Question about Kwikset Brz Sgl Cyl Deadbolt
Installing a deadbolt in a steel door. need to find the best/easiest way to get the plates recessed. using a cold chisel is a huge pain. hopefully thats not the only way. unless i'm doing it wrong.
  • 864 Answers
A really, really, REALLY sharp chisel can be used to pierce the steel door skin enough to form the mortise you need for the bolt plate. Do not use a wood chisel unless you never ever intend to use it on wood again or have the means to completely renew the cutting edge. Cutting the opening for a plate in a metal door jamb is another issue since it is probably too thick to yield to a chisel. If the jamb is 1/8 to 1/4 inch thick you can just drill a hole in it to accept the extended bolt. it will be just as strong as a plate (maybe stronger.)
Posted on Jul 29, 2009
Key will not come out in unlocked position
I presume you figured it out by now, but if the tailpiece is installed wrong in many deadbolts, the key won't come out in one position or the other. It's called a "timing" problem and the way to fix it is to take it off the door, turn the tailpiece a half circle and put it back on the door. Usually Kwikset locks are designed so you can't put it in the wrong way, but it can happen. (If it's not the timing problem, then the deadbolt unit is defective or broken. They are designed to fail in a way that keeps them locked, so this could be a sign that someone tried to break in, or that someone used the extended bolt as a way to stop the door from closing and it hit the door frame too hard.)
The best way to install a deadbolt lock without the instructions handy is to look at the "lazy" cam and see if there is a way to install it wrong and don't install it that way. Example: If there are 2 ways for the tailpiece to fit in the deadbolt unit when the deadbolt is retracted and only one way for the tailpiece to fit in when the deadbolt is extended, then install the lock with the deadbolt extended and you can't install it wrong.
Jan 05, 2014 | Kwikset Locks & Locksmithing
How to change baterry o schlage be365
To change the battery on the BE365, you need to remove the inside cover by removing the two screws (one above and one below the deadbolt knob). Be careful to tuck the wires inside the lock so that they will not be crimped when you put the cover back on.
Do you here a beep and see a flashing light? Usually if pressing the Schlage button unlocks the deadbolt, your installation was done improperly. The cam on the base plate must be vertical and the bolt must be correctly installed.
You will always be able to lock and unlock the deadbolt with the inside thumb knob.
I hope this helps.
Dec 04, 2013 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
I have extreme difficulty locking the deadbolt with a key or the interior latch. I have to pull up on the the door knob, below deadbolt and still have difficulty. It loosens the door knob from the...
Doors often sag downward just from use and gravity. This causes a misalignment of the bolt and the keeper (hole the deadbolt goes into) causing binding and dragging whenever you lock or unlock. You are correct that leaving this unfixed will quickly damage the lockset and be much more expensive to fix. A solution to the immediate problem is to lower the keeper to match where the deadbolt lines up. If you are semi-handy with tools you can probably do this yourself.
Extend the deadbolt with the door open. Push it against the door casing and mark above and below it with pencil. You should be able to "eyeball" it and see the problem by lining up the marks with the keeper. Unscrew the metal keeper from the jamb. Transfer the marks as close as possible from the casing to the jamb (surface where the keeper was). You will need to fill the old screw holes with wood because, when you remount the keeper, the new holes will be close to the old ones. You can use a sharpened popsicle stick, matchstick, toothpicks - whatever - to do this. Best to use glue. Tap them in fairly tight then break or cut the sticks level with the surface. Reposition your keeper vertically to match your pencil marks and screw it back to the jamb. Hold it in place in the new position and mark the screw holes then make a pilot hole for the screws with a nail. [Be careful not to change its position horizontally or the door won't close right] You may also have to remove some wood from the bottom of the hole behind the keeper where the deadbolt rests when locked. Easiest with a hammer and chisel but can be done with a good knife or drill and determination. I haven't looked but I wouldn't be surprised to find a Utube video of this process if you care to search. Good Luck!
Sep 22, 2010 | Kwikset Locks & Locksmithing
Instructions to replace door lock assembly
Hello,(1)Open the door and remove the two screws in the door lock latch plate on the edge of the door by backing them out with a Phillips screwdriver in a counter clockwise direction.
(2)Remove the two screws (located on the interior lock face plate)holding both halves of the lock assembly to the door by backing them out with a Phillips screwdriver in a counter clockwise direction,pull each side of the lock assembly from the door,using a flat blade screwdriver to pry them off if needed. (3)Pry the latch bolt out of the door by inserting the edge of a flat blade screwdriver under the latch plate on the edge of the door.slide the latch assembly out and set aside.(4)Insert the new latch assembly into the hole left by the old latch bolt.Trim the recessed opening with a sharp chisel if the new lock latch plate is larger than the old latch plate.Secure the latch to the door with the two screws provided by turning them in a clockwise direction with a Phillips screwdriver.(5)Hold both side of the new lock assembly to the holes in the faceof the door.Line up the shaft from the lock cylinder into the slotted hole in the latch assembly.Make sure the lock face plate with the screw holes is facing the inside.Attach the lock assembly to the door by turning in the screws with a Phillips screwdriver in clockwise direction.(6)Remove the old striker plate from the door jamb by backing out the two screws with a Phillips screwdriver in a counter clockwise direction.Install the striker plate that came with lock kit with the screws provided using a Phillips screwdriver in clockwise direction.
(7)Close the door and test the operation of the lock from the inside and outside using the turn lever and the key.Make adjustment to the striker plate if needed by removing the holding screws.Reposition the striker plate and replace the screws
Thanks
May 26, 2010 | Ovens
Remove schlage deadbolt
Schlage B160 - need small screwdriver to insert at bottom of faceplate to pry cover off. Face plate appears flush, but with a penlight you can see the recess at the bottom to pop it off. Screws lie under the cover for disassembly. Seems to be a lock design improvement once you figure out how to remove the faceplate.
Feb 08, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Loose Kwikset Chelsea Deadbolt
I just had the same problem as samrpetrich with a loose kwikset deadbolt. Here's how I fixed it - on the inside of the door, take off the latch that flips the deadbolt in and out using a very small allen key. There is a round plate cover that is snapped on top of the inside deadbolt mechanism. If you look on the bottom aspect of this round plate you'll see where it snaps on; once I saw where to apply pressure it came off easily - taking off this plate exposed the two screws beneath that were loose. Once I tightened these, I snapped the plate cover back on, but the dead bolt latch back and everything is tight again. Hope this helps.
Jan 23, 2009 | Kwikset Professional Door Lock...
Door will not latch
There are a few ways you can fix this problem by trouble shooting a few things.....#1 If there is room inside the door opening, and your door still closes you can "SHIM" one of the hinges out. Top or bottom can be shimmed depending on where the latch for the door is hitting the Strike Plate. Close the door and watch where the latch is closing on the frame. If it is hitting above the Strike Plate then you can shim the Upper hinge, Shim bottom hinge if latch is hitting below Stike Plate. You can use anything Thin( as Thick as the hinge plate or thinner) a wooden shim, a piece of plastic, something to bring the honge out a bit. Unscrew the needed hinge from the wall and insert "SHIM" between hinge and wall and retighten screws. This may adjusting enough so the door will latch. You may also use this method sort of in reverse. Instead of shimming the hinge, you may be able to recess in deeper into the frame or the door, creating the same affect. You will need to remove the door and use a wood chisel to sink the hinge(s) deeper. #2 If that does not work you may have to relocate the strike plate up or down, creating a new area for the latch. Follow the same proceedure as solution #1 to see where the latch is hitting the strike plate. Remove and reposition the strike plate so the latch hits in the center of the hole in the strike plate. Mark the strike plate where the new postion needs to be and use a wood chisel to recess the strike plate in its new position. Than you can patch the old area with wood putty. I think #2 is the easiest, depending on how your wood work on the door framing is......I have used these tricks before, and I hope they can help you out......Joe
Jan 10, 2009 | Hardware & Accessories
New deadbolt mechanism very hard to turn.
The deadbolt itself is binding in the door or the door jamb
you will ned to take the pressure ofF the turning mechanism by either readjusting the strike plate(area where deadbolt goes into door jamb(wall side) OR MECHANISM IN THE DOOR
FIX
First determine if the problem in the door or when the door is closed and is binding into the wall side
FIX FOR BIND WHEN DOOR IS IN CLOSED POSITION
If it binds only when door is closed you will need to adjust the strike plate up or down at the door jamb which is easy to fix
1 open door and turn lock in locked position close door up against the door jamb and mark with a pencil where bolt hits jamb
2 open door extend the marks to see where it lines up in relation to the strike plate remove strike plate and move so that the opening of strike plate is between two pencil lines
3 insert some wooden match sticks in old scres holes( jamb them in with head of hammer
4 screw strike plate in positon
5 close door and check lock
Note:
You may have to use a chisel , flat bladed screw driver or kinife to cut some of th soe out to allow bolt to slide into jamb (if it bareley drags you can take a metal file and file it also pt some wd 40 on bolt
FIX FOR PROBLEM WITH MOVEMENT IN DOOR
open the door from the inside turn the bolt in lock and unlock position if it moves hard you will need to take a phillips head screw driver and remove the plate that covers the bolt( on the side of the door where bolt slides out of door)
After you remove the plate turn the lock in lock/ unlock position
if it is still tight loosten the two screws at the deadbolt from the inside of the door do not remove completely
bolt should not be in a bind and should move freely
If it is tight at this point you wil ned to remove the assembly(continue taking 2 screws out) once you have the assembly out you will need to pull the bolt ot of the side of the door
if the dead bolt is real tight you will need to enlarge the hole it goes in by using a round rasp or file
and check the ock manually and with a key
Good luck
Jan 05, 2009 | Kwikset Professional Door Lock...
Kwikset deadbolt
use the proper size alan wrench to tighten or loosen face plate . That is if you have not stripped that hole by putting the wrong tool to it. Under that plate is the 2 main screws to hold the hardware tight to the door.
Oct 27, 2008 | Kwikset Professional Door Lock...
Kwikset powerbolt 1000 keyless entry deadbolt lock with keypad
Make sure that the bolt hole on the jamb side is recessed enough so the bolt gets a full extension. Without this externsion the bolt will not engage the key release. So when you do your quarter turn you are actually turning more. Remove the strike plate and drill the hole deeper until the bolt can extend all the way. Also double check your key to make sure it is not spurred or worn.
Aug 13, 2008 | Kwikset Professional Door Lock...
Kwikset Brz Sgl Cyl Deadbolt Logo
403 people viewed this question
Top Kwikset Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Kwikset Measuring Tool and Sensor Expert? Answer questions, earn points and help others
