Question about D-Link DI-634M Wireless Router (DI634M)
My D-Link DSL-2640B power light is staying red, and its not working at all. The only light which is on, is the red power light, usually it works fine, and its green. any help please?
    President:
  • 1,188 Answers
Try another power adapter.
Posted on Jul 29, 2009
A mysterious message coming from nowhere...
Posted on Dec 10, 2012
I have a D-link DSL-2750U router worked fine till yesterday, but now its power led keeps on giving a red light it should give green a second or two later but it keeps givings
Reset router. There are two resets. A simple push reboots and holding it in clears all custom settings. Try the first.
This is a quick fix and usually does it. Test with network cable and work your way backwards to modem if you still have problems.
Nov 11, 2012 | Computers & Internet
D LINK DSL-2640B Router's Wireless keeps disconnecting
both modem ip address same please check book the modem and install modem ip different 192.168.1.1 and 2nd 192.168.1.2
Apr 15, 2012 | D-Link (DSL-2640B) Wireless Router
Modem d-link dsl 2640U status : connected Power : Red Light LAN (R1) : Green Light DSL : Green Light Internet : Red Light seems that the modem has crash! can't even rest it ! so what should i...
hi
I am techbuddies from fixya .i would like to give a try on your issue.
first of all shut down your modem and your computer then unplugged cables that goes from modem to your computer once it is done then wait for 30-50 sec and then replugge all your calbe and then first turn on your modem and then your computer .This kind of method is called as power cycle of modem.
Once you have done that then check that wether is works or not if not then try to check that is their any kind of red X on your computer on right hand side bottom ,if yes then on run type devmgmt.msc then click OK and the you would be able to log in to device manager .Once the device manager is open look for network adapter click on the plus sign and then under lan right click and click on to enable it .
check wether your internet is working or not .
Also check what is the ip address if comming on your computer .
Inoder to reset your modem .check is their any small hoel in rare-end of the modem if yes please insert a smal pin in to it and press it untill all light flash on and off .
if still the problem comes get back to me on fixya
Sep 09, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
D link router ports no lights model d1 604
there is insufficient info provided but...
is power on? if not, then re-connect power
are there no lights on any cable? is cable properly inserted on router and on computer? try another cable? another computer?
if none of the above works, router maybe due to go where burnt toasters, obsolete tv's and other non-working electronics go... you maybe due for new router...
Jul 27, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I'm having problems tring to connect to ATT HS DSL, flashing green light but can not connect to internet, what settings on DSL-2640B do I need???
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Jan 07, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Power red light solid
I have same problem. I was able to manually assign IP of 192.168.1.2 and was able to connect to 192.168.1.1 (the d-link) but it keeps asking for Factory Supplied Firmware From ISP. I flash it with the firmware but then it crashes again.
Jan 04, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Power light is red. Hub is OK. No wireless and Internet connects
Have you tried configuring your wireless settings? If your internet works hard wired, its just the wireless settings that need to be configured. Access the router's setup by going to http://192.168.0.1 and change the wireless channel. Make sure to check the wireless security as well and verify if you are using the correct wireless network key
Oct 06, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
No power light on DLink DSL 2640B
try another power adapter, the Dlink 5v power packs known to die within 2 years.
Jul 03, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a 2640b router failure
I think that u need to go on, open your internet explorer, and enter your ip address in the address bar. Enter your password. Check your settings. Sometimes, internet stops, because firmware needs to be updated, sometimes its your computers driver (this is not likely); but most likely, your best option is to update the firmware for it. Consult your manual or internet on how to do it.
Jan 06, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Dlink 2640b cannot get both internet and dsl to work together
Unplug both devices,and remove the cable/dsl line input to modem, wait 5 minutes, plug cable back it, then turn on modem, wait a minute, then plug in router.The signals should mesh.If not, buy a new router, theyre cheap!~
Dec 14, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
D-Link DI-634M Wireless Router (DI634M) Logo
3,078 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
