Question about Xerox Phaser 3200MFPB Multifunction Printer - Monochrome Laser - 24 ppm Mono - 1200 x 1200 dpi - Fax
How do I set the time and date for the fax on my Xerox Phaser 3200MFP
    Scholar:
  • 141 Answers
From xerox.com support for Phaser 3200
NOTE: If the printer has been powered OFF for a long period of time, the date and time may need to be reset when the printer is powered back ON.
  1. Press the [Menu] button on the Control Panel until 'Machine Setup' is displayed on the top line of the Display Screen.
  2. Press the [Left] or [Right] arrow button on the Control Panel until 'Date and Time' is displayed.
  3. Press the [Enter] button on the Control Panel.
  4. Refer to the table below to enter the current date and time using the numeric keypad.
    Unit
    Range
    Month
    01 - 12
    Day
    01 - 31
    Year
    four digits required
    Hour
    01 - 12 (12-hour mode)
    00-23 (24-hour mode)
    Minute
    00 - 59
    NOTE: By default, the clock mode is set to the 12-hour mode; however, the clock mode can be modified to the 24-hour mode. See the Related Items below for additional information.
    Press the [*] or [#] button on the numeric keypad to select 'AM' or 'PM' for the 12-hour mode.
    If a mistake is made, press the [Left] or [Right] arrow button to move the cursor under the digit to be modified, and then enter the correct digit using the numeric keypad.
  5. When the date and time are correct, press the [Enter] button.
  6. Press the [Stop / Clear] button on the Control Panel to return to the Standby mode.
Posted on Aug 04, 2009
09-800 on phaser 3635 xerox how to fix
That error indicates an incompatible toner cartridge for that model. Verify you are using oem Xerox toner.
Dec 21, 2015 | Xerox Phaser 3635MFP/X Multifunction...
Fax confirmation sheet on a Xerox Phaser 6180MFP
Not quite sure what you mean here, it can be switched either on or off within the internal settings. Normally the default would be off in a large office due to wasted pages, but in "print for pay" a customer has a receipt that the fax had arrived at it's destination.
Good luck.
Jun 13, 2014 | Xerox Phaser 6180N Laser Printer
you have to set the fax receive mode to fax or ans/Fax.
Is there a toner low indication?
try to reconnect telephone cable
Memory can be to full, clear some data
May 16, 2013 | Xerox Phaser 3200MFP/N Laser Printer
How to change the time on a phaser 3635
To Set Date & Time on a Xerox 3635
Press: Machine Status (hard button)
Press: Tools (on touch screen)
Press: Device Settings (on touch screen)
Press: Set Date & Time (on touch screen)
The machine will have tabs at the top
Press: Set Date
Press: Month
Enter the Month: (Using the hard buttons)
Do the same for Day and Year
Press: Save
Press: Time
Same procedure as above setting the Date
Press Save
Turn the machine off and back on for settings to take effect.
Dec 20, 2012 | Xerox Phaser 3635MFP/X Multifunction...
Reset to factory settings xerox phaser 3250
Reset to factory settings xerox phaser 3250 - Fixya
www.fixya.com/.../t12176778-reset_factory_settings_xerox_phaser_325...
Mar 26, 2012 - A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without ...
Mar 26, 2012 | Xerox Office Equipment & Supplies
I HAVE A NEW XEROX PHASER 3100MFP AND I NEED TO CHANGE THE DAY DATE AND TIME ON THE PRINTER
you got to have user manual, if you do not have just download from www.xerox.com
Jan 11, 2011 | Xerox Phaser 3100MFP/S Laser Printer
Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer: Hello, I have a Xerox Phaser 3300MFP and there are...
Primero , apaga el sistema y desconecta la energia
Luego hay que desconectar la bateria interna que esta debajo del panel por un momento , conectas la energia sin conectar la bateria , si todo esta bien vuelves a conectar la bateria y ya no te dara mas problemas.
Oscar M
May 06, 2010 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Xerox phaser 6180 mfp error code 133-290
Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
Corrupt Adjustmen
Jun 20, 2009 | Xerox 6180MFP/N Printer
Xerox Phaser 6110
What you are listing here is the date and time refoected on the screen. Not a fault code . What this post is quoting is that the machine reset the date and time to default.
When you work around the screen see if there is another fault showing.
Feb 20, 2008 | Xerox Phaser 6110 Laser Printer
Xerox Phaser 3200MFPB Multifunction Printer - Monochrome Laser - 24 ppm Mono - 1200 x 1200 dpi - Fax Logo
175 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
