Question about Philips Televison & Video
I need the base stand for my tv cus been wall mounted and now need it on stand and i lost it
  • 34 Answers
Not all Philips tv's will use the same stand. First, look on the back of the set for the model number. You can purchase most television parts, including stands and base assembly at http://www.partstore.com/
Posted on Jul 29, 2009
I have wall mount and now I need remove the pedestal stand from the TV. But I have lost the manual and can some body explain the steps to remove the stand? Thank you
Without knowing the model of your TV, it may be tough, but typically it's 1 or 3 types:
- the whole base is a single piece that slots into the bottom of the TV, with a clip release.
- the base removes from the stand, and the stand removes from a slot in the TV. This may be fastened with clips or screws.
- the base is screwed into the TV, and you'll have to remove these to remove the stand.
If that doesn't help, please provide more details, like the make and model of your TV.
Dec 18, 2014 | Televison & Video
Where can I find the piece that holds the tv for vs91350-01
Walmart and others have the universal "jimmy stand" for about 90 bucks. This will mount to the TV (on the back like a wall mount) but also includes a base so you can simply set it on a table.
http://www.walmart.com/ip/ShopJimmy-sj-Stand-3755BB-Universal-TV-Stand-Base-Plus-Wall-Mount-for-37-inch-55-inch-Flat-Screen/36774428
or search
sj-Stand-3755BB
Oct 26, 2014 | Televison & Video
Can I buy screws to fix base onto my umc tv
Yes The screws that you took off the back of the tv mount on wall brackects mounted on the back of your TV should be the same size
6mm
Oct 23, 2014 | Televison & Video
I need a Panasonic TV TH-42PD25 base stand! I've searched ebay, no luck. This might sound dumb, but can I use base stands from any of the other Panasonic 42" models?
You maybe lucky, but make sure the mounting holes on the stand matches your TV.
Alternately you can use a wall mounting and these have mounting holes that suit most TVs.
Nov 30, 2012 | Televison & Video
I lost the tabletop stand for my RCA L32wd26d TV when I wall mounted it. Where can I buy the stand from again?
Tries websites like Amazon.com,Ebay.com to buy a used base stand or a new base stand.
Dec 17, 2010 | Televison & Video
Need a table top stand for a LG 15" (model
Tries websites like Amazon.com,Ebay.com to buy a new or used base stand for ur tv.
Dec 08, 2010 | LG 15LC1RB 15 in. LCD Television
How do I take the stand off of the TV? (For wall mounting)
There will be clips or screws on the back of the TV which will need to be removed and the base stand will slide out of the bottom of the TV. Do NOT start taking screws out of the back of the TV without the wall mount with instructions. Sometimes there are spacers that need to be used with the wall mount and generally only four screws need to be removed from the TV. The TV should have instructions on how to prepare the TV for a wall mount as well. All are different, but very similar to do. If you lay the TV face down on a soft surface (do not slide it around) you probably can see what screws need to be removed to remove the TV base. Keep the screws with the stand for later use if desired because you will need them to re-install the case later. Here are two examples;
I hope this helps and good luck!
Nov 12, 2009 | Televison & Video
I need instructions for wall mounting
The TV is not the problem, if you have the parts to attach to the TV, and the screws that come with it, there is only one position that fits the support base on the TV, but the other part, I mean, the way that the support base is attached to the wall, I strongly recommend to find a Handy man who can do that job because must be a solid and deep surface in order to avoid the TV drop itself in any moment.
May 03, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Televison & Video Logo
888 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
