Question about Kitchen Ranges
The fan oven does not heat up, though the fan seems to be working OK. Any ideas, please? It's a Belling Cookcentre Evolution with electric ovens
  • 13 Answers
If the fan runs and the temperature light comes on but no heat then you will need to replace the fan element.
Posted on Jul 29, 2009
Tip
Common faults Belling XOU252
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling XOU252 Electric Single Oven
Tip
Common faults on belling cookers
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
on Jan 17, 2010 | Belling XOU592 / XOU593 Electric Double...
My Belling oven has no heat, but the fan &
If the fan is working o/k, then there is little doubt that the oven element has failed.
This is quite common with fan assisted ovens.
The element is usually located at the rear of the oven compartment behind a removeable cover.
Mar 29, 2010 | Belling XOU252 Electric Single Oven
Fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Apr 05, 2009 | Belling XOU252 Electric Single Oven
Oven not heating up
Easy enough job, you can access the element via the screws inside the oven compartment. Just make sure the unit is isolated at the mains. It is then simply a case of removing the screw that holds the element in and unpluging the spade crimps that connect to it. 5 minute job at the most. Maybe you can help me in return, I have the cookcentre 132wgr but no instructions do you know where I could get some???
Mar 24, 2008 | Belling CookCenter 151 Dual Fuel (Electric...
Broken cooking appliance :( please help
if the fan is spinning then it sounds as though the element has gone. has your fuse box recently tripped? it may have been the blowing element.
Jun 10, 2007 | Belling XOU252 Electric Single Oven
Belling Synergie fan oven.
the elemet has burned out round the fan
Dec 05, 2006 | Belling XOU174 Electric Single Oven
Kitchen Ranges Logo
248 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
