Question about Kodak EasyShare C743 Digital Camera
Kodak easyshare camera was dropped by my son and it won't turn on. I recharged the battery and when installed lens opened and then closed and camera turned off. Is there a fuse that could have gone bad?
    President:
  • 2,761 Answers
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 15, 2009
  • Bill Buchsbaum
    Bill Buchsbaum Aug 16, 2009
    The drop likely bent the lens tube or lens mount, and their is no DIY fix. You can check the Kodak troubleshooting guide at the link below, but it will tell you to send the camera in for repair.
    http://www.kodak.com/global/en/service/r...
SOURCE: Lens stuck open
Hi! Sounds like we have the same problem but mine says lens error 221,0,0,0 and my daughter dropped mine. If i dont get an answer soon, im sending my in for repair, it will only cost me $50.00. Here is the website incase you want to fix yours :) WWW.Kodak.com and just click on the repairs and services. Good Luck!!
Posted on Sep 06, 2007
jrw4u
  • 62 Answers
SOURCE: lens won't come out (Kodak EasyShare C613)
i have the exact same camera
you can hang it up and get ready to buy a new one because its not a do it yourself job and it would cost more to have it fixed than it would to buy another one just like it
Posted on May 01, 2009
  • 52 Answers
SOURCE: The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
Posted on May 16, 2009
  • 11967 Answers
SOURCE: Kodak easyshare lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move. The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason. A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth. Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods. The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired: Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on. Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time. Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera. Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one). Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes. Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens. Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 06, 2010
  • 94 Answers
SOURCE: Kodak easy share c182"lens error 211" will not
The lens has been knocked, probably not worth rpair due to low replacement cost - do you have household contents insurance ?
Posted on Jun 09, 2010
Kodak m1063 lens stuck closed won't open
I suggest you take your camera to a digital/Kodak camera repairer.
Apr 18, 2013 | Kodak EasyShare V1003 Digital Camera
Easyshare m1063 starts up lens opens then closes turns off camera
Here are some troubleshooting steps that you can try that may (or may not) correct your problem. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them. By the way, I'd focus on trying Fix #1 first by your symptoms (how old is your battery? Rechargeables aren't meant to last forever.):
And here's a video summary of the steps:
Dec 10, 2011 | Kodak EASYSHARE M1063 Digital Camera
The camera was on/lens out when my son dropped the camera. Since then when I try to turn it on it opens but immediately closes. Any ideas?
This is a long shot, remove battery and the memory card, press power and hold for 30 seconds to drain off any residual charge. Now put the battery and memory card back in and press power, if it works the camera has managed to reset itself, if this fails probably cheaper to replace it.
Feb 04, 2011 | Kodak EasyShare M530 Digital Camera
Does this camera operate on regular AA bateries. Put 2 brand new ones in and it will not power up. The manual says Kodak does not "support" Alkaline batteries....
Probably this old chat may help you to resolve your problem.
From site:
http://www.digitalcamera-hq.com/products/kodak-easyshare-c663
Kodak EasyShare C663 Specifications
  • 6 megapixels
  • 3x optical zoom / 5x digital zoom
  • autofocus
  • auto exposure
  • JPEG file format
  • ISO 100-400
  • 2 AA batteries
  • movie mode w/sound
  • 2.5" LCD screen
  • Part Number:C663
  • Release Date:Jan 12, 2006
chrissy66 (12/10/2007)reply to this comment (by James DeRuvo - 12/12/2007)Sounds to me like your lens may have come out of alignment. Was it dropped recently? Since your camera is still under warranty, the best thing you can do is have Kodak should fix it. If your camera is out of warranty, or if Kodak refuses to repair it for free, the one thing you can try is to try resetting the camera.
Kodak is also of the opinion that lens errors also occur when you use batteries not recommended by Kodak.
I recently chatted with a kodak specialist about this issue and he recommends changing your batteries to NiMh rechargeable batteries. These are the batteries that the camera is designed to use and using other types - like alkalines, can often cause the lens error to occur. If that doesn't work, then the camera indeed does need repair.
Rechargeable Ni-MH Batteries (AA Size): These Ni-MH AA batteries last up to twice as long as alkaline batteries when used in your Digital Camera - and you can recharge them up to 1000 times in our rapid charger.
Oxy-Alkaline Digital Camera Battery (AA Size).
CRV3 Lithium Batteries: A non-rechargeable battery designed specifically for today's feature-rich cameras. This battery is the obvious choice for speed performance, and long life. It delivers faster flash recycle times and lasts up to 10% longer than our previous design!
Ni-MH Rechargeable Battery Pack: Provides exceptional capacity with its 2.5 hour fast charge cycle time; can be recharged up to 1000 times in the EasyShare Camera Dock or EasyShare Rapid Charger,
Jan 06, 2011 | Kodak EasyShare C663 Digital Camera
When I switch my camera on it will not focus - my
Did he drop it while it was being used?
Also, I assume that you have fresh batteries.
Why doesn't the lens retract when I turn off my camera or extend when I turn on my camera? Question : Why doesn't the lens retract when I turn off my camera or extend when I turn on my camera? Answer : The batteries may be low or exhausted.
NOTE: If the batteries run low on power, your camera may turn off without retracting the lens. In most cases, this is normal and can be corrected by recharging the camera batteries.
In the U.S. and other countries where the Step-by-Step Solutions and Repair tool is available:
  1. Recharge the batteries or install new batteries.
    NOTE: Rechargeable batteries can be charged in the following ways depending on the camera:
    • Remove the batteries and place them in an optional battery charger.
    • Place the camera in a printer dock or a camera dock.
    • With the batteries installed, connect the camera to an AC adapter or to a computer using a USB cable.
  2. For more information, go to KODAK Product Manuals, and select the User's Guide for your camera. To see the battery charging accessories that are available for your camera, go to KODAK Accessories.
  3. If the problem persists, go to the Step-by-Step Solutions and Repair tool.
    • Select Digital camera, camera dock, or digital video camera.
    • Select Lens.
In countries where the Step-by-Step Solutions and Repair tool is not available:
  1. Remove the batteries, then wipe the battery contacts with a soft, clean cloth.
  2. Install the batteries, then turn on your camera.
  3. If this does not resolve your problem, remove the batteries.
  4. Go to Choosing the Right Battery for Your KODAK Digital Camera, then follow the instructions to verify that you are using the correct batteries.
  5. Install new or fully charged batteries into your camera.
    • With the batteries installed, connect the camera to an AC adapter or a computer using a USB cable.
    • For more information, go to KODAK Product Manuals, then scroll down to select the User's Guide for your camera. To see the battery charging accessories that are available for your camera, go to KODAK Accessories.
  6. Turn on your camera.
  7. If the problem persists, go to Eastman Kodak Company Worldwide Contacts for assistance.
Jul 23, 2010 | Kodak EasyShare C875 Digital Camera
The automatic slideing lens cover on the Kodak Easyshare C653 camera is sticking, sometimes it will open halfway than will not close. There may be sands in it from the beach. Is there any way of cleaning...
Here are the steps for the lens problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 09, 2010 | Kodak EasyShare C653 Digital Camera
I have a Kodak Easyshare C180 digital camera. I open ity, take a picture and then it closes. I then cannot get it open again. I see the on/off button but nothing happens
Is the camera LENs won't retract? Try to use a brand new different recomended batteries like alkaline batteries or lithium batteries. If your using a rechargable batteries make sure that they are fully charge. You can also try to turn the camera ON without using memory card. Remove the memory card on the camera. Then put a new recomended battery, try to turn it ON if the camera will not turn ON or stay ON call kodak support line. Support in English and Spanish is available at 1-800-235-6325 (23KODAK)
Nov 15, 2009 | Kodak EasyShare C180 Digital Camera
Kodak Z885 will not power on
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Apr 30, 2009 | Kodak EasyShare Z885 Digital Camera
CAMERA TURNS ON FOR A SPLIT SECOND THEN SHUTS OFF
My Z1275 was off with the lens open. When I turned it on, the lens moved a little, the screen came on
for an instant, and then the camera off.
Here is what I did to "fix" it.
I turned it on and helped the lens (gently) close while it was moving. It closed and the camera came on.
It must have been dropped and slightly bent in such a way where the lens could not close.
Good Luck!
Dec 29, 2008 | Kodak EasyShare Z1275 Digital Camera
Camera won't work after being dropped in toilet
http://www.fixya.com/support/r3771170-phone_water_damage
Oct 07, 2008 | Kodak EasyShare Z730 Digital Camera
Kodak EasyShare C743 Digital Camera Logo
146 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
