Question about Dryers
Dryer getting hot
Frigidaire MN FSE446RHS2 electric dryer
Recently opened up everything and greased the back of the drum to solve a grinding noise. While in there, vacuumed out all stray lint from fan, duct work, nooks & crannies. Replaced duct from dryer to wall, about 12 inches. Hooked everything back and the noise was gone and had good air flow outside. A few loads later, noticed clothes would not get completely dry on medium setting. Switching to high setting noticed rear getting very hot and would even give clothes a burned smell. What things can I check?
Thank you
    President:
  • 1,776 Answers
Dryers overheating is usually caused by a venting problem, but it sounds like you have the bases covered on that. I would look at a faulty high limit thermostat. It can be checked with an ohm meter to see if it is faulty. Hope this helped and best wishes.
Posted on Jul 29, 2009
MY FRIGIDAIRE MODEL FAQE770KW0 DRIER IS MAKING A LOUD NOISE AFTER IT GETS HOT
you might need a new roller on the back of the drum, As for being louder when warm it's the part getting hot from Friction that is wearing the roller or roller pin down.
Oct 09, 2014 | Frigidaire FAQE7077K Electric Dryer
How to fix Frigidaire GLER341A hums and vibrates when hot?
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
May 05, 2014 | Frigidaire GLER341A Electric Dryer
Grinding Noise
Check for warn drum rollers
Jun 05, 2017 | Frigidaire Dryers
I can't find the thermal fuse on a fse446rhs2 electric model
Location is inside the cabinet on the back wall. Upper right hand corner by where the terminal block is. Mounts by 2 screws. Part number 134120900 .
Sep 15, 2009 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire FSE446RHS2 electric dryer makes bumping noise when drying. Opened the top, belt is ok.
Rear bearing and drum coupler needs to be replaced
bearing kit part #WC5303281153 is available online from many parts stores. You may want to replace the belt at the same time while you have the unit apart. Also inspect the front upper drum felt if it is worn replace it. The whole repair time for me was about 45 minutes dryer now runs like new.
Jul 30, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Dryer won't heat up. I don't have a parts manual.
more than likely the theraml fuse on the back of dryer unplug unit and use a continuity tester to check for ohms. the t-fuse is on the exhaust tube also the squeaks usally comes from the drum rollers use a little silicon grease and lube the roller shaft
May 28, 2009 | Frigidaire FSE748GF Dryer
Dryer noise
TAKE THE DRYER APART USE A LITTLE MOTOR OIL TO GREASE ALL SHAFTS ON IDLER PULLEY AND USE A BIT OF VASALINE ON THE REAR BEARING ON THE BACK OF THE DRUM THIS SHOULD TAKE CARE OF THE GRINDING NOISE
Dec 21, 2008 | Hotpoint NBXR463EBWW Electric Dryer
Frigidaire stackable dryer fse446rhs2 makes a bumping noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dfghjhd
Nov 08, 2008 | Frigidaire GLGQ2152ES Gas Dryer
Squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Dec 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
124 people viewed this question
Top Dryers Experts
