Question about Microsoft Xbox 360 Console
When i put my disk in the tray and try to close it it opens back up
Make sure there isn't anything keeping it from going al the way in. i had the same problem with the original xbox.
Posted on Jul 30, 2009
SOURCE: disk tray won't stay closed
i have same problem with mine, if i close the tray quickly by hand after it re-opens,it usually starts reading the disc
Posted on Jun 16, 2008
  • 6 Answers
SOURCE: Xbox 360 disk tray wont stay shut
My 360 is/was having a similar problem...my 360 would say "reading disc" then "open tray". Well since my system is only about 8 months old...I opted to send it in for repair. Its under warranty. My system is in route to be fixed as we speak. I would advise you to get yours registered too.
Posted on May 28, 2009
  • 133 Answers
SOURCE: Disk tray stops spinning disks
You need a new laser. Thats the only fix
  • 34 Answers
SOURCE: I turn on my xbox 360 and it says open tray and wont read disc
I have had this happen about 3 times. The first time was when i figured out how to fix it. The 2nd and 3rd were temporary.(Just needed to be turned off for a moment) You need to shut the console off for atleast 15 minutes 10 at the lowest with everthing unplugged. I mean the hard drive, memory unit, and all cables, and adapters. Then after 10-15 minutes plug everything in and DON'T PRESS the BUTTONS ON THE XBOX OR THE CONTROLLERS. Press the button to open the tray and take out the game or dvd and put in a different one. If this doesn't work do it all over again and then put in a different game or dvd not the previous ones and turn on the console the same but then a soon as you get the disc in and closed in shut it off then open the tray and wait till you are at the main menu go into any program so you can't see it is reading and close the tray. If that doesn't work contact the xbox support line. Really hope this works for you.
Posted on Jun 23, 2009
XboxRepKit
  • 168 Answers
SOURCE: open tray message when closed
This is more than likely your laser that is dead and its possibly a samsung or hitatchi drive, be careful when buying a new laser because there is a lot of dodgy ones around at the minute which can damage your machine or at the very least will be inferior and not last long.
It could also be the logic board or the drive belt too, if the logic board is faulty no matter how many lasers you try it will do the same, the fix is to replace the logic board.
if its the drive belt well this is very easy to try and is what id try first, open your 360 tray and look inside the 360 you should be able to see the drive belt, make sure its attached properly and then take this out. replace it with a new one and see if this recifies your problems.
SOMETIMES if a drive belt is stretched it will not close properly and then a fault like yours will occur. its all a matter of eliminations. Drive belts can be found on ebay.
www.XboxRepairKit.co.uk
Posted on Sep 26, 2009
The disk tray will not open
Try slowly opening it with a flathead screwdriver. Get the tray open enough to put ur pinky in and try to remove any disk(s) that are in there. Plug it in and turn it on. If the tray closes ur system should be ok and try to open it with the button. If no good. Then try agian, but this time slowly open it all or most the way, then plug it in and let the drawer close and see if the button works to open and close it.
This is ussaly caused by a jam from either a incorrectly inserted disk and it jammed the tray. Or the gearing that is connected to the motors jamed up and the tray needed to be moved out to unlock the jam.
Closing the tray with ur hand and not pressing the button to close it also could of caused this problem
Oct 25, 2010 | Microsoft Xbox 360 Console
My Xbox 360 isn't reading any discs. Games nor Movies. When i put either in the game console it tells me to open the tray because it didn't read.by the way it makes a funny noise when it tries to read the...
take out the cd. close the tray with no disk in it. let it read till it says open tray
open and close it like 3 times with tha method mentioned above with out the disk. then put the disk back in and it will probly work.
sometimes the system turns dumb and u haft to remind it to reconize when there is actally no disk.
Why does my disk tray not close? I put a disk on it, press the open/close button, and 3 seconds later it opens by itself...how do I fix this?
Its possible that the tray has slipped a tooth on the gear on which it runs. Try opening up the disk player and removing the tray, then replace it after turning the drive gear which ejects the tray, back one or two teeth.
Best wishes,
Graemevm
Apr 18, 2010 | Northgate (WALAMD250A) PC Desktop
Open tray comes up when loading a game?
Try tapping above the disk drive or if that doesn't work open the tray take your disc out close the tray. open the tray put ur disk back in and close the tray again.
Mar 15, 2010 | Microsoft Xbox 360 Elite Console - Black
Game does not load keeps saying open tray,close try.
This has happened to me multiple times, but sooner or later, it will load, just keep at it. Try taking the disk out and closing the tray, then open and put the disk in and close the tray.
Dec 05, 2009 | Microsoft Xbox 360 Console
I put a blank CD into the tray to record. It
If there is a tiny hole somewhere near the tray you need to poke a needle or something like that in there to open the tray.
Dec 02, 2009 | Philips CDR785 3-Disc CD Recorder
Disk tray opens and closes repeatedly
WHEN IT OPENZ PUT THE DISK IN ND IMMEDIATLY TAKE THE POWER PLUG OF WAIT A SEC ... RE PLUG ... RESTART THE SYSTEM AND OFF YOU GOOOOOO
Jan 18, 2009 | Sony PlayStation 2 (PS2) Console
360 disk tray
What I did was took apart my Xbox and put the disc tray back on the tracks, carefully lifting it over the circle thing in the middle. When I lay my Box down horizontally, it opens and closes fine.
Jul 27, 2008 | Microsoft Xbox 360 Console
Always opening disc tray
3 things cause this:-
A Damaged Disk, A Dirty Disk, or a Hardware fault.
Below is Microsoft's doc on the issue.
http://support.microsoft.com/?scid=kb;en-gb;816779
If my advice was helpful, please vote for me!
Nov 16, 2007 | Microsoft Xbox 360 Console
My xbox wont stay shut
push it in until it closes .i know it sounds crazy but it worked for my ps2. i dont know about xbox though.
Nov 13, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
