SOURCE: Bought a Onix 2gb from Aldi no instructions how do
The Onix Mini Coupe I works just like a flash drive ... I am only running W2K ... I plugged it in and it was recognized ... copy mp3 files to the drive that appears in your list of disk drives. (just at the lowest (root) level). It works fine.
SOURCE: Bad Printing and Stripes on Printed Sheets on HP 1100A
It isn't a fuzer problem it is most likly a image drum problem. To fix you have two choices replace the image drum with a oem part or a refurbished part or replace the printer. sometimes it is cheaper to get a replacement printer than to replace this part.
SOURCE: I have no idea how to charge the battery
If it has no obvious battery connections, then hook it up on your USB cable and see if you computer will do it. Mine does.
SOURCE: how to print #10 envelopes
Here's the link to the Lexmark website to download the Lexmark C543 User's Guide. http://www.lexmark.com/publications/pdfs/2007/c54x/v14841473_en.pdf. There are two ways to print #10 envelopes, using the Multipurpose Feeder or the Manual Feeder. If you don't have the Mulitpurpose Feeder, you have to use the Manual Feeder and feed the envelopes one at a time. Scroll to Page 44 for MPF instructions or Page 46 for Manual Feeder instructions. Hope this helps.
SOURCE: MP3 Player, ONIX from Aldi,
The MP3 player is charged using the supplied USB cable. connect the player to this cable and plug it into a computer's USB port when the computer is running.
