Question about Panasonic Microwave Ovens
What does a display of h98 on a Panasonic microwave oven indicate?
    New Friend:
  • 44 Answers
Inverter and melectron faulty will couse this problem
Posted on Dec 20, 2017
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I discovered that a fridge magnet attached to the side of the microwave was causing the H98 problem. Removed the magnet and the microwave worked fine again. Lesson learned... never attach fridge magnets to outside of thr microwave.
Posted on Nov 14, 2018
SOURCE:
MicrowaveSvc
  • 9173 Answers
SOURCE: MESSAGE DISPLAY H98
The H98 fault on a Panasonic can be a bad magnetron, inverter or control panel.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 29, 2008
MicrowaveSvc
  • 9173 Answers
SOURCE: panasonic inverter
In most cases, this is a problem with the inverter or a bad magnetron.
Posted on Jul 01, 2008
  • 52 Answers
SOURCE: Panasonic Microwave
the error code H98 refers to the heating filament on the magnetron, unless you are confident I would not progress further
Posted on Feb 21, 2009
MicrowaveSvc
  • 9173 Answers
SOURCE: Panasonic Microwave show H98 in window
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Jul 05, 2009
  • 512 Answers
SOURCE: our microwaze is shutting off after ~25sec saying H98
Your microwave generation system has failed and Panasonic recommends that you get it serviced by a qualified tech. Hope it is under warranty!
Posted on Sep 17, 2012
Testimonial: "We had to go out and get a new one, basically H98 means that it was "fried"...learned lesson to try and keep all appliance manuals organized on file...we couldnt find ours so it was nice to try on-line....thanks for the help"
Trouble code H98
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
My Panasonic NN-ST657W microwave has suddenly come up with an H97 code on display panel. Switches off after about 6 seconds before displaying this code. What has happened?
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
Dec 31, 2010 | Panasonic Microwave Ovens
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
What does H98 mean on the display of the microwave screen?
Dec 26, 2009 | Panasonic NN-SD797S Microwave Oven
Microwave will not work...display reads H98
Dec 14, 2009 | Panasonic Microwave Ovens
I HAVE MIC. NN-SD997S ,IT DOES NOT WORK ,MESSAGE SAYS "H98" .
This displaying indicates a
problem with the microwave
generation system
This is for your dealer to resolve
Mar 11, 2009 | Panasonic NN-SD997S Microwave Oven
H98 error
Dec 31, 2008 | Panasonic NN-H965 Microwave Oven
MESSAGE DISPLAY H98
Jun 27, 2008 | Microwave Ovens
Microwave Ovens Logo
859 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
