Question about Haicom HI-405 III (SiRF III) BT GPS Reciver (Free Arkon Vent Mount): Optional Serial Data Cable for ... GPS Receiver
Dvb svaci-202 hi gd evng........... ihave a svaci202 dvb found some problum that is alredy all functions ok but i cant save antina set up i can change it but not memory that is going universal lnb after power off on
0 characters
1 Points
In the Nuvi 1300 Bluetooth controls can be found in Tools - Settings - Bluetooth.
In this screen the Bluetooth communication mode can be switched on/off by pressing on the Bluetooth menu entry. Press Off and Save to store this setting.
Also existing (paired) connections with a cellphone can be dropped by pressing the phone menu entry and press the delete button.
Jul 10, 2011 | Garmin nuvi 1300 Car GPS Receiver
Hi i have accidently deleted the voice navigation from my navman 550 sat nav and cant get it back ihave tried reset can you help
Is it Possible you have turned off the volume?
Here is how to check the volume setting:
From the Main Menu screen, tap Preferences.
The Preferences screen will display.
2. From the Preferences screen, tap More Preferences.
The second Preferences screen will display.
3. On the second Preferences screen, tap Hardware.
The Hardware screen will display.
4. From the Hardware screen, tap Volume.
The Volume screen will display.
5. To increase volume, move the Volume Level slider towards High; to decrease volume,
move the Volume Level slider towards Low.
• Tap Test to test the volume.
6. Tap Save.
The Main Menu screen will display.
Jun 06, 2011 | GPS Devices
Override code cant rmember my pass word
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Mar 29, 2010 | Panasonic Strada CN-NVD905U GPS Receiver
It says . cant unlock maps.
Follow this below
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
May 18, 2009 | Garmin Nuvi 255 GPS Receiver
Cant change time on gps
the time and date should set it self when you turnit on, as long as the unit was designed for use in your area then it should set to the right time.
Apr 05, 2009 | Sony NV-U73T GPS Receiver
GPS does not have maps
I had the same problum , it showd the car but no roads . My maps where on the sd card , dont know how it got there !!!! when i put it back in it worked ok
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Tomtom 720
New version of software (8.010) takes the compass preferences away. Compass always pointing north is available through the status bar settings. Found this on tomtom support under question, "How do compass settings work?" It has both new and old versions of how to access the compass.
Nov 09, 2008 | Tomtom ONE GPS Receiver
Change time setting on garman gps
to change the time or restore it to normal.
in the main screen press on the tool icon or settings icon
in the settings screen select time
in the time settings you can press on Restore settings
to restore the original time or change it from the time zone
setting, you can also change the time format and daylight saveings on the same page.
Jul 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Nav-cam 6200
Delete map, then re-install from cd . drag and drop do not use install program
Mar 07, 2008 | Evesham Nav-Cam 7700 GPS Receiver
GPS Devices Logo
46 people viewed this question
Top Haicom GPS Devices Experts
Are you a Haicom GPS Device Expert? Answer questions, earn points and help others
