Question about Daewoo DWC-056CL Air Conditioner
Water in base pan of my daewoo dcw 055rl
Water in base pan of my daewoo dwc o55rl . I am wondering if a couple of holes at the base of the unit will do the trick. That way the water drops to the ground in stead of the window. Any comments??
5 Suggested Answers
  • 69 Answers
SOURCE: I need to replace the plug on my Daewoo DWC-055RL Air C
You should be able to get this item at most hardware stores they are very generic. just take or draw a picture of the plug end there are only about 3 styles
Posted on Dec 24, 2008
  • 252 Answers
SOURCE: I have a daewood nano
Your clock board is bad. This happens when moisture from the outside gets into the electronic circuit board. This is common with your model of AC.
Posted on Aug 19, 2010
dburns60
  • 410 Answers
SOURCE: i have a Daewoo Air
features Cooling Capacity 5,340 BTU/h 10 Energy Efficient Rating Cooling Area (sq. ft.) 100 to 150 Low Noise Operation Washable Air Purifying Filter Effective Dehumidifying Operation Indoor Temperature Sensing Thermostat Window Kit for Easy Installation Power Supply (V/Hz): AC 115V/ 60Hz Power Consumption: 525 W
Answer = yes regular 115 vac outlet
Posted on Aug 21, 2010
SOURCE: i have a daewoo dwc 055rl air conditioner and i
Hello, I have a brand new AC of that model, in the box with remote that I'd be happy to sell. That way you could have two AC units and a remote. I'm in Laguna Beach, CA.
Thank you,
Russell
rboston@gmail.com
Posted on Sep 22, 2010
How to Remove the grill on my deawoo Dwc-055rl air conditioner
at the lower outer edges of the grill you will find indents
place your fingers at these points and pull out and up
the grill will lock up while you attend to the filters
closing is just pressing down on the grill until is clicks into lace
Jul 18, 2016 | Heating & Cooling
Where is water exit
window units have a slinger ring on condensor fan. it throws the water onto the condensor and evaporates.
Jul 29, 2015 | Daewoo DWC-056CL Air Conditioner
What is the amperage draw on the Daewoo a/c model # DCW f0520rle?
According to Daewoo, the amperage draw for that Model A/C unit is 4.6 amps
Hope this helps you. Please let me know.
May 16, 2011 | Daewoo DWC-150C Air Conditioner
I have a Daewoo Air Conditioners dwc 055rl can i plug it into a regular wall outlet
Aug 21, 2010 | Daewoo DWC-056CL Air Conditioner
Water leaking from base of unit during operation
dehumidification is something that AC units do as a by-product of cooling so yes, it is acting as a dehumidifier. there is a coil (copper tubing snaking back and forth through metal fins like on a radiator) that water condenses on and drips off of. That water will fall in to a pan and then will either evaporate or run through a drain. Make sure the path from the coil to the drain pan is clear. The water will either drip down (pan sloped to a corner or hole) or run through a tube to the drain pan. The drain pan is the part that had the drain plug in it. If that pan was dry the condensate is reaching the pan. If it is full that means either the drain is plugged up or the unit is pulling humidity out of the air faster than it can evaporate. Check to make sure any drain tube is clear and that the path for the condensate (water) is sloped the right way - not shaken loose or tipped to the wrong side.
That should get you started. Let me know if I can be of any other help.
Good Luck!
May 26, 2010 | Haier HPC07XC6 Portable Air Conditioner
I have a daewoo dwc 055rl air conditioner and i need a new remote. do you know where i need to go to replace it?
Thank you,
Russell
rboston@gmail.com
Feb 12, 2010 | Daewoo Heating & Cooling
Dec 23, 2008 | Daewoo DWC-056CL Air Conditioner
Cleaning a daewoo
You usually grab it by the front and pull, but there might some screws holding it in.
Jul 24, 2008 | Daewoo DWC-073C Air Conditioner
Daewoo (DWC-056CL) Air Conditioner
You don't have to remove the polystyrene that is inside the unit. It is part of the construction of the unit. It is part of the molded construction.
Jul 02, 2008 | Daewoo DWC-056CL Air Conditioner
Daewoo DWC-056CL Air Conditioner Logo
136 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Dan Webster
Dan Webster
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
