Cameras Logo
Dawn clark Posted on Nov 24, 2017
What size discharge on a Saturday s25-01 - Cameras
2answers
What causing a battery drain on 2009 Land Rover. Repaceed battery and alternator
Mostly a battery discharges because something is switched on rather than a short circuit, although it is possible damaged wiring could bridge two circuits.
If the radio has been replaced recently - some radios aren't suitable for some vehicles and a discharged battery over a period of a few days will be the result.
It would have been helpful if you had told us the size of the battery (amp/hour) and how long a fully charged battery takes to discharge?
This would allow us to determine the approximate size of the discharge, though this can and should be determined by connecting an ammeter in series with a battery lead - if a thorough visual inspection reveals nothing, the discharge will clearly be seen on the meter so the fuses can be drawn in turn until the discharge disappears and so the guilty circuit will have been discovered. The next stage will be to investigate everything on that circuit...
It is unwise to delve very far when troubleshooting electrics on a modern computerised vehicle without reference to a wiring diagram.
My phone got discharged on Saturday and I put it on charging on thursday. now the phone doesn't switch on. what should I do now?
First, clean the battery and battery slot connection, if it still doesn't work.
Do you have a charger or cable which can supply power to your phone directly? try if you can turn on your phone with the cable.
If so, it seems you need a new battery
Black smoke from exhaust
$1500 spent on what , if I may ask? Obviously a rich mixture, but need to know what was done for $1500, plus year , make and model of Chassis, and engine size.
This is my second mower. First one damaged after hitting a rock. My replacement mower will not discharge grass out of the side discharge. I have the mulching attachment in and the discharge chute as...
it could be a low lift blade on it. try to get gator blade for mulching..... or a high lift blade. lol, size does matter!!! this may fix the issue. there is so many blades out there now, experiment till you find what your looking 4......
Is there any service center in nagpur m.s.india for htc viva touch
Address: Shop no-42Jia jawan market,Near apna bazar,sec-17,vashi
Tel: 022-67919116, 67912065
Office Hours: Monday to Saturday : 10:00a.m. to 6:00 p.m.
2nd Saturday, Sunday and Public Holiday - Closed
Address: shop no 02, Vishwakarma Bldng no.05, Ambali road, vasai west
Tel: 0250-6588494
Name: Salora Int'l Ltd
Address: 384,dongre bldg,lamington road
Tel: 23886570/23861930
RT Outsourcing Services LTD.
Mahajan Compound, Behind Union Bank,LBS Marg, Vikhroli
(W),Mumbai -400079
(+91-22-65247595;92)
Monday to Saturday : 9:30a.m. to 5:30 p.m.
I want to dig a pit for the backwash off my iron filter. How deep, big around, how many levels of crush how many diffrnt sizes of crush
Great question! More people should do this! The dry well and all plumbing leading to it must be below the frost line for your area. Mine is 48". It helps to have an open vent at the point of discharge out side the home in case it may back up for any reason. You will need to size the drywell according to the discharge of your softener. A 30k softener will have about 80 gallons of discharge. Here is a great website for drywell design and capacity.
http://www.easydigging.com/Drainage/drywell_soakaway.html
I installed a drywell for softener, iron filter and sump pump discharge and it has worked great for 12 years now.
Good luck with your project,
RJ
I am having trouble connecting the discharge line
use a hose of proper size to connect to the discharge line. that must help.
take a sample to the shop. u can use a small thread to measure the dimensions.
Jul 27, 2009 • Dishwashers
Need to know what size bolts bolt together the bellhousing.
it is a 7/16 ths size bolt about two and a half inches long. i just pulled mine saturday
Size of speakers and amp recomendation for JVC KW-AVX800
you need to find out what size speakers you have now and upgrade them with that size the amp you get will be based on the rms rating of the speaker. Example if the speakers rms rating is 100 watts the get a amp that puts out between 100 and 120 watts rms also to add bass you could go with a subwoofer that will add all your low freq. If you want something that doesn't take up alot of room try a bass tube you can get one amplifed or not.
Good Luck
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
