Question about HP iPAQ H1945 Pocket PC
I have an HP Ipaq h1940 pocket PC. It won't charge!
I have an HP Ipaq h1940 pocket PC. The battery is 100% dead, and hasn't been charged for a while. I ordered a new USB Sync / Charger cable online, and it still doesn't turn on, even after a night of nonstop charging. Any ideas?
Charge the dead battery with other good battery for a while first.
Posted on Oct 25, 2009
Tried to update the rom of my ipaq h1940 with the sp26261 update pack. plugged it into the cradle, started the update manager (connection via windows device center on windows 7/64 bit). the update manager...
bad Idea ROM updates.
best is to never do it unless sure it cures a problem that you need fixed.
doing Rom up dates are very risky,
1: battery must be good. and being charged so that the process can not be interrupted.
2: you used XP PC of some kind to program that IPAQ rom?>
that be last choice, of all. after all most XP computers are infected with virus and malware, and is a virus magnet and not support now for 3 long years, (means its worse every day)
why even use any IPAQ,
why not just buy some used Android phone and move on, move up.
its dead product now.
IPAQ is like Elvis, he left the building.. LOL
if really motivated to make any think this old here why not ask
the real form.
Your only recourse now, it repeat the flash over and over
praying it works (with full charged and fully good batterY)
https://h30434.www3.hp.com/
May 15, 2017 | HP iPAQ H1940 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
My Hp ipaq h1940 pocket pc is frozen on the hp opening page with 2 1.07 at the top I have tried soft and hard reset and removing the battery.
check HP support for a rom update for your model. the h1940 had some problems you are having.hope this helps
Jul 16, 2009 | HP iPAQ H1940 Pocket PC
HP PDA h1940
I just found the most protracted set of instructions to reset it for reference.
1. charge on ac only = 8 hrs
2. remove battey, soft reset, reinsert battery
3. charge on ac only = 30 minutes, remove battery, remove power, hard reset then soft reset.
4. charge on ac only = 4 hrs
5. Power off. Soft reset.
Oct 13, 2008 | HP iPAQ H1940 Pocket PC
Problem
Hi, I have same problem. After upgrade bios to version 1.10 my ipaq h1940 don`t start windows. When switch ON appears HP logo, time line go to end, and ipaq stay block. No possible switch OFF and no starting windows.
Nov 16, 2007 | HP iPAQ H1940 Pocket PC
Ipaq h5555
I battery dead ? In some case, ipaq battery dead will not start. ================
Aug 05, 2007 | HP iPAQ H5555 Pocket PC
My iPAQ will not charge or turn on ...
Can you get the iPaq hooked up directly to AC power? There's apparently a charging threshhold for badly depleted batteries that the USB port cannot get over.
Sep 08, 2005 | HP iPAQ H5555 Pocket PC
HP iPAQ H1945 Pocket PC Logo
337 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
