For Chevrolet only, the shift lever is in FIRST (1) or SECOND (2) gear. The EBCM receives a class 2 message from the powertrain control module (PCM) indicating the gear position.
For Pontiac and Oldsmobile only, the body control module (BCM) detects that the traction control switch is pressed (signal circuit is low). The EBCM receives a class 2 message from the BCM indicating the switch status.
The BCM detects that the park brake is engaged (signal circuit is low) and that the engine is on. The EBCM receives a class 2 message from the BCM indicating the park brake status.
The PCM detects certain malfunctions and is unable to perform torque reduction requests from the EBCM. The EBCM receives a class 2 message from the PCM indicating that traction control cannot be performed.
The EBCM detects a malfunction in the traction control system. The IPC receives class 2 messages from the EBCM requesting illumination of both the service vehicle soon and traction off indicators.
The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
With the light lit there are DTC'S - diagnostic trouble codes stored in the EBCM -
TRAC OFF
Traction Off: Refer to ABS Description and Operation in Antilock Brake System
The body control module (BCM) detects that the traction control switch has been pressed (signal circuit is low). The BCM sends a serial data message to the EBCM in order to disable traction control. The IPC receives a serial data message from the BCM requesting illumination. The BCM sends a serial data message to the radio in order to activate an audible warning.
you need to have the ( EBCM ) electronic brake control module checked fro codes !
