Question about NAD C372 Amplifier
My yamaha av amplifier dsp a1 powers on I hook everything right but I have no sound at all from speaker output or headphone output
4 Suggested Answers
SOURCE: Output volume has dropped in right channel
dear sir,pls check the HT voltage fuse, LTsupplay also and out put stage,and volume controle,
Posted on Feb 01, 2007
SOURCE: Power but no sound
The cables going from the pre-out to main were just loose enough to cause the problem
Posted on Apr 20, 2008
  • 88 Answers
SOURCE: No sound from my NAD C325BEE amplifier
audio ic problem or component around audio ic.. good luck
Posted on Apr 26, 2010
How do I connect my 901 equalizer /speakers to the yamaha rx-v633 receiver?
Sorry, it doesnt look like you can hook up an external EQ while still using the amplifier section of the yamaha. Instead, You would have to use the preamp out to go to 901 EQ, out of the EQ into another stereo amplifier, then to the 901 speakers. Personally, to power the 901's properly, I'd use another external amplifier. You will barley get 75watts per channel out of the receiver to power the 901's
Jan 03, 2015 | Yamaha Av Reciever Rx-v793 Cinema Dsp...
Sony STR-DH510 Multi-channel AV receiver connected to cambridge soundworks ensemble IV w/ passive subwoofer: no sound from center channel during viewing, or during speaker level test- all other speakers...
The STR directs sound to the center as instructed by its speaker setup. You say the center does not work on calibration. Is it defined?
Prove another speaker does or does not work on the center output. Then we'll know if it's the receiver or the speaker ensemble that has the problem.
Have you checked the manual for this "
There is no sound, or only a very low-level sound is heard from the center/ surround. "?
Aug 03, 2010 | Yamaha DSP-A1 Receiver
No sound at all. Power is on and all lights light up, but so sound output regardless of speaker selected or input.
I do not have experience with this particular amp. Generic trouble shooting follows:
Might it be that you have headphones plugged in? (Unplug them, they turn off the speaker output) You are absolutely certain of the settings on your amp? (check them again) Are you certain you have an input? (AM, FM, CD, AUX, other) (Make sure the input is turned ON and the source is properly selected.
Is the output protected by a fuse or fuses? (look on the back panel for fuses or fuse holder)
Everything that is suppose to be plugged in IS plugged in ... all cables are intact? Did you check them for contunity? You can check contunity with a flashlight battery, the light of a flashlight and a paper clip.
Speaker selection switches are pressed as appropriate. Speakers are connected to the appropriate outputs and they are ON. Speakers are of proper rating - and resistance? 4 ohm - 8 ohm - 16 ohm??? Any controls on the speaker are set at a neutral setting?
I'm sorry your device is not functioning as you think it should. These things are designed to work and generally, they are pretty good at it. Sometimes, they just break (stop functioning) It may be that you will have to take it back from where you got it for repair or adjustment. But I am hoping you have the headphones plugged in.
Thanks for your interest in FixYa.com
Dec 26, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Standard speakers to the computer , low volume
You are getting low volume because there is no amplifier in those speakers. Computer speaker sets are powered -- there is an amp in one of them them which drives both speakers -- a computer audio output without an amplifier will only satisfactorily drive headphones.
May 11, 2009 | HP Compaq JBL Pro (401508-001) Computer...
Yamaha Dsp-A1000 5 ch amp Bought a used amp will be hooked to an awia reciever and speakers also have two subwoofers need help to install correctly witch connections to use
if you wanted to use your receiver as your controller and source then try to find out the receivber has got a bridge (jumper) between the pre-amp stage and the power amp stage. if your receiver does not have that, then you can just connect your receiver tape record out to one of your DSP inputs. subwoofers, the DSP has got a sub woofer out connector. you can use that (RCA type) to your sub woofers. put in series because DSP has got only one output for sub. or, you can connect your subs directly to the mains speakers, parallel connections. maybe one sub to your left and the other to your right channel.
Jul 24, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Auto Shut Off After 3 Seconds...?
either your DSP output stage already damaged or maybe your speakers. have it both chekced for short. or worst both of them. DSP A1000 can drive as low a 4ohms on main channels but how is the power handling of your speakers? are you sure it has not exceeded the capacity of the speakers? or maybe you have over driven the speakers and they are still ok but your amp gut busted due to over drive. If the DSP amp is busted then it is due for replacement of power transistors and drivers. you can not disable the protection circuit. at least the design. it can be disabled by a tech person with a lot of modifications but i wont go for that or it can cause more damage to your equipments. i am from yamaha before and i have made conversions of protection circuits but it is too risky.
Jun 13, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha dsp-a1
you need to set the ntsf or pal settings for hdtv and s-video is video1 video 2 or video 3 seting on input on remote
May 13, 2008 | Yamaha DSP-A1 Receiver
Very low sound in main left chennel.
disconnect the cabel of left channel from your amp disconnect the cabel of right channel and put it in place of left channel if the problem goen your problem is in left speaker itself (cabel or speaker).if the problem excit the problem will be in amplifier output stage
Jan 28, 2008 | Yamaha DSP-AX1 10-Channel Amplifier
Av amplifier
The display problem is because the solderings on the back of the display are broken. To fix it you have to open the amp and redo the solderings (there are about 50 or 60 of them). There is a Youtube video that shows how to do it. I have fixed this on my DSP-A1.
I also have the problem with the motorized volume control. I have tried cleaning it, and it works for a few days, then it's stuck again. I guess I will have to replace it to have it fixed permanently. The part number is VZ621400, a new one costs about 40$.
Jan 07, 2008 | Yamaha DSP-A1 Receiver
DSP-A1 Power Off
i am no expert but i had simmilar problems and it turned out that some capacitors needed replacing
Oct 25, 2006 | Yamaha DSP-A1 Receiver
NAD C372 Amplifier Logo
267 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
