Computers & Internet Logo
E
Elmer Fuller Posted on Nov 22, 2017
Butalbital-asa-ca-50-325-40-30. How can I identify
PILL IDENTY MIA110
Acetaminophen/butalbital/caffein, and it is used in the treatment of headache and belongs to the **** class analgesic (pain meds) but is not a controlled substance.
Try: https://www.drugs.com/pill_identification.html
Need help in buy my little dirls school clothes single mother in Redlands ca
Try the Salvation Army in Redlands. They may be able to help. http://www.redlandssalvationarmy.org/
Din greseala am introdus invers usb-ul in computer si hardul nu mai functioneaza.nu i-l mai vede in computer.in sistem i-l vede ca usb device.*** sa procedez ca sa-l computerul?cel putin sa pot sa-l...
regret dar nu prea mai ai ce face - cind ai introdus usb-ul invers s-a inversat si alimentarea lui asa ca aproape totul a fost prajit. daca ai noroc s-a prajit doar interfata carcasei - scoate hard discul din ea si pune-l intr-una noua
http://www.pcgarage.ro/rack-uri/filtre/general-tip-rack-extern-hdd-25-quot/general-interfata-hdd-sata/
si o sa fie ca nou.
How to export log from CISCOASA?like other cisco device logging 1.1.1.1 i want similar kind command in CISCO ASA
ASA's log is usualy stored localy on ASA itself, so easiest way to export that log is to go with telnet/ssh/console on it, do a command : show logging and copy/paste output into a new file.
but beware - this log is really short and as soon as ASA is rebooted - it's gone.
you could set asa to log to a syslog server (free on linux/freebsd or for windows use KIWI app).
that way all ASA log output is stored on pc/server running your syslog server.
My cisco asa 5505 lost it image file ... how can i get the image back
if it is really deleted from FLASH, you will need to connect to ASA with a console cable, start up TFTP server on your pc, and in TFTP copy your ASA image file (.bin - on your CD that you got with ASA) so that you can get it from pc to asa.
then use tftpdnld command to set all the parameters on asa and start the download of the file from your pc .... after it has been done - just reboot asa :)
17helpful
2answers
De ce imi apare add request pending
sa inteleg ca esti roman, asa ca am sa itzi explic tot asha....iti apare add request pending in dreptul unui id din lista ta, nu? asa ar trebui. ei bine, asta apare atunci cand tu dai o cerere de acceptare a id-ului tau, iar cealalta persoana inca nu ti-a acceptat cererea. tot ce trebuie sa faci este sa astepti.:D
1helpful
Oster coffee maker
Looks like you will have to contact Oster directly. I am unable to find replacement pots asa standalone for sale. You can contact them here:
http://www.oster.ca/consumerservice.aspx?content=contact
Or you can call them at (800) 334-0759
Canadian Residents: (800) 667-8623
1helpful
2answers
Upgrade firmware on a cisco ASA 5500 firewall
This is for the pixes, I haven't upgraded an asa yet...should be close or the same
* find latest version of code, these are usually *.bin files located on http://www.cisco.com/cgi-bin/tablebuild.pl/pix
* confirm the flash and RAM requirements of the PIX OS software versus what the PIX has (”sho ver”)
* make sure you have a backup of the old PIX OS and PDM to the tftp server (or at least confirm the software is there)
Note: You cannot back them up from the PIX, so you will need to download them and put them on the tftp server * put in a change control form
* once change controls confirms date/time do the upgrade:
wri mem*** only if you save your configs via tftp wri net conf t ca save all copy tftp://your tftp server ip/pix635.bin flash:imageskip this if you don't use pdm copy tftp://your tftp server ip/pdm-304.bin flash:pdm *** if this is a failover pair, upgrade the other pair reboot
Grand Canyon Tech
Grand Canyon Tech
