Question about Elite Televison & Video
Kenmore Elite Induction cooktop, model begins 790. Error codes 88 and 60 flash.
Controls don't respond to touch, will not do anything. I've turned off supply breaker and back on. Any idea what the problem is?
    Sergeant:
  • 155 Answers
From my quick look around they have got more error codes than I have seen in a long while its a wonder they work!
I have not seen those codes listed anywhere and would suggest calling for a service engineer but before that switch off its main power source and wait for an hour to allow it to discharge any residue voltage in the electronics before turning on again.
Hope this helps...........
Posted on Nov 24, 2017
  • Elite Master
  • 2,794 Answers
Try posting this in the appliance forum, you may have better luck there
2 Suggested Answers
SOURCE:
SOURCE: Kenmore Elite Induction Cooktop Error Code 41
I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
Anyone else experienced this failure??
Posted on Jul 16, 2010
I have a Kenmore Elite Electric Range with Induction Cooktop #C970-440032 with an error code E074
Suggest down load the owners manual online and reference error codes.
Mar 21, 2018 | Kenmore Cooktops
What is error code E035 on a Kenmore electric range w/ an invection top and a convection oven
Kenmore 790 Model Induction Cooktop Error Codes Sears PartsDirect
Take a look at this link ... for model 790 it indicates that error 35 is:
Improper power supply voltage (low voltage) or failed wiring connections
Check:
Disconnect power. Check the power supply wiring. Have an electrician check the supply voltage. If the connections are good and the voltage is normal, the main power control board or filter control board is defective.
So it may need a new control board...
Mar 14, 2018 | Kenmore Kitchen Ranges
Looking for instructions on how to replace the main cooktop on our kenmore elite elecric range, model 790
To raise and lower the cooktop:
1. Remove all items from cooktop and set aside.
2. Grasp the sides of the cooktop and then lift from the
3. Lift the cookop high enough to allow the support rods
to snap into place. The llft-up rods will support the
cooktop in the raised position.
4. If necessary, clean underneath using hot, soapy water
and a clean cloth; then dry.
5. To lower the cooktop, grasp the front corner of each
side of the top while pushing back on each rod with
the heel of your hand. This will release the notched
support. Hold the range cooktop and gently slide the
top back down level to the range.
Aug 03, 2016 | Kenmore Kitchen Ranges
I have a Kenmore elite cook top that is displaying a code C 11. What is the meaning?
ftp://ftp.electrolux-na.com/prodinfo_pdf/lassomption/318200292.pdf
ftp.electrolux-na.com > lassomption
SERVICE DATA SHEET - 30" Induction Cooktop with Ceramic Glass. IMPORTANT. DO NOT .... C11. Shorted keypad. The defective control will flashes the error code in its display. 1- Cycle power on ...
May 24, 2015 | Kenmore Washing Machines
Wiring for Kenmore Elite Induction Cooktop
The white one may just form an earth loop,, I recently had a ceramic plate needing cleaned so we did the whole lot, I think most hobs have 4 wires and they are numbered rather than colour coded..hope this helps
Nov 10, 2013 | Kenmore 30" Induction Cooktop Stainless...
Feb 01, 2009 | Kenmore 42800 Stainless SteelCooktop
Error codes 10 12 16 on kenmore induction cooktop
We purchased a 36" elite model on ebay for our house we are building. I finally installed a year later only to have error codes 39 & 40. I completely dissasembled it and put it back together. No luck. However after much searching I found the service manual for the 36" Icon by Electrolux (same manufacturer as the Elite). The guts look mostly the same. Manual states your codes 10 16 12 are for defective key sensors. I found out that on my cooktop if I held a key for maybe 20 sec or more it would beep once - indicating the key was not defective.
Link for manual on web site appliancejunk. com is below
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=270
Oct 10, 2008 | Kenmore 42800 Stainless SteelCooktop
What does error code 35 mean on a kenmore elite induction cooktop model 790.4290. I believe the unit is made for Kenmore by Electrolux
it has a fatal or error condition. try turning the power off and than back so it the cook top can reset it's self. if that does not work you will need to contact sears for service.
Aug 23, 2008 | Electrolux Kitchen Ranges
Televison & Video Logo
133 people viewed this question
Top Elite Televison & Video Experts
Akbar Mughal
Akbar Mughal
 steve
steve
Are you an Elite Televison and Video Expert? Answer questions, earn points and help others
