Question about Stanley Tools Staple/Brad Nail Gun
Bostitch N60 finish gun - air leaks out of the trigger when the air hose is connected
  • 2,176 Answers
There is an oring that is probably broke in half, It is referred to as a purple o ring. You can buy the whole trigger assembly but I think that just replacing the one will get you going. Let me know and I will try and help more
Posted on Jul 29, 2009
    Problem Solver:
  • 10 Answers
Replace the trigger assembly part # TVA6, I am assuming the valve assembly in your gun is green, if so they are highly pron to failing. The new valve assembly will be white and should last the life of the tool.
Posted on Oct 31, 2009
Bostitch just blows air when trigger is pulled
Air leaking from trigger when attempting to fire the gun is normal and should cause nailer to fire, however if the trigger pin is not depressed all the way in,the gun may not respond. Easy test. Remove the nails and remove the trigger. Connect the gun to air and quickly depress the valve pin all the way in with finger. If the gun fires, adjust the safety foot so that the trigger pin is depressed all the way in. If the gun still does not fire, then remove the head cap and pull out the headvalve. Apply plenty of white grease to orings and retest. If the gun fires, then replace the headvalve orings. When the headvalve orings are worn, air will leak from bulkhead chamber to the headvalve chamber causing the gun to not respond to the trigger. The addition of grease to worn orings will make them temporarily seal. Good luck
Jun 16, 2016 | Stanley Bostitch N66c1 114"to 212" Coil...
Bostitch N62FN air leaks out the cap and it wont pressure up or fire. Is the piston ring solid
Glad that you repaired your gun. The piston oring is the only oring in the gun that can have slit and still work fine. It works like a piston ring in a motor. Small ring gap is ok just as long as the piston does not drop down the cylinder under its own weight. The piston oring does not hold pressure, it only reacts to pressure when headvalve opens. When this series of gun leaks air, it is usually due to headvalve orings (lube with white grease), Cylinder seal loose or broken, or trigger valve oring splits (tva6 valve). Good luck
Mar 29, 2013 | Stanley Piston Driver Assy Bostitch N62fn...
When using n60 nailer, one nail goes all the way in, but the next nail only goes halfway in and the some don't go in at all. Don't know what's wrong.
Worn orings in gun and the trigger valve can/will cause problems as you describe. Remove the nails and leave open the latch. Lighty tap the nose of the gun against coiled rubber hose. The driver/piston should stay in the top position (if the driver is down or comes down after test, replace driver oring). Now push the nose against the rubber hose and activate/hold trigger, while holding the trigger/gun in this position, the driver will /should stay down under pressure. At this point no air should leak out of the nose of the gun. If air leaks out of the nose, examine the lower bumper for cracks ( replace as needed ). Finally remove the trigger and examine the firing valve pin. If it has a plastic pin, looks worn and wobbles from side to side, most likely needs to be replaced. If however it has a metal pin and it seems to fit snugly, do not change unless it is leaking air. Good luck
Jun 19, 2011 | Stanley Bostitch Air Nailer Trigger N60...
GUN DOES NOT FIRE FOR SEVERAL ATTEMPTS--even though gun is pressed firm against work---just had unit serviced and trigger valve replaced-----any suggestions? thanks joel
Remove nails and remove trigger to expose trigger valve pin. Place nose of gun against rubber pad or old coiled up air hose to absorb impact of driver and with very quick and deliberate motion press in trigger pin. If gun fires, then problem is with safety foot not pushing trigger pin all the way in (or worn trigger). Make adjustment as needed or replace faulty parts. If gun still does not fire, then likely problem is with headvalve. If headvalve orings are leaking, gun will not fire. Test for leaking orings as follows. Remove head and remove headvalve, apply silicone paste lube (plenty) to all orings and where orings contact. Assemble and do test above. If gun fires then surface where orings contact is allowing air to leak(smooth with very fine sandpaper if scratched).
Mar 13, 2011 | Stanley Piston Driver Assy Bostitch N60fn...
Bostitch RN46 will not fire nail, only releases air when trigger is held and firing tip is touched to surface of material. Any ideas on what is wrong?
Gun will not fire if air is leaking past orings in head /headvalve or safety /trigger is not pushing trigger pin all the way into trigger valve. Test: Remove trigger to expose trigger valve pin. Remove nails. Place nose of gun against thick rubber mat or coiled rubber hose to absorb blow of driver. Very quickly and deliberately press trigger pin all the way in. If gun fires, safety foo or trigger is not pushing trigger pin all the way in. Make adjustments or replace worn parts. If gun still does not fire, remove head and pull out headvalve. Apply lots of silicone paste lube on the orings and the surface of the head where orings make contact. Reinstall head and test as above. If the gun fires then orings were leaking. Replace orings and sand any scratches on body of cap with very fine sand paper. Parts are at www.toolpartsdirect.com Good luck
Mar 06, 2011 | Stanley Factory Reconditioned Bostitch...
How is the trigger valve on a Bostitch N60 nailer removed for replacement?
To remove tva6 (or similar) valve on n60 you will need to use air pressure. Remove roll pin at trigger with 3mm punch. Next remove one or two roll pins just above trigger valve (also 3mm). Reduce air pressure to 20psi (or pressure needed as some valve will be stuck) and use glove or rag to catch valve as it pops out of gun. Use caution as you connect air to gun because the valve could come out with force. Clean port and check for sharp edges before installing new valve. I use silicone paste on orings (available at Lowes in plumbing department). Good luck.
Aug 10, 2010 | Stanley Air Tools & Compressors
Bostitch N60 finish nailer. The driver will not return. into gun and blows air out by trigger. How to fix?
You will need to replace the trigger valve, the one you need is a P/N- TVA6. As far as the driver not returning, it could be a broken head valve spring,(spring in the back cap under the head valve) or possibly a broken driver blade.
Feb 03, 2010 | Air Tools & Compressors
Stanley finsish nailer and air is leaking through the trigger as.
If the air is coming out the trigger it must be replaced. Depending on the model of gun you will have to replace the trigger assembly or various o-Rings. Find a Bostitch dealer in your area and they will supply the parts you require.
Jul 14, 2009 | Stanley Bostitch FN16250K - 2 16 - Gauge...
Have a bostitch N60 with a trigger air leak
Your nailer uses a trigger valve part # tva6 (cost about $20) and is sold at www.bostitch.com. If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body(Use punch for 3mm hole). Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring/seal on plunger is cause of leak. Try using an oring with smaller inside diameter than the broken or loose fintting seal that is present. It must fit pretty tight and be slightly thicker than 1/16" to work. Remove the outer orings to valve and clean and re-use same. Clean the valve port in body of gun and check for sharp edges to prevent cutting orings before inserting the valve. Use silicone lube or oring lube on the orings and the valve port (Danco silicone paste sold at Lowes in the plumbing department). Good Luck on your repair and email if you have other questions
Apr 26, 2009 | Air Tools & Compressors
Help with Bostitch N60 air nail gun.
If it is a N60FN you will have to install a new trigger valve P/N TVA6. Any Bostitch service center should have them.
Apr 08, 2009 | Tools & Hardware - Others
Stanley Tools Staple/Brad Nail Gun Logo
587 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
JOHN LAPIER
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
