Question about GE Refrigerators
Part 2 for build up of ice on coil inside frig
Thank you for reply/answer-i have a manual defrost one, i did defrost freezer and even used hairdryer to melt ice that may have been frozen in drain part, the freezer works and frig also still is cold if turned up higher than normal, but frost and ice are still on coils, mostly frost. i will check when i get home from work, if anthing has changed in frig, if anthing else you can suggest, i would really appreciate-thank you again.
  • amylynn0373 Jul 29, 2009
    thank you, that does make sense, but what about icing
    up where freezer drains into frig(on the back), someone told me to clean interior part of drain out, that my problem sounds like a frozen/clogged drain. what do you think?
    New Friend:
  • 63 Answers
Does your locale have high humidity? If it does, there is no true way of stopping the build-up of frost (and ice). Unfortunately, water vapor condenses below the dew point (temperature at which vapor turn to liquid). This happens at higher temperatures in very high humidity environments. It is not as noticeable in the winter months when humidity is low, but the summer months are another story. Just like when you see water vapor on the outside of a glass of ice tea in the summer; you don't notice it as much in the winter months.
Posted on Jul 29, 2009
Water/ice collects under drawers on bottom of frig. Unplugging for 24 hrs helps but I did this 3 months ago and now I have problem again. Frig. is 8 yrs. old.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Oct 03, 2011 | Refrigerators
Freezer ok, ont cooling on refrigerator side
First thing to check is if the evaporator fan motor is running behind the rear panel in the inside of the freezer if you cannot feel the air flowing replace the motor. If when you take the rear panel off giving you access to the evaporator coil you find that the evaporator coil is iced up or has any ice build up on it you would have to defrost this ice build up and if you had this build up this is known as a defrost issue in which either the defrost thermostat, the defrost heater, or the defrost timer or adaptive control board has a fault. I will await your reply till after you remove the rear panel on the inside of the freezer before giving further solution due to if there is no ice build up and if the fan motor is working then you would look at the refrigerator side either the diverter aka damper door or the refrigerator thermostat control. Thanks again I await your reply to your finds
Rick
Aug 15, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have water leaking on the kitchen floor and also have ice build up on the inside bottom of the freezer. The problem is I can't find the drain tube inside the freezer to see if it is blocked. This is...
Leo Ponder
imufo2
Aug 10, 2011 | KitchenAid Refrigerators
Good afternoon........ I have a top mount frig.. we bought it in 1998. The frig works great..... The only problem we have is water seems to built up on the inside bottom of the frig.... I know it is not...
Hi Dan,
It sounds like you have a defrost drain issue. An annoyance to say the least. To repair you will need to clear the defrost drain as it can get a build up over a few years of use. On a top freezer model you will need to unload the freezer and remove the back panel, be sure the power is disconnected by unplugging the refrigerator.
With the back panel off you will see a set of coils that resemble a radiator in a car, below that coil is a pan that slopes to a hole the size of a dime, you may not be able to see that hole due to the ice build up. Clear the ice with hot water and towels to clean up the mess. Careful not to use anything sharp or damage the coil.
Once the ice is gone use a turkey baster to flush hot water down that dime sized hole until it flows clear, you will know when it is.
Reassemble and enjoy a water free frig.
Apr 18, 2010 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
Freezer drain freezes up, leaks on to shelf in frig. It get so bad that there is ice built up on the floor of the freezer. Frig is only 4 years old.
you have a defrost problem it is either a defrost thermostat, defrost heater, defrost timer, u can manually defrost it by unpluggin it for a awhile and lettin it wamr up and clear the ice and that hole.... or posiibly remove that back panel in the freezer and takin a hairdryer to those coils and drain hole or trough,,,,,, this is only temporaliy though u gotta figure out which one of those parts is faulty hope this helps
Jan 31, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Every few weeks the ice in my freezer melts. It
You will need to remove the bottom freezer crisper and check the defrost drain , to see if it is iced over . If so , then use a hairdryer to melt the ice ( hot water also helps ) . When you see the drain , ( could be obvious obstruction from plastic ) , use a small hose inserted into the hole , to blow thru , to remove any unseen debris blockage .
You may have to remove the rear inside freezer panel to access this drain , depending on your model number . So make sure the drainhole is open. When it happened to mine this was the problem.
Oct 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer compartment has frost buildup
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Whirlpool GS5SHAXN Side by Side...
Neither freezer or fridge sides are getting cold enough. There was ice buildup on the back of freezer where the air comes out, but I removed all this and 2 hours later, still not cooling. Fan is running,...
You have a defrost problem. Common problem on most frost free refrigerators because the ice buildup does not allow efficient heat transfer to evaporator coil. You will need to remove the cover in the back of the freezer compartment (you know , where you scraped of the ice).When you remove panel you will see a buildup of ice on your evaporator coil. This will have to be thawed out by hairdryer or some other means before you move onto next step.Next you will see a heater element (black thingy ) or glass tubes with internal elements .These are your defrost heaters. They can usaully be visually inspected but best to use an ohmeter to check continuity.If you have good heaters you will want to put frig into defrost by manually turning the defrost timer clockwise untill you hear frig cut off. (Look for timer inside right frig compartment next to thermostat.) power will now be diverted to heaters and will get hot for duration of defrost cycle. If defrost thermostat is bad this could be the case of problem( round looking disk thingy clamped to coil and wired before heater) You can check by bypassing the defrost therm directly to heater and see if heater works while in defrost cycle.You will want to replace it as this is the device that turns off the heater so as not to overheat and melt plastic in freezer.Just reinstall everthing and you should be good to go.
Jul 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works, frig does not. Also ice build up in freezer coil
I just worked on a FF801W which is supposed to be very similar. The defrost heater in mine was of the glass tube type and located under the evaporator. There was a bimetal thermostat clipped to the top of the evaporator and a thermal fuse (sealed in a clear plastic tube) nearby. The connections were behind a little plastic cover (2 screws) in the back wall just above the evaporator.
Mine was iced up like yours and I had to defrost it with a hair dryer. All the defrosting parts in the freezer compartment turned out to work so I now suspect the defrost timer (down by the compressor). I've marked it and I'm waiting to see if it's turning.
Mar 23, 2009 | Avanti FF1101W Top Freezer Refrigerator
Refrigerators Logo
126 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
