Question about Olympus FE-280 Digital Camera
Same exact thing......My mom thinks it needs a new battery.
When I turn my camera on the lens comes out then goes right back in for about 4-5 times.
Then it turns off.
I have an olympus FE-340
  • 300 Answers
Hi!
It sounds like your camera lens focus is stuck - could be sand or something in the focus gears - that's the weak spot of these lens. If you can't open the lens and check your lens focus gears yourself, you should contact your local Olympus service center or other camera service center. You can contact me too at toms.safranovs@gmail.com and I can give you a good price.
Hope this helps!
Tom
Posted on Jul 29, 2009
Turn camera on, lens comes out, goes back in ,and says lens error.
try these fixes
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable nimh 2500mah or better) and turn the camera on. If using rechargeables, and they're more than a year old, consider purchasing new rechargeable batteries as they may not be providing sufficient power to startup the camera. If new batteries didn't work, try pressing and holding the 'Function' or OK button while turning the camera on.
2.If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
3.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
4.Insert the cameras audio/video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fix 3 as a means to provide extra power to help to this fix. Reinsert the cable only after tapping the camera.
Feb 07, 2011 | Nikon Coolpix S3000 Digital Camera
I631 camera won't turn on
Mine dose that too ugh i got new batteries but it didnt work it dose the same thing i am wondering if it is jammed or something
Jun 02, 2009 | Polaroid i631 Digital Camera
Won't stay on even with new batteries- it beeps then turns off
my camera is doing the exact same n i'm hunting the net right now for some kind of solution!! :( i think its something to do with the lens, mine was completely stuck, but i gently pushed it n it went back in and moves in and out fine, but the cam still comes on for a couple of seconds makes this wierd beep n goes off again!
May 27, 2009 | Samsung S760 Digital Camera
Cannon G7 need help
Hi
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
Zoom
If the batteries are a common type, install them into another device to see if they really are still OK or buy a cheap digital multimeter or battery tester.
The latter can be bought at the chain hardware stores or Radio Shack and draw some current to lightly test the load capabilities of them.
These batteries do fail to a short; NICads are the worst but lithium ion and NiMh can fail as well.
The 'sand' diagnosis may be right but what you describe could still be only batteries.
Aug 25, 2008 | Olympus FE-230 Digital Camera
Lens not working after only one year
Same here.. bought the camera early April '07. Problem began in May of '08. Turn it on and the lens goes in and out several times but it won't focus.
Jul 12, 2008 | Olympus FE-230 Digital Camera
Lens Error Message 10f, 1, 0, 0
I just had the same problem like 10 or 5 minutes ago. I think that I am going to need to get a new one, take it to a lens(camera) shop, get a refund or take the damn thing back..and or, get a "NEW" thosand(jkjk) dollar camera..oh! and did u know that now! at walmart they are selling a deluxe package that comes with this same camera for $147.99..I was so mad when I seen and heard that because my mom bought this SAME camera for the SAME pice that they are selling the SAME camera w/(with) more things included...grr, damn you koday(jkjkjk lol) any wayz, I think that i am going to trade it in for that lol...thanks ya..peace!
Mar 24, 2008 | Kodak EasyShare M853 Digital Camera
It turns on but then turns off
You need new batteries... My camera did the same thing
Dec 15, 2007 | Polaroid I533P Digital Camera
Stuck Lens, Beeping, Auto Turn-Off
The same thing happened to me. It was my wife's camera so I bought her a new one and planned to send the damaged camera in for warranty repair. I took the batteries out and put it back in the box. About 5 months later, just as I was planning to ship it to Canon, I thought I would put batteries back in it and see what happened. It started working and has worked since. Ron
Feb 09, 2007 | Canon PowerShot A520 Digital Camera
Camera lens comes out and goes back in when I turn it on.
Sounds like the lens can't get into the proper position. Any possibility of damage to the lens?
Aug 10, 2006 | Olympus FE-110 Digital Camera
Olympus FE-280 Digital Camera Logo
417 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
