Put in new toner and still tells me toner life ended. Printer is Brother 3740.
  • 40 Answers
Change drum unit, not toner
Posted on Jul 30, 2009
Toner life end message despite new toner
. To reset the "Toner Life End" message on the Brother MFC-8460N Open door press Clear/Back key
Apr 22, 2014 | Brother MFC-8460N All-In-One Printer
Brother MFC-9440CN Laser Printer is saying toner life end and I just put a new cartridge in.
If you want to reset your Brother MFC 9440N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 9440N should be reset and the Toner End of Life message should disappear. Warning, this may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Nov 11, 2010 | Brother MFC-9440CN Laser Printer
I am changing the ink cartridge i put the new one in and it keeps saying End of life and it has a new cartridge what do i do
Here is the solution that will reset the count and allow your fully functional toner cartridge (the one the printer tells you is empty) to continue to work.
Open the front cover.
Press options button.
Press the start button.
Press + or up arrow button 10 times.
Press set button.
You have to do this with a long pause or the system will reset and you will have to start over.
Good luck.
May 24, 2010 | Brother DCP-7020 All-In-One Laser Printer
The toner life ended and then we got a refill. Earlier on refill, It was working fine, But this time it still says , TONER life end, replace toner. We tried loading 2 different refilled toners and cleaned...
we can refil toner many times but we should reset cartage, while we refiling toner to open cartage we should sides white rings middle plastick flate white plate make adownof cartage it is first methode. when we put reffiling cartage put on printer and do on at that time we push cartage right side pointo re set. look on www.brother.com
Nov 05, 2009 | Brother MFC-7820N Printer
TONER LIFE END BUT TONER IS NEW
first print out a help page. i beleive that this is in the reports section, scroll down to drum follow the promps the same for toner good luck brother sr tech
Jan 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
Toner
what you do is unplug it from the wall for 10 sec.-1 min. and that should fix the problem
Sep 18, 2008 | Brother MFC 7420 All-In-One Laser Printer
Toner life end
Try removing the new toner cartridge from the machine, and shake it up and down and sideways, over a newspaper. Then, put it back in the machine and see if that helps. Sometimes, especially if the new cartridge was exposed to high temperatures or humidity before you got it, the toner SETTLES inside. Shaking it up can usually help.
Jul 06, 2008 | Brother MFC-7820N Printer
Toner life end message flashes
did you reset the toner life?
open the front cover, press the option button, on the screen will display ''reset toner life 1 yes 2 no ''
press 1 and close the cover.
toner life reseted
May 06, 2008 | Brother MFC-7820N Laser Printer
MFC 8460N giving Toner Life End message
I just solved my own problem. Try it for yours. I had been using several compatible toners for the MFC-8460N with no problems until today, as I posted earlier. On a hunch, I went to the local office supply store and purchased one original Brothers TN550 toner and put it into the printer and closed the cover. Everything clicked. Toner End Life message gone. I then took that Brother toner out and put the compatible one back in and still everything was fine. Am keeping the original Brother toner as a "kickstarter" if it happens again.
Mar 10, 2008 | Brother MFC-8460N Laser Printer
483 people viewed this question
jasbo
jasbo
