Question about Vizio VA26L 26 in. LCD HDTV
Goodman 42" HDMI TV 5 years old has thin lines on the screen
I still have a picture but it has thin lines from side to side all over and lines running top to bottom, can this be repaired or is it terminal?
    President:
  • 1,188 Answers
Appears most probably to be a fault in the inbuilt power supply capacitors. Getting them changed once solved my problem. If you opt to change yourself then don't blame anyone if it renders your TV unusable!
Posted on Jul 29, 2009
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Jan 24, 2014 | Vizio Televison & Video
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
We have a thin line going through the picture is this a problem with Sony Bravia T.V. it is just under three years old.
Line failures are comon on all plamsa and LCD screens.
Best way to test is connect via HDMI or PC into the TV if it still has the line it is 80% the screen.
Aug 11, 2010 | Sony Televison & Video
I have a thin vertical line about 9"from left side runs top to b
either a bad buffer pcb or display panel, 12 month warranty call panasonic quick
Aug 08, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Hpr4262 samsung plasma picture problem
You need to call a technician.The problem lies in the board [internal].
Jun 25, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Thin green line on right side of screen when watching through HDMI cable...line goes away when watching through reg AV inputs
You should check if you could adjust the screen size or posistion. If that don't work try using another (newer) HDMI cable. If everything feals go back to your store and claim a new tv. Then it is the hardware inside the tv, you will have warrenty on that.
Dec 24, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Hitachi 32" Plasma TV fault on screen thin pencil type line on left hand side of screen from top to bottom. Line thickness is approx 1mm TV is 5 years old Thanks Tom
iav a sky 42 inch plasma model number pd54250 when i swich it on i av got a green lined picture sometimes it comes on with a full picture can you help
Nov 22, 2008 | Televison & Video
42" pansonic plasma hdmi problem
if I understand your question properly.. its because your direct tv output doesnt broadcast in high def so its giving you the standard tv definition inputs which are RGB or Component.so you will lose picture quality cos its running at fewer lines or pixels. hope this helps
Mar 12, 2008 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Vizio VA26L 26 in. LCD HDTV Logo
173 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
