Cell Phones Logo
R
Roy Saunders Posted on Nov 24, 2017
Cannot transfer from my music to usb - Cell Phones
1helpful
How can I download music to my fusion2 phone
First you:
2.9.1 Using the microSD Card as USB Mass Storage
To transfer all your favorite music and pictures from your PC to your mobile phone's microSD card, set the microSD card as USB mass storage.
1. Connect your mobile phone to your PC with the USB cable provided. Your PC will detect the microSD card as a removable storage device.
2. Open the notification bar, and then touch USB connected.
3. Touch Turn on USB storage in the dialog box that opens to confirm that you want to transfer files You can now transfer files from your PC to your mobile phone's microSD card. When your microSD card acts as USB mass storage, your mobile phone will not use this memory space. Ensure that you follow the correct procedures to disconnect the USB mass storage device (your mobile phone) from the PC when you have finished transferring files.
Then:
8.3.1 Copying Music to the microSD Card
1. Connect the phone to your computer with a USB cable and mount the microSD card.
2. On the PC, navigate to the USB drive and open it.
3. Create a folder in the root directory of the microSD card (for example, Music).
4. Copy the music from your computer to the folder you have created.
5. After copying music, unmount or eject the drive as required by your PC's operating system to safely remove the mobile phone.
6. Disconnect the mobile phone from the PC.
Once done open music player and play music.
Ref: http://www.att.com/support_static_files/manuals/ATT_Fusion2.pdf
2answers
How do I delete songs from my ipod from a usb port on a computer?
First plug your i-pod 1st generation into my usb port on your computer.
Then download and install Sharepod. when the it appears right click the selected song and delete it, in the main menu
3helpful
I want to download music using my usb
Hi,you can transfer music to nokia 5800 from your computer(pc or mac). There are different ways of transferring music.if you have a PC, you can use PC Suite to transfer music files.the nice software that comes with the phone. If you have a Mac, you can use Nokia Multimedia Transfer (free download) and sync it with your iTunes.
how to put songs on nokia 5800-nokia pc suite
To transfer music as data files, make the connection with a compatible USB data cable. You also need to have a compatible memory card inserted in the device. View your nokia 5800 on a computer as a mass memory device. follows these steps: firstly, connect nokia 5800 with computer via USB data cable. then select Mass storage as the connection mode. A compatible memory card must be inserted in the device. then view the device from the computer file manager as a mass memory device. now you can fansfer the music files. after transferring songs, you can close the connection by remove the USB device safely from your computer.
Hope it helped.
How do i transfer music from my pc to my nokia 5230 using bluetooth
Hi, Not all cell phones come with special software to transfer photos, music, video and other file formats from your computer to your phone. In fact, some cell phone providers desire that you purchase this software separately and make it difficult to transfer music any other way. However, most users can typically hook their cell phone to a computer with a USB cable and transfer music to a cell phone as if it were an external drive, such as a USB stick or an SD card. Note: This process might not work with all cell phones.
Connect your cell phone to the computer using the USB cable.
Wait for the computer to recognize your cell phone as an external drive. If a dialog box does not pop up with the name of your cell phone within a few minutes, open the Windows Explorer folder and navigate to the external drive in the left pane. Sometimes the name of the drive will show up as "Removable Disk."
Open the music folder of your cell phone. In some cases, it might be under a "My Media," "My Music" or similar folder.
Drag and drop the music files into their own folder under the cell phone's music directory. This way, it should be convenient to find the files once they're on the phone. Wait for the files to copy completely.
Disconnect the cell phone from the USB cable. If there is a Safely Remove Hardware icon in the bottom right corner of your taskbar, use this utility to safely remove the drive.
Tips & Warnings
If your cell phone supports an SD or micro SD expansion card, transfer music onto this card using the above method instead of transferring music directly to the phone. This way, you don't hog space with large music files and slow down the performance of your phone.
According to Simple help.net, sometimes a USB connection icon will appear in the window of certain cell phone types when you connect. In some cases you might need to tap this icon to confirm the USB data transfer before you can begin moving files to the phone.
May 23, 2011 • Cell Phones
2helpful
2answers
I tried downloading mp3 music on my nokia 5230 it doesnt work
you might want to check your java scripts, also try master reset see link below --> discussions.europe.nokia.com/.../Nokia-Nuron-5230-how-to-master-reset/m-p/773627
How do I put my music from Itunes on the usb drive and when do I know that they are on it
Plug your usb pen into a usb slot on your computer,
open 'My computer' from your start menu or desktop,
Select your usb drive by double clicking it to open it,
Open itunes and right click on the song you would like to transfer,
click on 'show in windows explorer' This will then open up the musics file location,
have your usb drives window open in another screen and drag and drop the music file from its location the the usb drive, it will tell you how long is left of transfer, once finished transferring the notification of transferring wil then stop and close.
Select multiple music files to transfer by highlighting them and right clicking any one of them and then again completing the steps above.
2helpful
I have albums in my pc and want to transfer the albums to my nokia 97?
Not sure if you meant photo album or music album??? Here is the steps for both, music first:
Transfer music from a
computer
You can use the following methods to transfer
music:
● To install Nokia Music to manage and organise
your music files, download the PC software from
www.music.nokia.com/download, and follow
the instructions.
● To view your device on a computer as a mass
memory device where you can transfer any data
data cable or Bluetooth connectivity. If you are
using a USB data cable, select Mass storage as
● To synchronise music with Windows Media
Player, connect a compatible USB data cable, and
select Media transfer as the connection mode.
To change the default USB connection mode, select
Menu > Settings and Connectivity > USB > USB
connection mode.
This works for music, photos, or video:
Select Menu > Settings and Connectivity >
USB.
To have the device
ask the purpose of
the connection
each time a
compatible data
cable is connected,
select Ask on connection > Yes.
If the Ask on connection option is turned off or you
want to change the mode during an active
connection, select USB connection mode and from
the following:
● PC Suite — Use Nokia PC applications such as
Nokia Ovi Suite, and Nokia Software Updater.
● Mass storage — Transfer data between your
device and a compatible PC.
● Image transfer — Print images with a
compatible printer.
● Media transfer — Synchronise music with Nokia
Music or Windows Media Player.
Here is the link for your manual online:
http://nds1.nokia.com/phones/files/guides/Nokia_N97-1_UG_en.pdf
1helpful
2answers
Use my music from computer to phone
Do you want to transfer music from your computer to your mobile phone?
Connect the phone to the computer using the USB cable that came with your phone. Or transfer the file using bluetooth
How to download music to Lg 260
There are several ways and options to do that:
A.With the use of Data cable
-Use Lg260 USB datacable or an Infrared USB datacable to transfer music files that are saved in your computer. Both of this should be connected to the USB port of the computer as well as to your phone.
B.Wireless transfer between phones and devices
-First option via Bluetooth and Infrared transfer to download music from your friends phone or devices which has Bluetooth and infrared features by sharing.
C.Wireless transfer/download from PC
-2nd is using your phones Bluetooth with a USB Bluetooth Dongle inserted in your computer's USB port and is wireless.
That's it, u can download music now in easy ways.
Enjoy!
Rate this solution according to the use obtained from it. It will be much appreciated.
Thank you!
For other questions, post here....good luck!
Sep 30, 2008 • Cell Phones
2answers
Transferring mp3 files
This thing will not allow me download anything; my regular CD or music from a downloading company??
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
