Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Water showing mold like substance visible despite 2 new filters
We are not able to use the water dispenser for months now because we are seeing mold like substance in the water despite changing  both refrigerator filter and one extra on line filter. please help
  • tcoe Apr 14, 2008
    We've replaced the filter (even though the sensor said it was good - green), however, the water still contains dark floating substances. Almost like little pieces of skin. We can't figure out what this is. . looks like film that may have formed in the components somewhere. Please help!
  • Gowster Apr 27, 2008
    I had the same problem. After paying over $200 to call out the service repair man, all he did was swap out the water tube hose. If you open the fridge and remove the botton drawers, you'll be able to see the hose coiled in the back. If you look closely, you should see the black film inside the tube. What it is is mold that has accumulated in the tube. replacing the tube fixed my problem. You can probably order and replace the tube yourself which will save you money.
Hi Sergo,
I had the same problem with my fridge for a while. After changing the filter twice, I determined it wasn't that. I ended up paying about $250 several years ago and called the service repair man. All he did was replace water hose coil reservoir inside the fridge. If you open the fridge and pull out the bottom drawers, you should be able to see the hose coiled up in the fridge. This is your cold water reservoir. If you look very closely at the coil, you might be able to see the mold inside the transparent coil. Replacing the coil fixed my problem. You can order the coil and replace it yourself and save yourself lots of money. The reservoir coil part number is 2209687. Good luck.
Posted on Apr 27, 2008
  • 447 Answers
Disconnect the water from the refrig. Get large bowl and turn on water supply. Does water look clear?? Flush real well.
Posted on Nov 23, 2007
Whirlpool Gold side by sideGC3PHEXNS00 not making ice but the water works. Already replaced the filter.
put your finger in the ice mold and see if there is ICE in the mold. if no ice then use a turkey baster and put approx 1/4 cup of water into the ice mold, slowly. in about 2 hrs you should hear ice drop and then refill with water. if there is ice in the mold, you most likely need a new ice maker.
Jan 02, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
My GE GSL25JFPEBS side by side refrigerator stopped making ice. The green power light blinks indicating ice being stuck, but once the ice is removed from the mould, the problem starts all over again. It...
i am wondering if ice is constantly getting stuck or are the cubes smaller that the size of the mold? if that is the case have you tried replacing the water filter. The typically reason ice gets stuck in the mold is because the individual cubes (usually 7 or 8 per mold) are too small,the leading cause of that is not enough water in the mold
Also is water dispensing through the door with good pressure, if no replace filter but first check the pressure of the incoming water from house plumbing
Jul 29, 2011 | GE Refrigerators
2 months into the heating season I noticed a large puddle around my heater. the Aprilaire 600 unit was leaking. The distrution tray had a red substance around the water holes. Also the overflow drain line...
Mold can really cause problems with humidifiers-
They do need to be serviced, cleaned up, and something like weak bleach used to kill mold spores, -- get it all tidy and clean!
Were you able to clean out the drain line?-- and is it draining now?
And is the float valve shutting off the water flow, before it reaches the overflow drain pipe?
Another concern would be the soaking pad-- Has it been changed recently?
Tell us more--
Mack B
Jan 06, 2011 | Aprilaire 600 Humidifier
Mold in water dispenser
I also found black colored mold in my kurieg, I was getting a respiratory infection every couple of months and couldn't figure out why. I stopped using the machine immediatley about 4 months ago and haven't had a respiratory infection since. What's scary is what is inside the water resevoir that you can't see.
Jul 15, 2010 | Keurig Elite B40 Coffee Maker
Monthly Cleaning Protocol
  1. Hello. here it is: Use only the proper amount of HE (high-efficiency) detergent in your Duet. Whirlpool has stated that using too much detergent or fabric softener in the Duet can ruin a high-speed spin bearing responsible for spinning the basket. The replacement part is approximately $600. Whirlpool also claims that using too much detergent or softener can cause fungus growth.
  2. If you have mold and mildew problems with your Duet, check the filter trap. Unplug the washer and remove the three screws in the seam between the door and the bottom panel to remove the bottom panel. The Duet drain pump has a design flaw that leaves about a cup of water in the filter trap under the tub. Clean out that filter with bleach every month or two to eliminate mold problems.
  3. Put small items in a mesh bag before washing. There is a good chance they will get lodged in the Duet's filter trap, if you don't. Check the filter trap mentioned in Step 2 monthly to make sure there aren't any small items blocking the filter.
  4. Remove your detergent dispenser every month and wash with warm water and bleach to prevent mold buildup. Remove the fungus smell from your washer with Affresh washer cleaner. Always keep the washer door open when not in use.
Apr 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Moldy door gasket, smelly clothes
Mold growth is a common problem due to tight seals and poor drainage.
Pull back the rubber or plastic around the tub or basin to reveal the problem. You should also check your detergent dispenser as this is another common area for mold growth. Remove any visible mold. You can use a solution of water and dish detergent or bleach (1 part bleach to 10 parts water). You could also use bleach wipes to do this depending on how stubborn the mold is.
Because of the set-up of the washer, mold can also tend to grow in pipes, traps, and outside the drum where you can't see it.
You can run an empty load on the hottest water setting with 1 cup or more of bleach. Run an empty load on the hottest water setting with 1 cup or more of vinegar. Use a product designed to attack build-up from detergents and fabric softeners. Call a repair man to service the parts of the machine you can't see or attempt to do it yourself
However Mold needs moisture to grow. Leave your washer door and detergent dispenser cover open in between loads to allow for complete drying. This will dramatically decrease or eliminate the problem.
2. clean the machine monthly to stay away from the problem.
3. Switch to powder and/or low-sudsing detergent.
Let us know if you need further clarification else please accept the solution.
Thanks for contacting
Mar 21, 2010 | LG Washing Machines
Bad smelling water
The water lines are contaminated with bacteria and/or mold. This is a problem with many refrigerators. You need to turn off water and disconnect the feed line and filter. Mix 4 ounces of Clorox(R) in 1 gallon of water and pump it through with a NEW garden sprayer. You can remove the wand and clamp it onto the water inlet. Activate the dispenser while you pump the bleach through the system. Once bleach starts coming out the dispenser, vent the garden sprayer (de-pressurize), Let the bleach sit for 15-20 minutes. Re-attached water using a brand new filter (do not use the old filter and do not put bleach through filter). Run water until no chlorine odor (it can be a while). This process needs to be done at least once a year.
Jul 29, 2009 | Maytag MFC2061HES Stainless Steel French...
Dirty pieces of ''onionskin'' in water after changing water filt
Same problem in my 1 year old Maytag side-by-side. I let the stuff it sit in a cup for about 5-7 days, and it turned into a fuzzy mess of mold. Obviously a problem. However, Maytag WILL NOT admit a problem. Home Depot would not override Maytag's decisions. They did arrange for an appliance repair company to replace internal tubes, but after about a month of drinking it again, (WITH A NEW $35 FILTER) I found lots of new MOLD last night. Filled a pitcher a couple of times to find six "onion-like" pieces. This has been an ordeal of about 9 months. My family has had unusual illness (colds, flus, stomach problems) for the past 9 months. I am about to take it to the city dump.
Mar 21, 2009 | Refrigerators
New filter but water dispenser still not working
Check the water valve if its working most probably watewr line inbetween the water valve and the water dispencer is frozen. Un plug the refrigarator for four hours and try again.
Mar 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Black flakes, like mold in water dispenser
check your water reservoir lower part of refrig. section ( take out crispers)
Dec 14, 2007 | Frigidaire FRS23R4A Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
158 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
