Question about LG Washing Machines
My LG Tromm front load washing machine gives me an OE error. Referring to a drain problem. What should I be looking for/
  • 6,784 Answers
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Posted on Jul 30, 2009
What is an "OE" error message on an LG Tromm clothes washer?
OE means Water may not drain properly
This causes:
Your pump is clogged.
Your pump is not connected.
Make sure your pump is repaired, and try again.
Jul 28, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My tromm LG front load washer is flashing OE, what is it.
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
Jul 19, 2011 | LG Washing Machines
The washer is displaying an OE. How do I fix this?
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
heatman101
Sep 03, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg tromm front loader washer wm0532hw shows oe error
that's draining error. check the filter cleanout behind lower left panel on front of machine; of course drain 1st via small drain hose. if thats o.k the drain pump itself may be jammed with debris or the drain hose could be clogged.
Jun 24, 2010 | LG WM-2277HW Front Load Washer
LG Tromm WM2277HW OE error message
unit not drainning..in the but front left hand corner ,,there a panel,,open panel and clean your filter...onthejob...
Jan 25, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My front load Tromm LG washer flashes OE message, won't drain or finish wash. Door does open
oe is an error code for pump problem disconnect power cord open small door on lower front of cabinet pull little tube out and plug from tube and drain water in to bucket after water is drained unscrew cap of pump to clear out any obstructions reinstall the cap and plug and give a test run
Dec 20, 2008 | LG WM-2277HW Front Load Washer
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
195 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
