Question about Furuno 520 5psd Plastic Thru Hull Transducer 600w
My problem is I bought a 600l furuno and it came w/a thru-hull transducer and I wanted a transom mounted trans.I all ready bought a tr/mount and I need to sell the thru/hull.It's the 2" w/speed and temp and I would like 125$.My name is Scott I'm in Tampa (813)416-1680
    New Friend:
  • 132 Answers
I will exchange this for you, free shipping no charge, just ship it to me to inspect and i will send you the transom ducer no charge, if you have a bronze thru hull with speed and temp to trade for a plastic transom mount with speed and temp, let me know
Posted on Jan 16, 2010
Can a inside the hull transducer be used as a transom transducer.
You could use it but you may not get accurate readings, best to get a transom transducer of find a way of mounting the one you have inside the hull?
Nov 06, 2017 | Boating
Just got an Eagle Fishmarkde pathfinder need help w/mounting transducer to motor at end of shaft. If that is possible?
Hi Mike
The transducer (depending on which one you have) should be mounted to the hull of the boat. If a transom mount, at the back of the boat of course and if a through-hull or in-hull ducer in an area that provides good contact with the water at all times.
You shouldn't mount the transducer on the motor.
I was unable to find a reference anywhere to the Fishmark DE.
-Steve
Mar 13, 2015 | Eagle Boating
Installing transducer
I assume you're talking about a transom mount transducer. Best if the leading edge of the transducer is even/level with the hull and tilts slightly down in the back or trailing edge of the transducer. Also try to eliminate a gap between the leading edge of the transducer and the hull.
Mar 25, 2014 | Hummingbird Boating
I was told that the Uniden QT-206HP depth sounder will not work thru an alunium hull is this true or false
Hi!
The transducer for your depth gauge will not work through an aluminum hull. A drilled through-hull transducer or a transom mount transducer are your options here.
Just in case you require it, your Owners Manual can be viewed/downloaded at:
http://ca.binnacle.com/pdf/Uniden-QT206-manual.pdf
Hope this helps..
Jun 20, 2011 | Uniden Qt206hp Digital Depth Gauge With...
Does this transducer mount in the floor of the boat,or on the bottom of the hull?
Hi!
This transducer requires a hole to be drilled in the bottom of the hull and the unit installed from the outside, using a caulk/adhesive such as 3M 4200 or 5200. Nice choice. Furuno is a good manufacturer!
Hope this helps!
Dec 24, 2010 | Furuno 520 5psd Plastic Thru Hull...
Can not get clear reading of bottom when travellling over 9 knots
Your in hull ducer is getting turbulence. (in hull or not) A transducer will stop working is the tiniest cabitation or air bubble interferes. If possible, relocate the ducer. If you have a transom mounted ducer, try angling the leading edge up. This is a 90 % chance caused by turbulence on ducer. The other possibility, al;though remote is that you alternator or ignition system is interfering after a certain RPM on the motor.
Try first to manually gain the FCV620. You will always need to manual gain set the unit if you have an in hull ducer.
Mar 02, 2010 | Furuno 520 Ihd Adj In Hull F/ 6000 600l...
My furuno depth finder gives me crazy depth readings after i go over 10knots..whats the problem?
Turbulence on the transducer is almost certain. If transom mounted, **** it slightly deeper aft and ensure that the leading edge is not exposed. If through hull, call me 847-746-0100
Nov 03, 2009 | Furuno 1850WF Gps Fish Finder Combo...
Furuno sounder trandecer problems
the leading edge of the ducer should be higher than the aft portion. The leading edge must not be below the bottom of the transom. To determine if it is turbulence or radiated interference, put the boat in neutral and run motor up in RPM, if it fails then, with boat stationary, then proximity to motor is a problem and you should buy and in-hull ducer. glueing the transom ducer may or may not work well.
Aug 27, 2008 | Furuno GP7000F/NT GPS Receiver
Furuno 520 5psd Plastic Thru Hull Transducer 600w  Logo
150 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Are you a Furuno Boating Expert? Answer questions, earn points and help others
