour the vinegar into a measuring cup and head over to your washing machine.
  2. Add the baking soda mixture to the detergent container of your machine and pour the vinegar into the drum. Set your washer to normal load at the hottest water setting. Close the door and start the machine, letting it do all the hard work for you. The baking soda and vinegar naturally break up mineral deposits and any mold growth while cleaning and refreshing your washing machine.
  3. Use a clean scrubber to rub around the opening of the washing machine, removing stubborn mold or residue. Wipe clean with fresh water.
  4. Your washing machine is sparkling clean and ready to do a load of laundry! Give your front-loader a cleaning once a month to keep your clothes smelling fresh and your machine working in tip-top condition.
Mar 20, 2015 | Washing Machines
The water smells bad as if it is not draining correctly. Is there a water filter that needs to be replaced? How do I clean out this washer to get it smelling nice?
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Hope this helps.. Please post back if you need mor information.
Daniel
Nov 26, 2010 | Bosch WFMC 3200 Front Load Washer
What can I do to keep mold out around the front rubber piece in my washer?
Try leaving the door open when not in use, just enough to let air in. If its a big problem and its because its not being used much then leave a open box of baking soda inside, while not using it. Don't forget to take it out when your going to use it again.
Aug 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell from front-loader Asko washer.
Hi
First check to make sure that the machine is draining properly and that the pump filter is clear of any debris.
On a frontloader a common place for mold to build up is the rubber seal around the door. Clean this out as well as you can with ordinary kitchen cleaner then place a heaped cup of baking soda directly into the drum and run an empty hot/boil wash on a full cycle.
Hope this helps. Thanks for using FixYa
Nov 15, 2009 | Asko W6461 Front Load Washer
LG WM1814CW Front Load Washer rubber seal on front door collects water underneath and now has black mold, and a strong odor, like cigarette smoke.
Use some detergent plus baking soda and mix it in with the water--rub it around (with an old toothbrush) to loosen the mold. Let sit for a while, then wipe water, mold, and cleaner away. Finally, rinse with clean water and wipe dry. Leave the door ajar to air out after each wash. It will help to remove the standing water each time. Don't poke a hole in the seal to drain the water out, because water will then run out of the bottom of the washer.
Sep 28, 2009 | LG WM1814CW Front Load Washer
After washing my machine smells like stagnant water
Hi
If the machine is a frontloader a common place for mold to build up is the rubber seal around the door. Clean this out as well as you can with ordinary kitchen cleaner then place a heaped cup of baking soda directly into the drum and run an empty hot/boil wash on a full cycle.
Hope this helps. Thanks for using FixYa.
Sep 26, 2009 | Whirlpool Washing Machines
Mold on the rubber seal of bosch washing machine
RUN A LOAD OF HOT WATER WITH 1 QUART OF WHITE VINEGAR, THAT WILL KILL THE MOLD, THEN WIP IT OFF THE SEAL
Aug 24, 2009 | LG WM-2277HW Front Load Washer
Kenmore 'elite' HE3 front loading washer
I have the same problem. Nothing works fcfor the mildew. i have bleached it, used simple green and used baking soda. That washer is the biggest piece ever!! Good Luck!
Jul 06, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
