Question about Fujitsu fi-5120C
Scanner keeps grabbing 2 to 3 sheets at a time when scanning
  • 490 Answers
You need to clean the rubber rollers with a damp cloth thoroughly.
S. Mohan
Posted on Jul 30, 2009
I want to know how to use the scanner - we have lost instructions
Instructions
    • 1 Determine if the scanner has flatbed only or ADF (automatic document feeder). Scanners with have a flat glass section for scanning, but they may or may not have an ADF. Determine if your scanner has one of those so you can scan one sheet or multiple sheets at a time.
    • 2 Place paper in respective slot. Insert the paper into either the ADF, or place on the flatbed for scanning use. Make sure the glass is relatively clean. If you're using the paper feeder, make sure the pages do not have staples or paper clips still attached.
    • 3 Press the "Scan" button or use an application on the computer that can interface with your scanner. Use this to grab the image of the documents or pictures you desire to be digitized.
    • 4 Save scanned item as you want it. Store the now digitized image to whatever format you desire (whether it is PDF, JPG or other). Keep track of where your storage location is so you may retrieve the data soon.
    • 5 Retrieve it. Remove your papers, and browse to your digitized documents.
This is picture guide visit this site.
http://www.dummies.com/how-to/content/how-to-use-a-scanner.html
May 19, 2011 | Computers & Internet
My Xerox 4150 keeps taking lots of blank pages through when printing multiple page documents sometimes 30 or 40 at a time
Two possible solutions to your problem.
If you are talking about grabbing more sheets than one from the tray, you need to make sure the tray guides are up flush against the paper.
If on the other hand you are talking about scanned/copied jobs, check the setting for your scanner, it may be set to letter size which is longer than A4, so the machine thinks it needs another sheet to complete the job causing a blank page to be sent.
Hope this helps
Jan 10, 2011 | Xerox WorkCentre 4150 Black and White...
Alienment sheet prints every time I print a page.
just put the printed alignment test page paper on scanner glass and press the scan button to complete the process. It is alignment process which is printer is doing for self testing after installing new cartridge. Just finish the process.
. It is necessary to after aligning the page it need to scan with the scanner. Otherwise it keeps pop up.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Have a nice day and do not forget to rate please...!
Mar 15, 2010 | HP PSC 1315 All-in-One Printer...
Fi-6130 not grabbing paper, displays Code: DS32002
My scanner is Fujitsu M4097D. I just have problem with ADF: Error Code DS32002: Paper jam in the ADF. Here is my solution: 1. Bend two white platin pieces down a little bit in order to "sensor" the paper scanned. This problem is occurred after I am scanning 50 thick pages. Until paper count 42, it is stopped with error code DS32002. Hope help anybody having this problem.
Jan 06, 2010 | Fujitsu ScanPartner fi-5120C Pass-Through...
How can I stop my printer automatically printing out a test page when I switch it on?
every time u switch on the printer it will print the alignment sheet until you scan it.once the alignment sheet is printed ,keep it in the scanner glass and press the scan button.this will scan the alignment sheet.
Sep 24, 2009 | HP Photosmart C5180 All-In-One InkJet...
Canon R265 keeps grabbing 6 sheets for printing one sheet
Paper has different thicknesses called Mils. Make sure you are using the correct paper for your printer. Paper that is thinner than is intended for your printer may sometimes cause it to take multiplesheets.
Jun 15, 2009 | Epson Stylus R265 InkJet Photo Printer
Canon Dr-5020 grabbing multiple pages
Wipe the rollers with a damp cloth thoroughly. Remove all the dust in the glass for a claen scan. The red color roller roller in the bottom needs thorough cleaning, rotate with hand gently (in power-off mode) and clean it thorughly. No solvents pls, except Isopropyl alcohol for cleaning
S. MOhan, Chennai, India
Mar 03, 2009 | Canon DR-5020 Path-Through Scanner
DR-2050C Scanner all sheets feed thru only one scans
Do you get an error message after the first scanned image? If not, check your software settings to see if you have the option of single page /multipage scanning. Some software lets the customer choose a single page scan when the SCAN button is pressed.
Check the "Feed Select Lever" to make sure it is in mutifeed position. If not, it will grab all of the docs at once.
Jul 05, 2008 | Canon DR-2050C Path-Through Scanner
Scanning sheet music
Scan all pages with GrayScal Single Page JPEG and then convert them to Multipage PDF.
Jan 22, 2008 | Canon CanoScan 8000F Flatbed Scanner
Fujitsu fi-5120C Logo
127 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
